![]() Join Date: Oct 2015 Location: Seattle Area
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score So I have a 2007 CX-7 with the factory nav and Bose system. It's not working (doesn't load CD's and Nav doesn't turn on). I'm basically looking at having to, at a minimum replace the head unit with one from eBay and price starts at $300 for a used head unit with Nav screen. Did some research to find out what it would take to upgrade to a navigation ready CD/DVD player that has Bluetooth and a lot of other features and came up with an affordable solution. First off, if you want to retain your SWC Steering Wheel Controls, you'll need a unit called PAC RP4-MZ11. They can be had on eBay for about $90-100 USD. This will cover Bose and non-Bose systems with steering wheel control and all of the Bose issues everyone asks about due to different Ohms, etc... No need to get the unit I'll mention below. Pac RP4 MZ11 Mazda Aftermarket Stereo Radio Replacement Wiring Interface SWC | eBay If you just want the Bose conversion and don't care about the SWC's, just get PAC MAZATO for about $45-50 USD. Also on eBay. Pac Mazato Bose Car Stereo Radio Replacement Interface Installation Harness | eBay So that leaves the Navigation / Radio unit to get. I found the Power Acoustik PDN-626b unit to have good reviews and be easy on the budget. You'll want to get a dash kit from Scosche MA1533B or whatever brand you find that fits your CX-7. Link is for no-name brand. Radio Stereo Single ISO Double DIN Installation Install Dash Kit Wire Harness | eBay That's all. Just thought if someone was in the same boat I am that it would be nice to have all of the relevant info on 1 thread. You should be able to use ANY double DIN radio with the above mentioned adapters. No need to worry about specific "compatibility" with Bose. Hope this helps. I'm able to piece together a complete system and junk the factory one for $261.00 if I do it myself. Not bad... |
| Systems and Set ups | nuttzzy | 2010 MS3 - Car Audio & Electronics | 204 | 05-05-2015 09:48 AM |
| Will a non bose 6 disk mechanism fit a bose head unit? | fasteddie128 | MazdaSpeed 3/6 - Car Audio & Electronics | 1 | 12-11-2014 08:41 PM |
| Official: Bose noise cancelling now available for cars without Bose stereos | Haltech | Automotive News | 0 | 12-22-2013 07:10 AM |
| BOSE AMP WIRING INFO HERE... | ganderson | 2010 MS3 - Car Audio & Electronics | 20 | 11-18-2013 11:30 AM |
| 2008.5 Headunit TSB Bose and none Bose | FastAttack | MazdaSpeed 3/6 - Car Audio & Electronics | 2 | 07-15-2008 12:51 PM |
