> CX-7 > Engine, Transmission & Driveline
 Old 09-04-2018, 12:25 PM   #1
sfcarbone's Avatar
Posts: 2   (View Stats)
sfcarbone is an unknown quantity at this point
Default Engine differences??
Yes, I have not made posts on the forum. Yes, I have spent plenty of time searching but I still have a question that I cannot seem to find an answer to.
I am looking to buy a 2010 CX-7 that has a blown engine. Unless I'm mistaken, that is considered a Gen-2 engine. I am considering buying a crashed, but low mile Mazdaspeed 3 for the motor. That one is a Gen-1 for sure.
I've seen conflicting information on this forum. Some say that the engines are the same, Mazdaspeed 3, 6 and CX-7 (except the turbo of course). Internally, they seem to have different combustion shapes, so pistons are different. I get that, but it should make no difference in doing a swap. But on several posts, I've seen people mention that to move a Gen 2 to a Gen 1 car, the powersteering pump and upper wiring must be changed. That makes no sense if the block and head are the same.
As I'm looking to put a Gen 1 into a Gen 2, what do I need to look out for? I plan to take it down the the block and move all manifolds and valve cover over to the fresh engine. What am I missing?
sfcarbone is offline   Reply With Quote
 Old 09-04-2018, 12:46 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Gen 1 vs Gen 2 piston and rod differences
Gen 2 Ms3 Engine Swap into a Gen 1 Ms3
any differences between K04's? btstarcher MazdaSpeed 3/6 - Turbo Induction 5 04-09-2013 04:52 PM
Engine Block Differences silvapain MazdaSpeed 3 - Engine, Transmission & Driveline 7 05-09-2012 07:27 PM
2009 ECU Differences? ms3blackmica MazdaSpeed 3/6 - ECU Computer Tuning 7 05-02-2012 01:24 PM
Gen 1 - Gen 2 differences? steedspeed 2010 MS3 - Turbo Induction 15 11-05-2010 08:44 AM
engine mount differences between NA 3 and MS3 builthatch MazdaSpeed 3 - Engine, Transmission & Driveline 0 07-31-2008 12:52 PM
Page generated in 0.23309 seconds with 21 queries
