> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
 Old 01-22-2015, 04:03 PM   #1
vegaslightsss's Avatar
Posts: 8   (View Stats)
vegaslightsss is an unknown quantity at this point
Default 07 CX7 swirl valve questions
Just replaced head gasket,Throwing the P2006 swirl valve error. I need to see a pic of whatever pushes on the lever to actuate the unit. I never saw it as my son was working on it and said it was a plastic part that looked like a "teeter-totter", the part that has obviously operates the mechanism looks to me like it is broken off and just needs to be replaced,it has one connector and 2 screws and presses on the lever to open the runner valves. I cant find anything that looks like what he is describing. I really need a pic of whatever presses on the metal rod lever,or the part he says fits onto the lever . Also will this cause valve noise above 2k rpms if it is not working all? Thanks in advance. If the pic i tried to attach is in the post its the circle on the right area I am talking about.
What I am asking is if the silver component is just broken off and actually makes contact and depresses the lever,or if there is a plastic or any part that fits over the metal lever in the yellow circle i drew on the pic. Thank You
vegaslightsss is offline   Reply With Quote
 Old 01-22-2015, 06:30 PM   #2
So this is the piece that operates the metal lever in the first picture with the yellow circle around it. I need to know what the part it presses on is called and how it attaches to the lever so that it can function. A pic would be awesome. **CAN the car be driven at low RPMs without interference damage to the valvetrain? Right around 2200 RPM it sounds like it is starting to tick, having never seen the piece before it got broken,this is becoming a nightmare. Thanks Again in advance if anyone can help.
Intake Valve Cleaning using valve overlap and DI injection window shift Vansquish MazdaSpeed 3/6 - ECU Computer Tuning 33 05-06-2014 07:00 PM
Followup: Schumacher condition stable as rumors about his prospects swirl Haltech Automotive News 0 01-17-2014 05:10 PM
blow off valve questions jmcisneros MazdaSpeed 6 - How-To's 13 10-18-2012 06:56 AM
Rumormill: Unconfirmed next-generation Ford and GM truck powertrain details swirl Haltech Automotive News 0 07-29-2011 02:30 PM
Report: Rumors swirl about possible demise of USF1 team Haltech Automotive News 0 02-17-2010 10:00 AM
Page generated in 0.22994 seconds with 21 queries
