| CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
(Thread Starter) | Not Ranked : 0 score After the pistons hit the oil squirters in my 3MPS back in 2016 after only 40k kms/25k miles on a freshly built forged engine, I ended up buying a new block, new OEM crank, and all the bits to put together another fresh engine. So at the end of the build I had the parts for an almost one more complete short block (I was missing a good crank), so I purchased a lot of other things: a new complete head including the fuel rail and injectors, an used crank within factory specs, including a full set of gaskets, and everything to build one more engine. Once I had all these parts I started researching on what could I put a 2.3DISi-fTw in... an RX8? A NC Miata? Well, no matter what path I wanted to go I was about to have the same problem, registering that custom car for street use. Also, it was going to be one more fast car, while I already have this 450-ish bhp 3MPS (3.91s for 60-100mph) and a 195PS Smart ForFour Brabus (this one is only chipped from 177PS to 195PS, and weights 1090kg/2400lb). So my wife asked me: - What else from Mazda comes from the factory with your beloved engine? - The CX7! - Well, we could really use such a thing with more ground clearance! - Done! Incoming WIN! So here I go: about 90k miles, 6 speed manual (this is how they come here, basically a 6MPS/Mazdaspeed6 with a bigger chariot on top), Shitty/Icy Blue, manufactured in 2008, first sold in 2010 after being a show room car for almost 2 years, with a lot of beans under the carpets (yes, beans!), all chassis elements except for the roof were repainted and they were still scratched when I got the car. Cylinders 1 to 3 had 170PSI compression and #4 had 180, spark plugs looked fine apart from the 1.2mm/0.048" gap they were worn to. It was pulling strong, there were no noises from the transmission, mechanically seemed well. The interior also had a few elements pretty banged up as well. Paid about $8500 for it back in February and ended up spending about 12k more until today. Is this a WIN or what?! So here is the Pig with pedals: Next day I ordered Versatuner and started making it smoother and more powerful. After a lot of work, parts, new tires, new wheels, new interior parts, about $200 spent for OEM clips and screws, I got it inspected and they said right away: transfer case and turbo. I never thought the TC (a common problem with the CX7s) was an issue as it didn't make any noises, and I knew about the turbo which was pushing very well but was spewing a bit of oil and/or coolant into the exhaust occasionally but I wanted to change it next year, not this year. But what is it that a teenager will not do for his project car?! So I started: 1. New properly waxed wheels and tires (CX5 2018 OEM rims with Michelin Latitude Sport 3 tires): 2. Took the old StreetUnit TMIC from the Cow (the 3MPS) and fitted it to the Pig. The Cow got a new CP-e TMIC (no difference in flow, only in the looks): 3. New exhaust tips (old versus new): 4. New OEM in-tank fuel filter and Autotech HPFP internals replaced these: 5. ...Man... these beans... 6. Re-leathered steering wheel, new OEM shift knob: 7. Finally, new GTX2867R gen2, with a TIH mocked up from an old CP-e TIH for the GT/GTX30 turbos (4" turbos): 8. New TC at the same time with the GTX: The ATP kit was for a 3MPS/Speed3, so the supplied oil return line did not fit, we had to bend the OEM line. Also, I made a mistake not purchasing the Kozmic oil feed line for the MS6, the OEM line was a bitch to bend to the right shape. But we got it in the end. 8. Last mod this weekend, TheSpeedLine strut tower brace. And I'm not done yet. At this point I have the stock intake and stock exhaust. This turbo struggles a bit to make 22PSI with these factory parts but I'm not going to any track days with the Pig so the stress on the turbo will be only on acceleration reprises just to humiliate Porsche Cayenne/Macan / Audi Q5/Q7 / BMW X5/X6 / Mercedes GLC/GLE dick heads and some of the hot hatch owners around which sometimes think the roads are not meant for chinese shitboxes (of course it's japanese, but what do they know?!).
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI Last edited by mituc; 08-13-2018 at 12:15 AM. |
| The Following 8 Users Say Thank You to mituc For This Useful Post: | AveryPlaysBass (08-06-2018), Db09ms3 (08-06-2018), Jeff23spl (09-14-2018), KiwiFlavor (09-14-2018), lildisco (08-11-2018), Thor Hammer (08-06-2018), Tomas (09-13-2018), torquemaniac (09-01-2018) |
Groans: 211
| Not Ranked : 0 score Nice work!
| The Following User Says Thank You to Thor Hammer For This Useful Post: | mituc (08-07-2018) |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Finally the grand master decided to make a built CX-7 ![]() Let me know if you want some RMM insert to stiffen the engine a bit (I made a mold of the old Corksport insert, and can cast some in silicone...for free)
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| The Following User Says Thank You to torquemaniac For This Useful Post: | mituc (09-01-2018) |
Groans: 111
These inserts are perfect for such a car as I don't want to go full retard on the rear diff mount and other mounts, exhaust, or anything that could affect the way it sounds (inside) now. I'll PM you right now, thank you!
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| The Following User Says Thank You to mituc For This Useful Post: | torquemaniac (09-28-2018) |
| Not Ranked : 0 score Fuck! Manual DISI CX-7! So those go for around 8.5$ in gypsyland huh? Do you know if the manual transmission is identical to the MS6? By the way I do not believe the rear carrier on the AWD CX-7 is the same as the MS6. IIRC it is an open diff type as opposed to the LSD found on the MS6. Could be a nice upgrade. Especially if you do a lot of snow driving and tow hand reading gypsy women in velvet lined wagons. Also if you can get a MS6 steering wheel. It's a direct fit on the CX-7 and much nicer. Oh and sorry bruh but why the fuck would you spend 12k on upgrades and then go and use CX-5 OEM wheels? Not only are they not especially good looking, some may even argue worst looking than the stock CX-7 wheels, but they are probably still a wimpey 7.5" wide. If you want to keep an OEM look use stock CX-9 wheels. The Australian dude used them and they look pretty good. They are just 19" but its not that small of an aspect ratio with stock circumference tires.
__________________ Last edited by Tomas; 09-14-2018 at 04:48 AM. |
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
Groans: 111
(Thread Starter) | Not Ranked : 0 score You can find them between 5500EUR and even 11k EUR, so that is about 6500$ and 13k$. The engine and transmission is identical between the 3 2.3DISI-T powered models (CX7, 3MPS and 6MPS). the CX7 and 6MPS are very similar though, I think the only things that differ are the axles and driveshaft, and it's only the length of them, not even the number of splines. In the rear they indeed have an open diff just like the CX9.
Here it is, in case you want one: https://www.ebay.com/itm/Steering-Wh...d=323357356115
The rules are so stupid that you can get your car registration revoked if you put 205/55/r17 or 215/50/r17 wheels on a Mazda 3 2013+ which only has 205/60/r16 and 215/45/r18 listed in the registration/homologation papers. Yet there's absolutely no problem for them if you change the stock rims with others with a 40mm smaller offset as long as you keep the original tyre and rim sizes. Also this pig is supposed to serve practical purposes, so the 18" wheels with these fat tires are absolutely perfect. After adding that tower strut brace the car corners just as good if not better than my Smart ForFour Brabus, which is supposed to be a mini-compact hot-hatch build for this specific purpose. So for me these 18" wheels are perfect, and it happened to be the OEM CX3/CX5 wheels because I found them new for about $600 a set when the wifey likes this polished aluminium + black paint combination in the rims fascia quite a lot. Right now the car is sitting in a parking lot for about 10 days now because it threw a P0202 error and the power of 3 cylinders is absolutely horrific. But I'll fix that eventually. Looks like the previous owner took the car to some butchers for doing the timing kit and the engine loom sat on the engine. So it's pretty cooked and brittle and I'll have to find there the injector #2 wire is pinched or cut.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | ||
| The Following 2 Users Say Thank You to mituc For This Useful Post: | Tomas (09-14-2018), torquemaniac (09-28-2018) |
| Not Ranked : 0 score Fuck yeah thanks for confirming the transmission thing. The steering wheel controls are completely adaptable from the MS6 to the CX7.
__________________ |
| The Following User Says Thank You to Tomas For This Useful Post: | torquemaniac (09-28-2018) |
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
| The Following 3 Users Say Thank You to Jeff23spl For This Useful Post: |
| First Romanian BT MS3 | mituc | MazdaSpeed 3/6 - Big Turbo Builds | 141 | 09-04-2019 02:23 PM |
| Romanian driver literally flies through roundabout | Haltech | Automotive News | 0 | 05-23-2016 12:00 PM |
| Video: Romanian gas is like a troupe of French maids for your engine | Haltech | Automotive News | 0 | 07-13-2012 11:10 AM |
| Video: Romanian criminals attempt to loot a moving truck | Haltech | Automotive News | 1 | 06-14-2012 11:53 AM |
| Next in line to get irked by Jeremy Clarkson? The Romanian government [w/VIDEO] | Haltech | Automotive News | 0 | 11-24-2009 06:00 PM |
