> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
Like Tree8Likes
 Old 06-05-2016, 11:55 AM   #41
scratchbuilt's Avatar
Posts: 19   (View Stats)
scratchbuilt has a spectacular aura aboutscratchbuilt has a spectacular aura about
I didn't notice a spring spec or part number for McMaster listed. Could someone please point me in the right direction?
Thanks!
scratchbuilt is offline   Reply With Quote
 Old 06-05-2016, 06:59 PM   #42
torquemaniac's Avatar
Posts: 733   (View Stats)
Thanks!
Unfortunately McMaster-Carr doesnt have the right spring...this is why I went with Century Spring!
I will post the specs later...
2011 CX-7 AWD 2.3 turbo
 Old 09-10-2016, 04:03 AM   #43
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
I need to read this. I want more than 320hp at the wheels
Project_dog is offline   Reply With Quote
 Old 11-27-2016, 03:22 PM   #44
As stated in post#35, the TCM will adapts to the change done on the valve body, and the quality of the shift will suffer
The only way around this issue is to make access holes on the valve body cover to easily re-adjust the clutch control valves with an hex key
At the request of @Project_dog; here are some pictures of the valve body cover with the access holes
I did not keep the measurements for the access holes positionning, so you will have to take the measurements (the best is to have the holes directly aligned with the clutch control valves, but some holes end up in some round part of the cover, so you will have to move the holes a bit to have a flat surface for the rivnut)
A part of the block also need to be cut to have access to the B1 clutch control valve with an hex key (see pictures)
In the last picture is shown the harness bracket that must be removed to gain access to the C1 clutch control valve
Here is the part list for the cover mod (McMaster-Carr part number):
- Rivnut 95105A135
- Stainless screw 97763A232
- Viton o-ring 9464K13
- Ribut install tool 96349A280
Attached is a PDF of the clutch control valves as a reference
The Following User Says Thank You to torquemaniac For This Useful Post:
Tomas (11-29-2016)
 Old 11-27-2016, 06:15 PM   #45
Thanks!
This is the spring I use form Century Spring : Compression Spring S-1129
This spring gives a +30% increase in pressure (I would have gone with a +40% spring, but I could not find a spring with the right specs...unless I shimmed the pressure regulator sleeve...this could affect the stroke of the valve so I opted to not go this route)
Attached is some note on the spring specs (OEM and upgrade)
Tomas (11-29-2016)
 Old 04-04-2018, 10:19 AM   #46
raydaddy's Avatar
Posts: 8   (View Stats)
raydaddy has a little shameless behaviour in the past
How hard is it to replace the valve body in cx7 trans?
Where is the pan located? Is it that vertically mounted bucket
Looking cover on the sida?
Is there a turorial anywhere with pics how to do it?
raydaddy is offline   Reply With Quote
 Old 04-04-2018, 05:52 PM   #47
Ozynigma's Avatar
Posts: 743   (View Stats)
Its the black vertical pan on the front. It's just awkward getting all the bolts out. I don't know of any tutorials. The workshop manuals can be found through the CX7 FAQ thread for reference.
 Old 04-04-2018, 06:34 PM   #48
raydaddy's Avatar
When i pull the valve body are there any springs or parts that may fall out i need to be aware of?
 Old 04-05-2018, 01:17 AM   #49
Ozynigma's Avatar
Yes I did have a piece fall out, I can't remember which one now, it was a couple of years ago. So be careful.
 Old 04-05-2018, 12:56 PM   #50
raydaddy's Avatar
Man i wish there was a write up with pics somewhere.
I have the manual ins. And im not afraid of the job
Just wish i had a bit more reference material
 Old 04-06-2018, 12:23 AM   #51
raydaddy's Avatar
Any idea on procedure to reset shift adapts?
 Old 04-08-2018, 01:06 PM   #52
raydaddy's Avatar
Ok got all prep work done and cover off
Doing swap next week
Not too bad so far
Anybody know what the best way to clean off the old RTV is? Is theree a solvent for that?
 Old 04-08-2018, 01:32 PM   #53
kTaLgsTo's Avatar
Posts: 566   (View Stats)
razor blade/starter fluid
Don't go gouging the case like a newb
 Old 04-08-2018, 05:33 PM   #54
Ozynigma's Avatar
Disconnect battery will reset ECU. It will relearn after that.
Not too bad so far
I use brake/parts cleaning spray solvent with a wire brush
Last edited by Ozynigma; 04-08-2018 at 05:33 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-19-2018, 05:09 PM   #55
The only way to reset the shift adapt is to go to a transmission shop...disconnecting the battery wont do it (the transmission is controlled by the TCM and not the ECU)
EvilMmotorsports likes this.
 Old 08-11-2018, 11:47 PM   #56
EvilMmotorsports's Avatar
Posts: 2   (View Stats)
EvilMmotorsports is an unknown quantity at this point
@torquemaniac
You're a pioneer in your ways!
I would love to chat with you personally about some of your findings. I am just in Onterrible.
I can't PM just yet, but you have been the sole reason for me joining MSF.
You can find me on IG if you were so inclined. Same username.
EvilMmotorsports is offline   Reply With Quote
 Old 10-31-2019, 01:51 AM   #57
zidane10's Avatar
Posts: 1   (View Stats)
zidane10 is an unknown quantity at this point
Well, well...do we have an Alpha Romeo intruder on the Mazdaspeed site
I did reuse all my gasket, eventhough you suggested I change the little one...and everything is holding fine
1-2 shift lag is completely gone...but the shift is a bit harsh on very light throttle, but I rarely am in light throttle
Counterclockwise adjustment of the B1 adjuster is all that is necessary to eliminate the 1-2 upshift lag
C2 and C3 are to increase firmness of the other shift
I would like to play with the C1 adjuster (I can turn the adjuster without removing the cover because I made access holes), but I cant because the damn harness bracket is right in front of the C1 access hole...didnt see that when I put the cover on
C1 could improve launching from a stop (the Aisin 6-speed goes in ''neutral'' when idling in gear to improve fuel economy)
You dont need a bigger turbo to do this...it will make the shift faster and firmer
Hi Eric!
Can I talk to you personally?
Interested in the issue of setting up the AWTF-81 hydroplate.
Thank.
zidane10 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f123/cx-7-transmission-z-178708/
Project Q - Another modder's thread - Page 5 - Alfa Romeo Forum This thread Refback 04-14-2015 08:57 AM
Project Q - Another modder's thread - Page 2 - Alfa Romeo Forum This thread Refback 12-05-2014 12:26 AM
transmission Matx CX-7 > Engine, Transmission & Driveline 4 08-23-2011 11:13 AM
Page generated in 0.36291 seconds with 28 queries
