> CX-7 > Car Audio & Electronics
 Old 03-13-2014, 04:50 AM   #1
73mercedes's Avatar
Posts: 2   (View Stats)
73mercedes is an unknown quantity at this point
Default CX7 turbo won't start security light flashing
My first post folks. Hope you can help. The key goes in,turns,dash lights up but no ignition. Security light started flashing. We tried jumping it,no good.I then disconnected the battery trying to cancel out what ever caused this,no good. Towed it to a local shop for the weekend. Monday morning the car starts for the shop. No dash lights flashing. So we take her home only to have her not start again the next day. Any ideas before I tow her to the dealer? Thanks
73mercedes is offline   Reply With Quote
 Old 03-13-2014, 05:21 AM   #2
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Um I had a similar issue like this in my speed. I ended up replacing the ECU as it went bad.
Here is the thread with suggestions:
Security light on and car wont start
Best of luck.
 Old 03-13-2014, 05:38 AM   #3
spdtrux's Avatar
Posts: 481   (View Stats)
Groaned at 9 Times in 6 Posts
This shit happened to me a few times (normally 60miles after I flashed a tune) but then went away
Not sure why or how. Cobb said it was probly my ECU going bad.
99 JEEP WRANGLER SPORT
 Old 03-13-2014, 05:51 AM   #4
maisonvi's Avatar
Groans: 75
Yeah, my car didnt start two or 3 times, but then eventually did. Then one day, just gave up the ghost. I ended up getting a used ecu and a friendly deal to re-flash it for me.
 Old 03-13-2014, 05:56 AM   #5
spdtrux's Avatar
I was able to pop start when the problem happened so I was never left stranded. But I do ha a lil dent in the hatch from my palm..
Push push now quick run to the driver seat and pop zoom zoom. Shoulda seen the look on peoples faces!
 Old 03-13-2014, 06:07 AM   #6
73mercedes's Avatar
Thank you Maisonvi and Spdtrux, I did read that thread Maisonvi. I need the car,unfortunately, so I think it's off to the dealer with it. Sure hope it's not the ecu. Wish I could pop it Spdtrux. But it's not a wise thing to do at my age,and I think the automatic tranny wouldn't like it to much either. Thanks any,73
 Old 03-13-2014, 06:52 AM   #7
maisonvi's Avatar
Groans: 75
Yeah I had a rough 2 weeks bumming rides while it was down, so I feel your pain there.
 Old 03-13-2014, 06:56 AM   #8
We had that with out CX-7 GT/ If keyless, check this out.
Got the smart key setup, and having issues with them "freaking out" click here!
 Old 05-21-2014, 01:09 PM   #9
hahaitzskippy's Avatar
Posts: 51   (View Stats)
hahaitzskippy has a spectacular aura abouthahaitzskippy has a spectacular aura abouthahaitzskippy has a spectacular aura about
a few things i would do 1st before going all crazy... (sorry if you already tried these steps but ill restate them just in case)
1) replace batteries in keyless remote
2) try starting the car using the detachable key removed from the keyless remote
3) make sure the keyless remote is not touch or interfering with any other electroincs (if put right on an iPhone, the car cannot sense the keyless remote. this happens all the time for me)
note: it is recommended to turn the key from off > acc > on > start then directly to OFF before restarting. sometimes, the ECU needs to do a soft reset in order to enable the starter.
i believe if all this fails, then resort to plan B... FREAK OUT! jk look at other possible issues. ie: ecu replacement/reflash etc
hahaitzskippy is offline   Reply With Quote
Security light on and car wont start maisonvi Mazdaspeed3/6 General Discussion 75 12-31-2017 01:07 AM
4wd light flashing Karmat MazdaSpeed 3/6 - Troubleshoot/Diagnostics 40 06-27-2017 09:45 AM
Security Light Flashing Question KoreanNightmare Gen2 MS3 General Discussion 4 02-08-2015 09:19 AM
Flashing Oil Light Mazdazilla6 Mazdaspeed3/6 General Discussion 70 10-17-2012 06:55 PM
Security light flashing p057 Mazdaspeed3/6 General Discussion 2 03-24-2012 07:55 AM
Page generated in 0.28700 seconds with 24 queries
