> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
 Old 11-11-2016, 04:43 AM   #1
Goscx7's Avatar
Posts: 6   (View Stats)
Goscx7 will become famous soon enoughGoscx7 will become famous soon enough
Talking Beginning to mod my cx7
Hey guys. I'm gonna go all out on my cx7 and to a proper build. Bit for the first one or two years I wont be touching the internals. Also where I live we have no dyno and only regular fuel, we can get high octane fuel by the barrels for real expensive. So I can only get it for racing. So yeah. I wanna start off small than go on to bigger mods. Where do I start from? Whay do you guys recommend? I wanna start off with a cobb downpipe and intake, egr and boost cutoff delete, get a new bov, and an electronic boost controller. And also I'm a boon at cars altogether. Always wanted to mod but now I got the chance. So any help and advice will be appreciated
Goscx7 is offline   Reply With Quote
The Following User Says Thank You to Goscx7 For This Useful Post:
Tomas (11-11-2016)
The Following User Says NO Thank You to Goscx7 For This Un-useful Post:
Vansquish (11-14-2016)
 Old 11-11-2016, 10:51 AM   #2
torquemaniac's Avatar
Posts: 733   (View Stats)
If you are serious about modding, you have to planify the build otherwise you will waste a lot of money
You will not get very far with the stock K04 turbo (even the Mazdaspeed3 K014 is a waste of time in my opinion)...I suggest you dont buy stuff that will only work with the stock K04, otherwise all that stuff will go in the garbage when you go with a better turbo
Best place to start is with the Versatuner tuning software...even with no mods, the software will give you some decent gain
After that, start reading and doing some research to find the kind of setup you want...
A lot can be done on this platform, it just take some ca$h and time
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
 Old 11-11-2016, 11:58 AM   #3
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Are you really in Fiji? Like in the motherfucking Blue Lagoon?
 Old 11-12-2016, 04:12 AM   #4
Goscx7's Avatar
I'm dead serious about modding my cx7 man, wanna be the fastest SUV in the quarter mile here. and the fastest time here is mid 14s. but i'd like to tap into the mid 15s first. I want to make the most out of what i spend. and i'd some advice from pros. I am planning to get versa tuner, but can you also recommend other mods which will work even if i do a turbo upgrade?
Yes brother i reside in the Fiji Islands. own 1 of only 2 CX7s in fiji, and there is only one other Mazdaspeed 3 here. so no support for modding here, but i love the engine too much to give up and go mod a more common Forester.
Last edited by Goscx7; 11-12-2016 at 04:12 AM. Reason: MSF Database - Automerged Doublepost
torquemaniac (11-13-2016)
 Old 11-12-2016, 06:43 PM   #5
Bob Ross Fanclub
Tomas's Avatar
Fuck bra there are more remote places but not many.
Welcome.
Been to Nadi once.
And some island hotel called Beach Cumber or something like that. Was backpacking. Unfortunately was not impressed. Sort of a tourist trap. That shit was over 20 years ago. Fuck I am old.
 Old 11-13-2016, 02:51 AM   #6
Ozynigma's Avatar
Posts: 743   (View Stats)
Hi and welcome.
Between torquemaniac and I you can find out pretty much all you need to know about CX7's. We both have build threads on this forum that you should read.
You need to run a minimum of 95RON or I think E10 fuel (around 94RON) here in the southern hemisphere. So what fuel can you buy from the pump?
The cheapest way to up your octane might be to add methanol either in the fuel tank (there is a whole thread on that here) or with methanol (or water/methanol) injection. I can get 20 litres of methanol for $50AU and I haven't even used my first 20 litres in about a year of driving with WMI.
You should figure out how far you want to go before you start. There are some easy drop in and bolt up options to replace the K04 and keep your stock exhaust manifold and Mazda flanges for the turbo and downpipe. However if you are going bigger than that you can just go straight to a V band manifold, downpipe and turbo.
There is not much point upgrading the intake unless you go a bigger than stock diameter like 3" or 3.5".
There is nothing much to be gained replacing the stock BOV at this point unless you want more noise by venting to atmosphere (needs to be tuned for with Versatune).
You can't mess with the boost control, its all done by the ECU. If you go a bigger turbo you can get a 3 port EBCS to replace the stock 2 port. Again it needs to be tuned for.
Oh yeah and you need the HPFP (High Pressure Fuel Pump) internals upgrade before you do much of anything else.
Last edited by Ozynigma; 11-13-2016 at 02:51 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Ozynigma For This Useful Post:
torquemaniac (11-13-2016), Vansquish (11-14-2016)
 Old 11-13-2016, 05:04 PM   #7
Goscx7's Avatar
Originally Posted by Ozynigma View Post
Hi and welcome.
So I should just forget about everything else for the moment and just get me a versatuner right? Just so that I atleast get access to my management system, because with all the ecu controlled sizzle in my csr it'LL need to be tuned
Oh and here in fiji we only get 91 octane here. No other
Last edited by Goscx7; 11-13-2016 at 05:04 PM. Reason: MSF Database - Automerged Doublepost
torquemaniac (11-14-2016)
 Old 11-13-2016, 05:16 PM   #8
Ozynigma's Avatar
Versatune is a very good start. It will let you get the most out of your existing turbo.
You will be very limited with tuning if you can only buy 91 octane fuel. i can't imagine your motor is too happy with 91 octane fuel and tropical weather.
Do you have a sticker on your car fuel cap telling you what fuels to use? In Australia it says minimum 95RON.
The Following User Says Thank You to Ozynigma For This Useful Post:
 Old 11-13-2016, 06:31 PM   #9
cardoc4u's Avatar
Posts: 46   (View Stats)
cardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud ofcardoc4u has much to be proud of
Use water injection
2012speedy3: cobb sri,tip, accessport, rmm, aem wmi, tbe(with meow),fuel pump innards,fmi
self-tuned @ 309whp/326tq
13.522 @105 mph
cardoc4u is offline   Reply With Quote
 Old 11-14-2016, 07:14 AM   #10
Dropen's Avatar
Dropen will become famous soon enoughDropen will become famous soon enough
I will start my tunne too in my CX-7 2008, i will buy versatuner this month with the group code discount and see whats happen with it =)
I will start with the intake first, i have installed one now but is not easy to access to the filter (is in front of the front wheel) and i dont know his dust status becase is hard to see it.
For intake i have 2 options:
1-. JBR Power Path Stage II Short Ram Intake [MS-PPI-S2] - $250.00 : James Barone Racing, Aftermarket Performance
2-. https://corksport.com/corksport-stag...e-for-cx7.html
In my country is 0 provability that E85 arrives (I've been listening since 2010 that would be available in the gas stations and nothing) so i dont know if i should to upgrade the HPFP yet, because my turbo works fine, so i dont need to change it... for now...
I really dont want it for speed, i want to spend less money in gas. Here we have 93, 95 and 97 Octane, i suppose that i have to use it with 97oct, but... hell is expensive (like 1,2USD/lt) so i use 95 (like 1USD/lt), i tryed to use it with 93 but the car doesnt feel right and i dont want to mess the internals.
Dropen is offline   Reply With Quote
 Old 11-14-2016, 08:11 AM   #11
I run 91 octane all the time in my car with no problem (even beforte I injected meth)...the max power of the engine will be limited though (versus with 93 or more octane)
The absolute basic mods are : Versatuner with the HPFP internals upgrade
Link to the HPFP internals upgrade : Autotech FSI High Pressure Fuel Pump Upgrade Kit
 Old 11-14-2016, 04:41 PM   #12
Ozynigma's Avatar
MON or RON? We use RON in Australia which has a higher number for the same knock resistance.
Same question for OP. You need to be sure your local fuel is up to the octane rating specified by Mazda for your model.
 Old 11-14-2016, 08:05 PM   #13
I have no idea if its RON or MON...its not specified
 Old 11-15-2016, 06:22 AM   #14
Goscx7's Avatar
Guys here in Fiji we use 91 octane to Australian standards. Like our 91 is America's 89(I guess)
 Old 11-15-2016, 11:25 AM   #15
frothy's Avatar
Posts: 1,067   (View Stats)
Canada uses the same AKI (Anti Knock Index) Octane Rating as the U.S., so it uses both RON and MON. The two numbers are added together and then divided by two to get the average.
If you look at the pump, you'll often see "(R+M)/2" listed above or below the octane rating number:
The Following 2 Users Say Thank You to frothy For This Useful Post:
Tomas (11-15-2016), torquemaniac (11-15-2016)
Timings 08 CWP MS3 Beginning Timing MazdaSpeed 3/6 - Build Diaries 17 05-04-2016 09:57 AM
I'm beginning to hate this car skiptowncat MazdaSpeed 3/6 - Troubleshoot/Diagnostics 56 11-27-2011 02:45 PM
Page generated in 0.36648 seconds with 26 queries
