  • 1 Post By Nliiitend1
 Old 12-10-2012, 05:24 PM   #1
vivalawham's Avatar
Posts: 16   (View Stats)
vivalawham is on a distinguished road
Default Swaybars, Shocks, & Axles
I've done hours of reading on this stuff, but I'm still a newb, having no practical experience. Here's what I'm thinking about getting, please let the opinions fly. This car is a daily driver with occasional track use. I've found varying reports on the axles - I just really don't want to drop $500 at the dealer for an axle with a 12 month warranty, when I can get one from O'Reilly's with a limited lifetime warranty.
Whiteline 27mm FSB
JBR RSB
Koni Yellow Shocks
Masterpro Axle
MasterPro® CV 60-8189 - CV Drive Axle | O'Reilly Auto Parts
vivalawham is offline   Reply With Quote
 Old 12-10-2012, 05:58 PM   #2
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
Need to know a little more details on exactly what type of tracking etc, also what are your goals with these part....it will help evaluate if they are right for what you need. Also, are these to compliment some other mods???
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
 Old 12-10-2012, 06:10 PM   #3
supertubesocks's Avatar
Posts: 404   (View Stats)
supertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the world
Why so worried about axels?
Sent from my PC36100 using Tapatalk 2
supertubesocks is offline   Reply With Quote
The Following User Says Thank You to supertubesocks For This Useful Post:
PreyStayShun (12-11-2012)
 Old 12-10-2012, 06:11 PM   #4
2k4_8's Avatar
Groans: 64
That's exactly what I was getting at. Based on what he typed in, I have no clue why he picked those particular parts and not others that may be of more help....but it's all dependant on what he responds with.
 Old 12-10-2012, 07:28 PM   #5
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
dude, you are making no sense to us right now. why do you want new axles? i have never heard of people replacing axles unless they break..
the rsb is great, i've heard loads of good things about the koni yellows and FSDs..
as for FSB, some auto-x'ers say no FSB because it disrupts the function of the front suspension.. plus, it seems like a mother to install...
The Following User Says Thank You to tddvrrn For This Useful Post:
2k4_8 (12-10-2012)
 Old 12-10-2012, 07:38 PM   #6
2k4_8's Avatar
Groans: 64
Not to mention I think some good springs would help a lot more than a fsb...unless he's got em already.
 Old 12-10-2012, 07:52 PM   #7
vivalawham's Avatar
Should have elaborated a little more - first, everything is stock. My RF axle is shot, as are all the swaybar bushings and the right rear shock. My thinking was if I'm going to replace the bushings, why not put a new bar in there while I'm at it. At the same time if an FSB isn't going to give me much I'd just as soon not worry about it, especially if the install is difficult. I've read a few horror stories. Would springs help that much? The next track event I'll be doing is The Mitty at Road Atlanta.
 Old 12-10-2012, 08:01 PM   #8
2k4_8's Avatar
Groans: 64
Yes, springs would make a difference. I would just replace bushings on the fsb with some greasable urethanes and call it a day. If you get the konis look up that bump stop thread that was involving them on a gen1 so you can use the suspension and not the bump stops.
Something like konis and swifts would be a lot better than konis and a fsb. From my understanding tri point is the best rear bar for track use....and I have no clue on the axle situation.
 Old 12-10-2012, 08:16 PM   #9
Spec's Avatar
Posts: 4,472   (View Stats)
I've got the jbr Rsb, it's great. Has three different settings which would help for different set ups you'd like to run being just a track day or autox. You'll want the stiffer setting for high speed turns and probably the middle or the softer setting for autox. I'd also look into end links for the rears. Jbr comes with PU bushings for the Rsb.
The stiffer you make that front sway bar the more understeer you'll have making an autox a lil more tricky. From what I've personally found, I'd do bushings at the most.
I'd also suggest solid shifter mount bushings as well.
Your axels being shot, think of it this way … the lifetime warranty are remanufactured typically.
How long have your oems lasted?
Unless you have a lot of torn motor mounts and a tweaked frame, I'd go back with Oem. I've always had to replace those oreily types every year or two, with hard driving if coarse.
 Old 12-11-2012, 08:42 AM   #10
tddvrrn's Avatar
Groans: 103
replacing the FSB bushings is easy-ish. replacing the whole RSB requires dropping the subframe, which looks to be a motherfucking chore. i'd just do the greaseable pu bushings.. that is what i did and it stiffened things up a touch and stopped the clunk/squeak.
sounds like upgraded suspension is what you're after. there is a whole suspension thread somewhere, i'd read that, plus search. suspension options and their pros and cons have been discussed on here ad nauseum.
 Old 12-11-2012, 03:01 PM   #11
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Whiteline 27mm FSB
JBR RSB
Koni Yellow Shocks
Masterpro Axle
The following links might be helpful.
Bilstein shocks for the ms3
http://www.mazdaspeedforum.org/forum/foru...mp-stop-45695/
OEM toe issue.
http://www.mazdaspeedforum.org/forum/foru...-setups-39059/
Front sway bar bushings
The Official MS3 Suspension Thread
http://www.mazdaspeedforum.org/forum/foru...essions-64356/
kw coilovers + swaybars = new end links?
Time has come for some Coilovers
http://www.mazdaspeedforum.org/forum/foru...r-arms-108418/
MS3 Owner Alignment Databse
Coilover help
pixelNate likes this.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
2k4_8 (12-11-2012), pixelNate (02-03-2013), SLOWHATCH (12-11-2012), vivalawham (12-11-2012)
 Old 12-11-2012, 04:55 PM   #12
vivalawham's Avatar
Thanks for the links, Nliiitend, looks like I've got another few hours of reading haha.
tddvrrn - I don't really care that much about upgrading my suspension, basically I just want to fix what's currently wrong with it using parts that are slightly better than OEM (and hopefully cheaper). As much as I'd love to go KW V3 (I can afford it), I just can't justify the cost.
Half fail. Swaybars Scribbles MazdaSpeed 3/6 - Suspension & Brakes 18 04-04-2011 09:33 PM
kw coilovers + swaybars = new end links? stefan MazdaSpeed 3/6 - Suspension & Brakes 24 02-24-2011 10:48 AM
Page generated in 0.35688 seconds with 25 queries
