> CX-7 > Car Audio & Electronics
 Old 02-19-2014, 02:25 PM   #1
gobalak6's Avatar
Posts: 1   (View Stats)
gobalak6 is an unknown quantity at this point
Default Factory Amp wiring
Hi All. Hoping someone can help me here. I did want to say that I have tried to search for wiring diagrams and other information before posting this thread. The situation is that I inherited a 2007 CX-7 with the 9 speaker bose system. The factory headunit was replaced with an aftermarket unit, followed by an equalizer, and then 2 amps and a sub. I have since replaced the head unit with a factory 6 disc and resotred all the wiring in the dash that was cut up.
Out behind the seat, the wires to all the speakers were cut and spliced into the new amp. Many of you will know that many of the wires are of the same color. What I am struggling with is reconnecting the factory speaker wired to the factory harness going into the amp. Being that many of the wires are the same color, I am not sure which is which although I have tried several combinations. Does anyone have the pin and wire color diagram for the bose 9 speaker amp? And as i mentioned, when I tried couple of possible combinations, i did not hear any audio. i see that the 12v to the amp is present. Anyone know if one of those wires to the amp is a "amp turn on" lead? Any info on the wiring to the amp will be helpful. Thanks in advance.
gobalak6 is offline   Reply With Quote
Am I doing it right/Wiring this kit Stangcobra MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 9 10-09-2012 02:04 PM
sub wiring Caldwell MazdaSpeed 3/6 - Car Audio & Electronics 2 09-18-2011 05:58 PM
GenPu's factory fuel cut factory tune psi (relative pressure) WRX_Fan_0717 2010 MS3 - ECU Computer Tuning 1 03-09-2011 11:14 PM
Wiring in AP! NJSPEED3 MazdaSpeed 3 - How-To's 9 11-18-2009 08:55 PM
Wiring schematic for factory alarm Jarods7920 MazdaSpeed 3/6 - Car Audio & Electronics 0 12-04-2008 08:51 PM
Page generated in 0.21851 seconds with 20 queries
