> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
Like Tree8Likes
 Old 10-31-2019, 01:51 AM   #26
zidane10's Avatar
Posts: 1   (View Stats)
zidane10 is an unknown quantity at this point
Well, well...do we have an Alpha Romeo intruder on the Mazdaspeed site
I did reuse all my gasket, eventhough you suggested I change the little one...and everything is holding fine
1-2 shift lag is completely gone...but the shift is a bit harsh on very light throttle, but I rarely am in light throttle
Counterclockwise adjustment of the B1 adjuster is all that is necessary to eliminate the 1-2 upshift lag
C2 and C3 are to increase firmness of the other shift
I would like to play with the C1 adjuster (I can turn the adjuster without removing the cover because I made access holes), but I cant because the damn harness bracket is right in front of the C1 access hole...didnt see that when I put the cover on
C1 could improve launching from a stop (the Aisin 6-speed goes in ''neutral'' when idling in gear to improve fuel economy)
You dont need a bigger turbo to do this...it will make the shift faster and firmer
Hi Eric!
Can I talk to you personally?
Interested in the issue of setting up the AWTF-81 hydroplate.
Thank.
zidane10 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f123/cx-7-transmission-z-178708/
Project Q - Another modder's thread - Page 5 - Alfa Romeo Forum This thread Refback 04-14-2015 08:57 AM
Project Q - Another modder's thread - Page 2 - Alfa Romeo Forum This thread Refback 12-05-2014 12:26 AM
transmission Matx CX-7 > Engine, Transmission & Driveline 4 08-23-2011 11:13 AM
Page generated in 0.68315 seconds with 30 queries
