(Thread Starter) | Not Ranked : 0 score OK so you wanna remove your door panel? Here's how! First, simply remove the door handle cover, to remove the cover you will need to stick a flat head screw driver in the bottom of the cover like this *Don't forget to take off the upper black trim on the other side of the mirror.* Makes it a lot easier. Then after that you have two screws, the tunnels are long and the screws are not small so make sure you have a nice longish screw driver. After those two you only have two more to go. One is behind the door pull, hidden behind the cover, in order to get behind the cover you will need a flat head screw driver. Then, unscrew! After that you have one in the little pocket in the door, behind the felt stuff, just remove that and unscrew. Go to the side of the door, and pull right where I am, and pull out and up, you might have some fasteners left on the door, and that can be a pain, just use that same flat head to pop them out and back on to the door panel. Then, pop out the door pull after you have the panel off of the door, and the one window switch harness and you're done! The same applies for the rest of the doors, the driver side door has 3 harnesses hooking into it and the rest should have one. |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score This door doesnt resemble mine at all. I got a 2009 Base AWD. Anyone have diff write up? Trying to get some new speakers in.
__________________ 2009 CX-7 Platinum Silver Metallic AWD |
![]() Join Date: Nov 2010 Location: Cape Coral, FL
Rep Power: 120 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Thanks Raider. You made a difficult job look easy. Looks exactly like my 2007. |
(Thread Starter) | Not Ranked : 0 score Mazoom posted it. Ryandlor, post pics of yours! |
| Not Ranked : 0 score Heres ya go. Im dumbfounded, I dont want to pay BestBuy $100 to install my speakers.
(Thread Starter) | Not Ranked : 0 score Looks the same to me, only the one mazoom posted was the passenger door. |
![]() Join Date: Oct 2015
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I was asking about the lower rear door panel. Any ideas? |
| Rotor Removal | FantasmoNegro | MazdaSpeed 3/6 - Suspension & Brakes | 20 | 11-10-2013 02:28 PM |
| MS6 ECU removal | kore2000 | MazdaSpeed 3/6 - ECU Computer Tuning | 14 | 01-27-2010 03:19 PM |
| Removal of pill | phantom3 | MazdaSpeed 3/6 - Turbo Induction | 3 | 10-22-2009 12:02 AM |
| Door Trim Removal MS6... | Driverman5777 | MazdaSpeed 3/6 - Appearance | 3 | 02-13-2009 12:24 AM |
