> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
Like Tree4Likes
 Old 03-10-2011, 01:10 PM   #1
ro-bi's Avatar
Posts: 138   (View Stats)
ro-bi is a splendid one to beholdro-bi is a splendid one to beholdro-bi is a splendid one to beholdro-bi is a splendid one to beholdro-bi is a splendid one to beholdro-bi is a splendid one to beholdro-bi is a splendid one to behold
Default my cx-7 tuning step buy step
I decided to open thread about tuning of my car.
I will make updates after all changes.
Car is 2008 y. with 85.000 km.
Until now I make new intake, maf housing, install new air filter, blow off is new.
Pump internals are changed (by myself- parts from PTP), today I removed balance shaft.
All pictures will follow.
About feelings:
- maf housing, filter and intake make big plus in power. Most benefits are 4000 rpm and up.
- pump internals are working like stock, no difference here (stock ecu soft)
- balance shaft, well, difference is bigger like I was thinking before from reading on forums. It is like switch from 6 to 4 cyl. engine. Engine revs better, pulls better from 5k up, but small vibration in same freq. like exhaust sound are here. Engine runs "harder", like I say, 4 cyl now, 6 before. Nothing to worry I thing, but I can feel them.
I also change oil and filter- EXELIA 5W-30. Without BS 7l of oil inside
ro-bi is offline   Reply With Quote
The Following User Says Thank You to ro-bi For This Useful Post:
dimkatz (09-30-2011)
Step by Step Brake Job from Grassroots Motorsports FUB4R3D MazdaSpeed 3 - How-To's 36 06-14-2014 03:08 PM
2-Step? D08SPEED3 MazdaSpeed 6 - Engine, Transmission & Driveline 4 05-11-2010 12:26 PM
Cut It Out: Toyota's recalled pedal modification remedy detailed step-by-step Haltech Automotive News 0 12-18-2009 12:10 PM
Page generated in 0.58182 seconds with 28 queries
