> CX-7 > Wheels, Tires, Brakes & Suspension
 Old 09-20-2017, 03:12 PM   #1
Dannzig's Avatar
Posts: 11   (View Stats)
Dannzig has a spectacular aura aboutDannzig has a spectacular aura about
Default CX-7 Brakes
Hi All!
I have a 2008 CX-7 that is going to need brakes soon. I get a vibration at Freeway speeds and when braking. My Question is 2 part.
Part 1 - Best Brake Pad Brand for my CX-7
Part 2 - Resurface or Replace Rotors?
Thanks Guys!
Dannzig is offline   Reply With Quote
 Old 09-22-2017, 12:16 AM   #2
tomek CX7's Avatar
tomek CX7 will become famous soon enoughtomek CX7 will become famous soon enough
The workshop manual says
1. Measure the thickness of the disc plate.
• If the thickness is not within the specification, replace the disc plate.
Minimum front disc plate thickness
26 mm {1.03 in}
Minimum front disc plate thickness after machining using a brake lathe on-vehicle
26.8 mm {1.06 in}
If you have vibrations the replacement is the best option. ATE set works good in my car for almost 2 years / 30kkm
tomek CX7 is offline   Reply With Quote
 Old 09-25-2017, 04:59 PM   #3
lildisco's Avatar
Posts: 332   (View Stats)
lildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond repute
Never had an issue with Centric Blank Rotors & Hawk HP Pads. I've had that combo on my CX7 for a few years. Only complaint is brake dust, but that's to be expected with the pads i have, but i'll take it over better stopping power
Sent from my XT1710-02 using Tapatalk
Cooper Red Mica 2008 CX7 AWD GT w/Nav
K&N Drop In, Stock Air Box Mod, HKS BOV, Silver Star Turn Signals, LED Fog Lights, Xtec Hi-Beam Lights, Tinted Tail Lights, ETS TMIC, CS Boost Pipes, RX8 Wheels wrapped wtih Yokohama AVID ENVigors
Originally Posted by TopGear Magazine
This is a good car, a fine family SUV that will serve you well, if unremarkably. It's on sale from 18 May, and its arrival signals the phasing out of the larger CX-7, like the 2 supermini, one of Mazda's underrated, underappreciated cars. Let's hope the CX-5 avoids the same fate. It deserves to.
Tuned with
lildisco is offline   Reply With Quote
 Old 01-04-2018, 06:44 AM   #4
Bstrom's Avatar
Posts: 8   (View Stats)
Bstrom is an unknown quantity at this point
My brakes were replaced by the dealer before I bought it, so OEM parts are good. Braking is strong and steady.
Bstrom | Powell, TN
2011 CX-7 | 1995 Miata | 2003 Tundra | 1999 4Runner Limited
Bstrom is offline   Reply With Quote
New Brakes Soon EvoFire MazdaSpeed 3/6 - Suspension & Brakes 10 01-01-2014 12:14 PM
OEM MS3 brakes = Volvo S60 brakes? levitron MSF KB - Mazdaspeed 3/6 - Suspension & Brakes 110 09-19-2012 01:42 PM
OEM MS3 brakes = Volvo S60 brakes? levitron MazdaSpeed 3/6 - Suspension & Brakes 109 03-02-2012 06:14 PM
2009 MS3 brakes vs. 2010 MS3 brakes Driver72 2010 MS3 - Suspension & Brakes 11 11-21-2009 10:34 AM
Page generated in 0.24029 seconds with 23 queries
