> MazdaSpeed 3/6 - Car Audio & Electronics
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
 Old 02-19-2011, 04:39 PM   #1
dealerjohn1's Avatar
Posts: 268   (View Stats)
dealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the world
Default component speakers
anyone done component speakers in the front and also rear of the speed3? I am curious about the sound imaging and clarity if anyone can chime in I would appreciate it
dealerjohn1 is offline   Reply With Quote
 Old 02-20-2011, 03:07 AM   #2
jv92red's Avatar
Posts: 319   (View Stats)
jv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the world
Putting separates in the back will pull your sound stage out from in front of you to the middle of the car. In general you'll want your sound stage out as far forward the center of your dash as possible.
jv92red is offline   Reply With Quote
The Following User Says Thank You to jv92red For This Useful Post:
dealerjohn1 (02-20-2011)
 Old 02-20-2011, 03:33 AM   #3
thanks man I appreciate it
 Old 02-22-2011, 10:49 PM   #4
also what im thinking of doing is adding a sound processor to the factory system ( I dont want to get the caska just yet) so I can upgrade the factory speakers and adding dynamat as well as a 10 inch sub so im curious if the processor will combat the imaging problem that you mentioned let me know any other thoughts you might have
 Old 02-25-2011, 07:25 PM   #5
6262ms3's Avatar
Posts: 103   (View Stats)
6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute
Just make sure your processor has some decent eq adjustability. I noticed these cars have a ton of resonance in the 200hz range, even after deadening the doors. I ended up cutting a good -5db at 200hz which cleaned the mud out of my components (h-audio ebony mids/polk ring radiator tweets running active). For the rear speakers I wouldn't bother with tweeters at all, just bandpass some decent midranges. I turn my rear speakers off completely (it's easy to do on my deck) unless I have passengers in the back.
'07 MS3. Cosmic Blue, CPE 60-duro rmm, Cobb Accessport, Corksport sri, Corksport tmic, TWM shifter base bushings, JBR adjustable short shift plate, Koni FSD-4045 Struts, RX-8 Rims.
6262ms3 is offline   Reply With Quote
 Old 02-25-2011, 11:03 PM   #6
jv92red's Avatar
Depends on how deep into tuning you want to go with the time to do it. From reading your posts it's hard to gauge your experience level. Processing can be a can of worms people open then find out it's much more than they realized. Proper imaging, clarity and what sounds good to you are so subjective that you can spend alot of money and mostly alot of time tuning and you may never get it right.
Question to ask yourself is: What do you want to get out of processing? How many channels will it need to control? Are you going 2 way active or will run passive front components? Do you need electronic crossover and slope control? Time alignment? How many bands of EQ do you want? EQ graphic or parametric? And most importantly: do you understand what all of that stuff means?
If so then you can shop for a processesor that meets your requirements then just run some RCA's off the line level outs from your head unit (assuming BOSE clean signal from HU - search this forum for more info on that)then tie in your processor then run your amps,speakers and you're set to start tuning.
If you've never adjusted a crossover frequency or slope, don't know what the difference is between a graphic and parametric EQ, or how to adjust EQ phase and Q width within a parametric EQ then I would suggest checking out a car audio forum and doing your homework before you start. I recommend checking out diymobileaudio.com While there are some knowledgeable people on this forum, this is a car performance site first and foremost, not a car audio forum.
Do you need to know all that for your system to sound good? Not necessarily. Just depends on how much processing you want to be able to do since you'll learn more as you go along so maybe buying a more capable processor now with your initial installation will give you what you need to dive in and learn on the fly. But buy a product packed with features and not use them and you'll be wasting your money compared to a unit which does just what you need.
We all start from the bottom - hell my first car when I was 16 had a 1/2 din 5 band graphic eq with a "Power booster - 500 watts" on board amp with 6x9's in the back that I thought was the shit! But when I was 16 these interwebz didn't exist so lot of info out there to learn. Good luck!
The Following 2 Users Say Thank You to jv92red For This Useful Post:
dealerjohn1 (03-17-2011), mroclimbr (03-17-2011)
 Old 03-17-2011, 03:14 PM   #7
thanks a lot...I do have a friend who is a professional car audio installer so im sure he can help me out a bit with all of the technical stuff but I do have pretty good ears so ill definitely be curious to find out what I end up with at the conclusion of this build
SPEAKERS M$3ChoquiM$3 MazdaSpeed 3/6 - Car Audio & Electronics 2 02-07-2011 03:40 AM
Top dash speakers angelkalel CX-7 > General Lounge + New Member Welcome 1 01-28-2011 12:41 PM
Grounded: HondaJet delayed again due to component delays Haltech Automotive News 0 05-18-2010 06:50 AM
Intel opens online component shop Haltech Computers & Technology News 0 04-14-2008 04:34 AM
JVC Mini Component Audio System $79.54 Haltech Hot Deals Section 0 03-29-2008 11:50 AM
Page generated in 0.27261 seconds with 22 queries
