| MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here. |
![]() Join Date: Mar 2019
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Illumination it pretty crappy at night. |
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score m6customs.com
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
Groans: 211
| Not Ranked : 0 score TRS HID Kit Pros
![]() Join Date: Nov 2012
Rep Power: 99 ![]() Thanks: 1
| Not Ranked : 0 score https://www.theretrofitsource.com/ has some
__________________ Back to Stock |
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) | |
![]() Join Date: Nov 2014 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score To be fair, one cant assume everyone knows what TRS means. It really should've been given with a link of some sort like the second person did.
__________________ 2008 Metro Gray Mica Speed 3-SOLD Corksport SRI Corksport TIP JBR 80 duro RMM Cobb AP v3 Autotech internals CX Racing FMIC SPC rear camber arms Hawk HPS pads front and rear FREEKTUNE OTS+ 1998 Civic - SOLD2011 Speed3 200k+ miles Stock -Daily |
| Not Ranked : 0 score First rule of MSF Club: help yourself by searching.
| The Following 2 Users Say Thank You to Fstrnyou For This Useful Post: | Db09ms3 (03-25-2019), monkey.bones.007 (03-25-2019) |
![]() Join Date: Sep 2018 Location: Naples,FL
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score |
Groans: 211
Maybe I could be really nice and let him know that MS6 customs recommends a different morimoto lens than what TRS (oops, THE RETROFIT SOURC) uses in their kit. Do I get your approval and blessing now? LOL. OP, if you want to retain your stock D2S bulbs then you can install a set of Morimoto 4TL-R lenses. MS6 Customs makes the brackets to install into your housings. Or you can send him your headlights. I went with these and bought the brackets from him. https://hidkitpros.com/shop/bi-xenon...-r-projectors/ Seriously.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
![]() Join Date: Dec 2017 Location: NYC/ Long island
Rep Power: 32 ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score If You're comfortable, you can actually open them and swap out the stock projector with something better performing. Theretrofitsource.com has everything you need. |
| Repacing OEM halogen headlights with OEM HID headlights | noidle22 | Mazdaspeed3/6 General Discussion | 9 | 06-15-2017 05:05 PM |
| MS6 headlights are WAY too low | Absolut1l | MazdaSpeed 3/6 - Car Audio & Electronics | 11 | 05-08-2014 09:16 PM |
| HID Headlights | Afejzic | Exterior | 7 | 03-28-2014 08:57 PM |
| LED Headlights? | Mclovin80 | Gen2 MS3 General Discussion | 8 | 09-19-2012 06:33 AM |
