| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
(Thread Starter) | Not Ranked : 0 score from what i have read they stack up pretty well to a higher end coilover like KW but without the huge price jump from BC/megan/DGR. here are the general specs: Features: • Full length adjustment system on lower mount • Separate ride high and pre-load adjustments • 6061 t6 Aluminum alloy construction: lower mount, top mount, spring seat and locks • 12 level adjustable damper - adjustable dampers allow fine-tuning of the suspension stiffness to best suit the driving condition. • Scm440 hardened piston rod: special high strength grade material with extra hardening process effectively improves the chances again deformation, fracture and leakage. • Special formulated oil - stable and durable high quality oil seal can minimize any suspension failures or oil leaking to increase durability. • Inner polished seamless steel tube - quality high strength tubes ensure the strength of the struts (cylinders). The micro finished inner surface ensures a precise and smooth action, which can reduce the chances of fluid leakage and prolongs struts endurance. • Mono tube design ensures quick response and comfort. suspension fluid is separated from high-pressure gas in order to reduce damper failure. • Advanced formulated rubber parts: effectively increase the endurance and help eliminate abnormal noises. • Forged aluminum alloy top mount: increases the strength and effectively reduces the weight to provide sensitive driving feedback. • Sae9254 spring: high strength material formed spring effectively minimizes deformation. MS3 spring rates are 7k/5k MS6 spring rates are 12k/5k the S1 version dont have the adjustable top plates and the S3 version does, i believe this is the only difference but i can check. heres some picts, these arent the exact MS3/6 versions (they are actually for BMW) but you can get a good gauge of the quality/components which would be the same for the mazda version. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() and here are some review threads i found for the BMW version. everyone seems to have great things to say about the quality of the coilover itself and the adjustability. Sonic Tuning S1 Coilovers (Impressions) - BMW 3-Series (E90 E92) Forum - E90Post.com Sonic Tuning Coilovers installed - BMW 3-Series (E90 E92) Forum - E90Post.com Sonic Tuning Coilover Review - BMW 3-Series (E90 E92) Forum - E90Post.com ive also been told my buddy is bringing his coilover to here to get it shock dyno'd against stock, KWv2, and a koni yellow. they had it done once already by a member on the BMW forums but couldent locate the results. Road Race Technologies im gona place my order in late january and shipping takes 2 weeks AFAIK so if anyone wants to jump in on this order give sonic tuning a call and tell them you want to be placed in with my order (anthony from MSF). 202-425-5255 ask for Wei (pronounced way) he will know who i am. the price is $899 shipped i believe for the first few sets and he diddent say how long that would last. ok here's what i have so far MS6: 2 sets of the S3 GenWON: 5 sets of the S1, 3 sets of the S3 GenPu: 3 sets of the S1, 2 sets of the S3 GB pricing will be 1099 for the S3 and 999 for S1, if we can get more then 5 people to order then everyone will get $100 off. so the first 5 people will pay $1099/$999 depending on what set they want, then when we reach 6 people the first 5 will get a $100 refund by CC or Paypal and everyone else after that will just pay the $999/$899 price! these come with a 1 year warranty against wear/tear (ie if you blow a shock) and a LIFETIME warranty against manufacturing defects (such as a broken coil, snapped bolt/bracket, ect). Sonic Tuning prides themselves on customer service and always making sure the customer stays happy no matter what. go ahead and read some of their posts on the BMW forums and see how happy the customers are. since Wei hasent finished the vendor form you can just go ahead and call him directly to place your order. i will update this thread with how maby people we have so we can keep track.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner Last edited by superskaterxes; 07-06-2012 at 07:35 AM. |
| The Following 25 Users Say Thank You to superskaterxes For This Useful Post: | AZSPEED3 (01-10-2012), BigjohnB20 (01-09-2012), BobtailedSnail (01-09-2012), charlesfist (01-09-2012), Design (01-09-2012), djuosnteisn (01-20-2012), dougefresh_ (07-09-2012), fishin53 (02-05-2012), IshiKage (01-09-2012), JacksonMS30 (01-20-2012), jracer (02-04-2012), MGM_GT3 (01-19-2012), Micha (05-26-2012), MS3-a(sore)ASS-rex (01-09-2012), Nataphen (01-28-2012), NinjaT1985 (01-09-2012), Onelovesoccer (07-12-2012), paveltol (05-27-2012), Pointless (04-18-2012), psychophyr (06-29-2012), rghispanic88 (01-09-2012), tddvrrn (05-24-2012), TexasSpeed3 (01-17-2012), uncorked11 (01-09-2012), Worbit (06-22-2012) |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
| Not Ranked : 0 score I talked to one of their reps that knew you around when the whole forum wars fiasco was happening. Are they gonna release these for the 3 too? It's been months since I first heard about it. I had volunteered to test them too
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | JacksonMS30 (01-20-2012) |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,607
| Not Ranked : 0 score Damn I just picked up some USED RPM springs and Koni shocks for just a couple hundred shy of that price. Great to see another option for the 6 guys, especially at what looks like a good cost/performance point. Interested in how these turn out.
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score That's awesome. I notice he's having a special on the website right now selling wheels for $399.
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
http://www.mazdaspeedforum.org/forum/foru...-5-48-a-99078/
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | ||
| The Following User Says Thank You to superskaterxes For This Useful Post: | MS3-a(sore)ASS-rex (01-09-2012) |
| Not Ranked : 0 score Interested in shock dyno results, then may pick up a set. Price point is great but quality and longevity are even more important.
| The Following 6 Users Say Thank You to Lex For This Useful Post: | AZSPEED3 (01-10-2012), charlesfist (01-09-2012), daafisch (01-09-2012), Design (01-09-2012), obijack (01-20-2012), superskaterxes (01-09-2012) |
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz | |
Groans: 224
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA | |
![]() Join Date: Feb 2011 Location: St. Louis, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Options are always good..will be in the market soon
__________________ ||2008 Metro Grey Ms3|| Cobb Sri|| Cobb TIP|| Cobb AP|| TurboSmart Dual Port BOV|| ATP full downpipe|| Autotech fuel pump internals|| TurboXS FMIC|| Denso ITV22's|| JBR 88a RMM|| BC Coilovers|| Evo X Wheels|| 25% E85 Mix|| Phate Tuned|| |
| The Following User Says Thank You to RyansSpd3 For This Useful Post: | superskaterxes (01-09-2012) |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score Look like quality shit for the $$$. How would these compare to the AMR coils? |
EDIT: i was thinking AMR = AST
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner Last edited by superskaterxes; 01-09-2012 at 11:09 AM. | |
| Not Ranked : 0 score Amr is like 1500 bucks lol
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Yeah, I'm pretty sure he was thinking of ASTs
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
shock dyno will happen this week sometime. will post results when i get them!
| The Following User Says Thank You to superskaterxes For This Useful Post: | Tokay444 (01-09-2012) |
| Not Ranked : 0 score Hey, Skater, in the event I still have time what's up with the center bore? When I contacted them they said they'd bore out the hub for me for extra $$$. Do these come with the proper center bore hole size? 67.1mm IIRC.
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score Ant, you know i'm gonna want your BCs once you go with these Wei Springs.
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 |
all of the closeout wheels they have left were all 54.1 IIRC which is the subaru standard bore. they have a machine shop around the corner that bored each set out to 67.1 that was ordered for exact fitment. this was done at no extra charge for anyone.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner Last edited by superskaterxes; 01-09-2012 at 12:26 PM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score Looks like they use an adjustable preload assembly instead of a helper spring. Spring rates seem pretty close to KW's OTS rates. I'm interested to see photos of the actual product. Do they reuse the rear jounce bumpers or supply their own? And it looks like they supply their own upper assemblies both front and rear? And how is damping adjusted - one knob for both compression/rebound or separate adjustments for each? |
| The Following 2 Users Say Thank You to Design For This Useful Post: | charlesfist (01-09-2012), Lex (01-09-2012) |
def have new top hats in the front (pillow ball with s3 version) but reuses the rear tops. one knob for comp/reb. the main difference between these CO's and say the KW's is the QUALITY of the components and the design. the s1 isent some crazy track CO (the s5 would be) but its similar to BC in that it was meant for street/light track duty but with much much much higher quality components.
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 739 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score why so low rate for the rear on the ms6? im loving the stiffer setup on my car.
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
(Thread Starter) | Not Ranked : 0 score no idea, i imagine it makes the car a little more even but its just what the designers came up with
| Not Ranked : 0 score Being monotube, I was pretty certain that they have a simple primitive single-adjustment knob for both compression and rebound, as true double-adjustable monotubes are hard to produce below the pricepoint of say, ASTs or Hotbits... Definitely not something you're going to see in the sub $1K (or even sub $2k, probably) price range.
![]() | | #24 | ![]() |
I'd rather have a damper where if it only has one adjuster, it's adjusting rebound only (Like a twintube Koni Yellow, or the twintube KW V2 dampers). Adjustable monotubes aren't worth investing in as far as I'm concerned unless you're going to "go-big" and get a setup with independent circuit control (AST has a line of rebound-only adjustable monotube dampers that go for ~$2k a set for most platforms, and that's about the cheapest I've probably seen). Of course, this is why I run a twintube double-adjustable setup... Because it offers me the fine-tunablitity I'm looking for (compression AND rebound, completely independent of one another) without costing ~$3K.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
![]() | | #25 | ![]() |
| Not Ranked : 0 score ^^^^ what coilovers you running?
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
Groans: 70
| Not Ranked : 0 score Yea the AMRs are like 16xx with camber plates |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Right, and AMRs still utilize simple single-knob rebound/compression combo adjusters, just like BC, Sonic, Fortune Auto, DGR, etc.... Someone correct me if I'm wrong.
![]() | | #29 | ![]() |
| Banned ![]() Join Date: Sep 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score Looks tempting... Might give them a call seeing as all of the BC's are backordered |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Wouldn't have them until late next month :/ |
![]() | | #31 | ![]() |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
Groaned at 8 Times in 5 Posts
yum | |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score it helps if we all place an order at once because shipping is really expensive from taiwan lol if your still interested let me know and ill put you on the list to order them late jan.
![]() | | #33 | ![]() |
![]() Join Date: Mar 2011 Location: Bastrop, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,208
Groans: 273
| Not Ranked : 0 score subbed
__________________ 2011 Black Mica - Daily JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp |
![]() | | #34 | ![]() |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score What was the result of the shock dyno?
__________________ 2006 Black Mica MS6 - Sold 10/15 |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score they have been swamped the last 2 weeks but he said he made an appointment for this week to get them done. sorry guys!
![]() | | #36 | ![]() |
![]() Join Date: Feb 2010 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score I might be interested as well. Of course test results, graphs and an actual pic of the setup is a MUST before I place my order. I have been looking for a budget decent setup that will serve 2 purposes street and occasional track days... Keep me posted... ![]() CB |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok i made the appt for the dyno for tomm!!! hopefully will have results posted tomm too
| The Following 3 Users Say Thank You to superskaterxes For This Useful Post: |
![]() | | #38 | ![]() |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,042
| Not Ranked : 0 score Damn. My wife is badass but not badass enough to let me pick up CO's yet. Maybe next year when I go FR
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Dyno results?? |
![]() | | #40 | ![]() |
| Not Ranked : 0 score ^^ Results? I didn't see this posted ealier, but any info on where these are made? Was the dyno a full sweep for adjustments? |
| New Sonic Tuning ST8s... | NinjaT1985 | 2010 MS3 - Wheels & Tires | 19 | 01-08-2012 10:22 AM |
| Sonic Tuning ST8s | MS3inDC | Wheels & Tires - BLACK | 7 | 09-07-2011 09:50 AM |
