> CX-7 > Engine, Transmission & Driveline
  • 1 Post By phate
 Old 02-08-2016, 05:48 PM   #1
jaguar_mike's Avatar
Posts: 18   (View Stats)
jaguar_mike has a little shameless behaviour in the past
Default VALVE CLEARANCE ADJUSTMENT
Hi, Does the VIP Membership has Specs, manual, ?
Is there is a chart or page that shows all the numbers, stamps on tapper, size of tappet on one?
I've been to two Mazda dealers and they only can give me the part number for the new tappet to order. When I have worked on Nissan in the past I could get a list that had around three columns. they were part order number, number on tappet, and tappet thickness, all in sequence.
Does someone have a list like this or a better system, or one to go by to figure out the tappet clearance I need to order for the head?
The car is a 2007 Mazda cx-7 2.3L Turbo
One service place said that they don't replace heads and only replace the whole engine, and so their Werner manual does not cover valve adjustment. I asked that it should be in the manual just in case. They said no and wouldn't check.
jaguar_mike is offline   Reply With Quote
 Old 02-08-2016, 06:02 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
You need to measure what you have and order whatever size you need to get the lash into spec. The engine build manual only has the lash specs, no part numbers. Go here for part #'s.
OEM MS6 engine part numbers
Go here for specs if you don't need the rest of the manual.
Valve Tappet Clearance Excel Spreadsheet
Dolfius likes this.
-06 MS6
-Corn fed 07 MS3 - Sold
TiGraySpeed6 (02-08-2016)
Valve Tappet Clearance Excel Spreadsheet silvapain MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-11-2018 01:32 PM
Intake Valve Cleaning using valve overlap and DI injection window shift Vansquish MazdaSpeed 3/6 - ECU Computer Tuning 33 05-06-2014 07:00 PM
oil return line & valve adjustment. thebestdj07 Mazdaspeed3/6 General Discussion 0 02-14-2014 11:13 PM
Head Rebuild and Valve clearance issues tkephart MazdaSpeed 6 - Engine, Transmission & Driveline 14 10-05-2012 12:46 PM
Page generated in 0.24175 seconds with 21 queries
