> CX-7 > How-To's
 Old 09-02-2012, 06:57 PM   #1
mazda12's Avatar
Posts: 1   (View Stats)
mazda12 is an unknown quantity at this point
Default How do you adjust rear emergency brake
CX-7 has 56k miles on it and the emergency brake light keep poping on and off. Some times I would drive it and notice the light come on. some times when I start it the light is on? Does the rear brakes have different pads then the rear emergency brakes??
mazda12 is offline   Reply With Quote
 Old 09-02-2012, 11:30 PM   #2
lildisco's Avatar
Posts: 332   (View Stats)
lildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond repute
Check your pads, might be do for a change. The light is prolly going & off due to the amount of brake fluid in your resavoir. If that's low, then check all 4 corners for pad wear & more than likely, you'll need new brakes.
Cooper Red Mica 2008 CX7 AWD GT w/Nav
K&N Drop In, Stock Air Box Mod, HKS BOV, Silver Star Turn Signals, LED Fog Lights, Xtec Hi-Beam Lights, Tinted Tail Lights, ETS TMIC, CS Boost Pipes, RX8 Wheels wrapped wtih Yokohama AVID ENVigors
Originally Posted by TopGear Magazine
This is a good car, a fine family SUV that will serve you well, if unremarkably. It's on sale from 18 May, and its arrival signals the phasing out of the larger CX-7, like the 2 supermini, one of Mazda's underrated, underappreciated cars. Let's hope the CX-5 avoids the same fate. It deserves to.
Tuned with
lildisco is offline   Reply With Quote
 Old 09-04-2012, 01:22 PM   #3
RiceBurn2.3T's Avatar
Posts: 74   (View Stats)
RiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to behold
The e brake uses separate pads from the regular rear brake pads. It actually has shoes on the inside/hub of the rear rotors. Last I checked, they are pretty expensive too. Was going to change mine till they gave me the price...Something like $100 ish.
RiceBurn2.3T is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f128/how-do-you-adjust-rear-emergency-brake-123508/
How do you adjust rear emergency brake - Mazdaspeed Forums This thread Refback 09-19-2015 03:53 AM
How to adjust handbrake on mazda cx 7 - 1Q5A This thread Refback 08-10-2014 09:17 AM
How to adjust e-brake???? MS6FL MazdaSpeed 6 - How-To's 10 05-30-2015 11:56 AM
SU CF Emergency Brake Install neotide87 MazdaSpeed 3 - How-To's 26 06-30-2011 09:14 PM
KW V1 - Can you adjust the rear with the spring in? surfwagon MazdaSpeed 3/6 - Suspension & Brakes 2 01-24-2011 12:44 PM
Emergency Brake Rattle....grrr kgb MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 10-15-2009 10:09 AM
Page generated in 0.23868 seconds with 22 queries
