> CX-7 > Engine, Transmission & Driveline
  • 1 Post By Raider
 Old 06-24-2014, 11:05 PM   #1
hahaitzskippy's Avatar
Posts: 51   (View Stats)
hahaitzskippy has a spectacular aura abouthahaitzskippy has a spectacular aura abouthahaitzskippy has a spectacular aura about
Default I hate the serpentine belt
my belt was squealing so i got a new belt installed by the shop.
after driving it for about 1000 miles, i notice the squeal is back but only when the engine is hot... shop diagnosed it as me needing a new tensioner and idle pulley.
i bought a tensioner and figured i give it a go at installing. so i thought it was going to be an easy and quick job. well it wasnt.
taking off the belt was suppose to be easy right? it wasnt. but i eventually got it off with the help of a 2nd pair of hands.
then got the new tensioner in and tightened but i cannot get the belt back on. that SOB is really difficult to push back against... i mean it is called a "tensioner" for a reason.
i finally gave up, nothing was going to work. the tensioner was giving me no slack what so ever.
the older tensioner doesnt give me any slack either?!?! ARGH (ranting here)
but FYI, squealing from the belts even when the belt is nice and tight means your idle pulley and/or tensioner is going out. those 2 pulleys wiggle which cause the squealing
looks like i gotta tow this car to the shop tomorrow.
anyone have any tips on how to put the belt back on before i tow it to the shop?
hahaitzskippy is offline   Reply With Quote
 Old 06-24-2014, 11:26 PM   #2
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
try to slip it on the idler pulley (or was it the waterpump, i forget its been awhile, well the one with no ribs). It has no ribs so it will be the easiest to slip the belt on. It is a two man job unless you got the arm power to release that tensioner all the way and slip it on.
release/hold the tension while the other guy uses some muscle to slip it on. If tensioner is not fully released because your arm is giving out, stop rest and do it again. Once its on, your golden, even if it is not on completely. Just release a little tension and push in from there after.
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 06-24-2014, 11:30 PM   #3
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
First: LOL
Second: man handle that on, feed the belt through everything and then put the tensioner on. If you can't get it that way try the pulley up front and the top of the engine. Remove the top 2 10mm(I think) bolts and loosen the bottom one. Use it as a leverage and hulk your way through. Search this site for a how to remove intake manifold, it explains that process and has pics. Might be for clean valves too, don't remember.
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
 Old 06-25-2014, 07:15 AM   #4
Monforte88's Avatar
Posts: 324   (View Stats)
Monforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the world
I feed the belt around maxed out the tensioner and had another pair of hands put it on the ps pulley.
Sent from my P.O.S iPhone!!!
2007 mazdaspeed 3. SRI\ TIP\ Forge v2\ Auto Tech HPFP\Ebat Catless DP\ Test Pipe\ CP-e Cat back\ 88a RMM \ Shift Plate\ JBR Short throw shifter\ solid shifter bushings\ #Bakerytuned 18PSI.
Monforte88 is offline   Reply With Quote
 Old 06-25-2014, 08:14 AM   #5
ya but how did you guys even move the tensioner? i cannot move mine by hand
i bought the goodoyear gatorback tensioner. that thing is tighter than... (insert imagination).
it gives me zero slack...
 Old 06-25-2014, 11:59 AM   #6
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
Try putting a socket and breaker bar on the pulley bolt and pull. This should give you lots of leverage.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
The Following User Says Thank You to nekret For This Useful Post:
taf0422 (06-28-2014)
 Old 06-26-2014, 11:25 AM   #7
cocoanton's Avatar
Posts: 168   (View Stats)
cocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the world
What he said. You are supposed to use a 14mm socket on the pulley bolt, pull as to tighten it and the tensioner will give you slack! If you could move your old one by hand it must have been totally dead!
cocoanton is offline   Reply With Quote
 Old 06-26-2014, 09:32 PM   #8
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
@Tedspeed6; maybe can chime in. He does his MS6 belt alone. I did mine but really struggled with it
Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM
Mandinca is offline   Reply With Quote
 Old 06-27-2014, 06:33 AM   #9
Takes a 14mm wrench to loosen the tensioner. I have done this on my CX-7 and it was tight tight. Had to use a long wrench to break it free.
Tedspeed6 likes this.
 Old 06-27-2014, 07:41 PM   #10
Tedspeed6's Avatar
Posts: 1,801   (View Stats)
Tedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the worldTedspeed6 is the leader of the world
A serpentine belt tool would make it fairly easy. I managed to use an extra long 14mm wrench from a Harbor Freight set and was able to get it on tensioner and move it enough to get the belt back on. The wrench set is cheap and prob $15-20
Black Cherry 06 MS6
New factory long block, gt2871r, JBR 3.5" intake and trilogy mounts, autotech internals, M2 DP with eBay cat, magnaflow CBE, vtcs delete IM
Awaiting install Cx piping with tr8 core, Cobb 3 port and JBR OCC
Tedspeed6 is offline   Reply With Quote
 Old 06-28-2014, 03:50 AM   #11
torquemaniac's Avatar
Posts: 733   (View Stats)
Ratchet on the tensioner pulley (turn clockwise) to release it to the max...second pair of hand put the belt around the powerstearing pulley...easy as 1-2-3
Couples caffein pills will give the required strength...
2011 CX-7 AWD 2.3 turbo
 Old 11-02-2019, 08:23 PM   #12
AngryOrchard99's Avatar
Posts: 8   (View Stats)
AngryOrchard99 is an unknown quantity at this point
How do you tighten the belt back on
AngryOrchard99 is offline   Reply With Quote
 Old 11-02-2019, 08:29 PM   #13
Police - Grammarhead
Vansquish's Avatar
Once you release the tensioner, the tensioner should take up any slack in the belt. As I mentioned in response to your other post, to loosen the tensioner, I believe you have to rotate it clockwise, not counterclockwise.
AngryOrchard99 (11-02-2019)
« Rod Knock | - »
Serpentine Belt Zeya MazdaSpeed 3 - Engine, Transmission & Driveline 8 05-24-2016 12:09 PM
serpentine belt Project_dog CX-7 > Engine, Transmission & Driveline 3 04-24-2014 09:37 AM
Routing the serpentine belt Spectrum24x Mazdaspeed3/6 General Discussion 4 10-08-2012 06:20 PM
Serpentine belt 07Speed3007 MazdaSpeed 3 - How-To's 19 02-12-2011 08:01 PM
08 MS3 Serpentine belt question?? gamma500 MazdaSpeed 3 - Engine, Transmission & Driveline 8 01-09-2011 06:49 PM
Page generated in 0.33808 seconds with 31 queries
