 Old 01-30-2020, 06:02 PM   #1
StopaOcean's Avatar
Posts: 14   (View Stats)
StopaOcean is on a distinguished road
Default What else to replace when doing shocks?
I'm going to be replacing my front struts with Koni Yellows. I'm a little unfamiliar with everything needed with this. After doing some research on the forums I saw that I should probably replace with the:
End links (Moog?)
Strut Mount (with this?)
Strut Bearing (with this?)
Bump Stop (OEM?)
I'll continue to do more research but does that sound correct? Should I replace anything else? Any recommendations for what to replace them with?
Thank you!
StopaOcean is offline   Reply With Quote
The Following User Says NO Thank You to StopaOcean For This Un-useful Post:
Db09ms3 (01-30-2020)
 Old 01-30-2020, 06:38 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
might as well do sway bar bushings and lube the brake guide pins.
94 M
MS6
IS350
 Old 01-30-2020, 06:49 PM   #3
StopaOcean's Avatar
Are there any bushings that you recommend?
 Old 01-30-2020, 08:22 PM   #4
Anaphra's Avatar
Location: Chico CA for school. Originally From the Bay Area
Posts: 34   (View Stats)
Anaphra will become famous soon enough
I'm not sure if the moog endlinks have been fixed yet but, FYI on their front endlinks
New Redesigned Moog front endlinks (K750073)
2009 CWP GT MS3
Damond Motorsports RMM PMM and TMM
Autotech HPFP
Cobb SF Intake
Cobb AP
Autotech HPFP
Corksport RSB+FSB
Corksport Adjustable Short Throw
Corksport Metal Skid Plate
Koni FSD
Anaphra is offline   Reply With Quote
 Old 01-31-2020, 08:42 AM   #5
StopaOcean's Avatar
Good to know, thank you
Your mods are pretty much exactly what I want to do with my car. Do you daily it?
 Old 02-01-2020, 11:02 AM   #6
Anaphra's Avatar
Ya I do daily it. Is there anything you want to know?
2009 CWP GT MS3
Autotech HPFP
Cobb SF Intake
Cobb AP
Autotech HPFP
Corksport RSB+FSB
Koni FSD
Putting in new rear shocks - replace mounts too? Roman-dude MazdaSpeed 3/6 - Suspension & Brakes 6 06-26-2016 04:42 PM
To replace or not to replace the throwout bearing that is the question? stockms3 MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-30-2014 07:29 AM
RX8 shocks dimka505 MazdaSpeed 3/6 - Suspension & Brakes 2 08-24-2012 09:59 AM
New shocks for 07 MS3 Peterspeed3 MazdaSpeed 3/6 - Suspension & Brakes 6 08-20-2012 01:41 PM
Page generated in 0.27903 seconds with 22 queries
