> CX-7 > Wheels, Tires, Brakes & Suspension
 Old 01-26-2014, 08:35 AM   #1
cxfan77's Avatar
Posts: 21   (View Stats)
cxfan77 is on a distinguished road
Default constant groaning and squeaking from rear brakes
Carmax has lubed the sliders and brackets earlier this month and yet its doing it again. Has this been an issue with these vehicles and is better to just go with aftermarket parts?
cxfan77 is offline   Reply With Quote
 Old 02-19-2014, 02:13 PM   #2
Diehonda's Avatar
Posts: 11   (View Stats)
Diehonda is on a distinguished road
Will be installing centric pads this weekend. The brakes should have the touch points lubed, caliper guide pins lubed, and springs properly mounted. Not sure if these have springs, but my last four Mazdas did. If the caliper guide pins have dirt on them the grease won't help.
Have you gotten in there and check it out?
Diehonda is offline   Reply With Quote
 Old 02-19-2014, 09:36 PM   #3
cxfan77's Avatar
No I haven't carmax did the tech disassembled the passenger rear brake cleaned it up and relubed the pins and contact points it did fine for like 3 weeks.
 Old 02-21-2014, 02:28 PM   #4
Diehonda's Avatar
I would recommend checking it out yourself. It may not have been lubed properly or you may have another issue. Make sure the contact points on the pads are greased.
Is it a constant squeal or rhythmic like a warped rotor? Just throwing out ideas as there aren't enough parts in a rear brake set up to not be able to pinpoint the culprit.
It will take longer to get it up and the wheel off than to diagnose.
 Old 02-22-2014, 12:04 AM   #5
cxfan77's Avatar
Yeah im going to take care of it myself I was a toyota tech for a couple of years so im experienced with brakes. I feel its more of a caliper hang up issue than the contact points tap the brake a couple of times it usually stops.
Squeaking Brakes at 13,000 miles nicholous28 2010 MS3 - Suspension & Brakes 10 01-14-2014 06:22 PM
rear brakes smoking 98zjdave 2010 MS3 - Troubleshoot/Diagnostics 4 06-11-2013 07:38 AM
Rear shocks squeaking loud! aanguia1 2010 MS3 - Troubleshoot/Diagnostics 11 11-27-2011 05:38 PM
Squeaking rear over small bumps in cold weather VFR800 MazdaSpeed 3/6 - Suspension & Brakes 7 01-31-2011 02:36 PM
do any MS3 rear brakes look like this?? ElBartoRex MazdaSpeed 3/6 - Suspension & Brakes 7 02-25-2010 01:54 PM
Page generated in 0.24621 seconds with 21 queries
