> CX-7 > Wheels, Tires, Brakes & Suspension
 Old 10-27-2012, 03:59 PM   #1
ryandlor's Avatar
Posts: 126   (View Stats)
ryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant future
Default FRONT PADS n ROTORS 50,000km
So 50,000km on my 2009, had some shimmy when braking so went with new pads up front. Got Wagner's semi-high performance. Both fronts were less than half thickness, and wearing unevenly.
Anyhoo, slapped the brakes together, and with new pads the shimmy was even worse so I knew the rotors were gone too.
Odd since they had been machined once already, (stealership around 30,000km) and now at 50,000km they were gonzo.
Got a set of premium rotors for $95 each for NAPA, no slotted or drilled. Im surprised at how easy the replacment was. Only bitch was the 2 Rotor set screws. No idea why we even have them.
So stripped the f outta 1 on each side, so had to get one of those drill/bore tools and it worked in 10 seconmds..screws came out great. Also used a crazy amount of liquid fire release to loosen those screws (not sure if thats the proper name). Put the rotors on, greased up calipers and new pads and voila....no shimmy. Great braking, sturdy stops. We'll see how the wear in goes.
Anyway point of this thread was to point out that the front pads and rotors are easy as shit to do on our 7's...mind you the rears i didnt touch.
Only thing i noticed was the OEM pads had two shims, a metal and a second shim which was so deteriorated i tossed them.
2009 CX-7
Platinum Silver Metallic
AWD
ryandlor is offline   Reply With Quote
 Old 08-01-2015, 08:53 AM   #2
jayhawk's Avatar
Posts: 1   (View Stats)
jayhawk is an unknown quantity at this point
Default Minn Newby
Verry interesting...looking at the Napa brakes too. Not sure what best replacements are.
jayhawk is offline   Reply With Quote
 Old 08-10-2015, 11:11 PM   #3
cxfan77's Avatar
Posts: 21   (View Stats)
cxfan77 is on a distinguished road
I puchased the Akebono pads for both front and rear and replaced all my rotors I've noticed that my braking improved with these pads over the ones that carmax had slapped on before I purchased my 7
cxfan77 is offline   Reply With Quote
 Old 08-10-2015, 11:46 PM   #4
[R]usty's Avatar
Posts: 2,204   (View Stats)
2010 Mazdaspeed3 w/tech
 Old 08-11-2015, 12:06 AM   #5
cxfan77's Avatar
What's the problem rusty
Need to replace pads and rotors aviator79 CX-7 > Wheels, Tires, Brakes & Suspension 12 07-24-2012 03:16 PM
rotors with new pads huffentuff09 Mazdaspeed3/6 General Discussion 3 06-11-2012 12:07 AM
Needin' new rotors & pads . . . speed6_in_calgary MazdaSpeed 3/6 - Suspension & Brakes 14 04-18-2010 10:58 AM
Centric rotors/pads speed6frk MazdaSpeed 3/6 - Suspension & Brakes 11 02-19-2009 07:58 PM
Page generated in 0.25704 seconds with 23 queries
