> CX-7 > Engine, Transmission & Driveline
 Old 02-08-2009, 12:25 AM   #1
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Hectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the world
Groaned at 9 Times in 6 Posts
Default Corksport motor mount inserts INSTALLED!
Well I finally got around to installing the Corksport MM inserts in my wife's CX7.
Install: I am bad at rating difficulty, but let's just say no busted knuckles during install.
Fairly straight forward. Remove the underpanel by taking out the (8) 10mm bolts per the instructions. Remove the 17mm bolts holding the mount to the bracket. Definitely loosen the (2) 19mm bolts holding the braket to the engine. This helps a lot with the removal (and installion) of the motor mount. You also need to use pry bar/big screwdriver to remove the mount from the rear part of the bracket. It takes a little time, but it will come out.
Once the mount is out you just need to press the inserts into the absences in the rubber of the mount. I used my hands, but you may have to use some kind of clamping tool (per the instructions). Once pressed in, I used a rubber mallet to make sure they were all the way in.
Then I loosely bolted the front of the mount in. Pushed the rear in slightly then used the rubber mallet to persuade it in. Lined the holes up using an old screwdriver and screwed the rear bolt in. Tightened everything up (don't forget about the 19mm bolts holding the bracket). Reinstalled the underpanel.
Driving impressions:
There is a definite increase in vibrations. Not dogbone in a MS3 harsh, but a lot different from the stock "cushiness" Driving around normal it isn't harsh, you notice a little more smoothness than with the stock mount. Once you get on it though, it goes through gears with less hesitation with more response. Only drove it around my neighborhood, but personally it is more of a blast to drive.
Anyone with a CX7 with plans to mod it, or just wants more of a sporty feel should check out this mod. For $35 you can't go wrong.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Hectik1 For This Useful Post:
kingpin748 (02-08-2009), Superstretch18 (02-08-2009)
 Old 02-08-2009, 06:13 AM   #2
Superstretch18's Avatar
Posts: 318   (View Stats)
Superstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond repute
Agreed. In about a month, the vibes should be nearly gone. The vibes are worse with the A/C on, but you have a few months before you have to worry about that and by then, they should be worn in...
Old - 2007 CX-7 Sport FWD
New - 2010 WRX Hatch
Originally Posted by martyxattack View Post
who has the most care? me 0 care.
Superstretch18 is offline   Reply With Quote
 Old 02-08-2009, 10:10 AM   #3
The Angry Goose
Hectik1's Avatar
I don't mind the vibes....personally I don't want them to go away. We will see what the wife thinks.
Hector
2014 Mazda 3
1979 Mazda Rx7
 Old 02-08-2009, 01:11 PM   #4
MZRDISI4's Avatar
Posts: 1,430   (View Stats)
MZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the world
Groans: 94
Groaned at 38 Times in 19 Posts
I think they're just a tad too thick, and that's why they vibe so much. I'm making adjustments to mine.
"We already have the Speed6 replacement" "It's just called the CX-7 now"
back at http://www.mcx7.com bitches, spam free
MZRDISI4 is offline   Reply With Quote
 Old 02-11-2009, 12:03 PM   #5
buttons's Avatar
Posts: 142   (View Stats)
buttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to behold
Groaned at 20 Times in 4 Posts
I am really curious what a CX-7 with intake, tbe, and a tune would run the quarter mile at. :-)
2006 White Mazdaspeed 6 Sport - Sold
2007 Blue Mazdaspeed 3 GT - Sold
2006 Red Mazdaspeed 6 GT - I/TIH/SU TMIC/3 port BC/Springs/Wheels
buttons is offline   Reply With Quote
 Old 02-11-2009, 12:10 PM   #6
~ mid 14's with a good tune and an ETS...
 Old 02-11-2009, 07:25 PM   #7
The Angry Goose
Hectik1's Avatar
The only bad part of the equation is the automatic trans.
Hector
2014 Mazda 3
1979 Mazda Rx7
 Old 12-01-2010, 05:20 PM   #8
GWSwipe's Avatar
Posts: 6   (View Stats)
GWSwipe is an unknown quantity at this point
Which stiffness did you go with?
http://swipelife.com/
GWSwipe is offline   Reply With Quote
 Old 12-02-2010, 10:44 PM   #9
The Angry Goose
Hectik1's Avatar
The stiffest. Vibrates the same as my MS3 with the TRZ trans/motor mount combo. Makes a big difference in power delivery.
Hector
2014 Mazda 3
1979 Mazda Rx7
The Following User Says Thank You to Hectik1 For This Useful Post:
CorkSport (12-16-2010)
 Old 05-08-2013, 02:39 PM   #10
Mrzoomzoom's Avatar
Posts: 220   (View Stats)
Mrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond reputeMrzoomzoom has a reputation beyond repute
when you purchase the mounts you only need 2 correct. i mean when you purchase them they come with 2?
Mrzoomzoom is offline   Reply With Quote
 Old 05-10-2013, 01:38 PM   #11
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
One of my friends has a 2007 CX7 and wants to stiffen the rear motor mount a bit. I recommended him these inserts since I also have them and had not so pleasant experiences with aftermarket urethane and rubber RMMs, but I was wondering if there's any reliable RMM on the market (apart from those from unSURE).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 05-10-2013, 01:41 PM   #12
The CS inserts are good stuff for CX-7.
mituc (05-11-2013)
Corksport MM inserts: Now Available for the CX-7 MZRDISI4 CX-7 > Engine, Transmission & Driveline 13 11-19-2010 09:00 AM
Trans/drivers side motor mount installed (production unit). ptperformance Mazdaspeed3/6 General Discussion 2 12-03-2008 07:45 PM
Intake and MM inserts installed - now a beliver vegas79 MazdaSpeed 3 - Engine, Transmission & Driveline 14 11-22-2008 12:33 PM
Page generated in 0.31072 seconds with 27 queries
