| MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here. |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
(Thread Starter) | Not Ranked : 0 score 2007 Mazda3 MAZDASPEED3 - Connector/Ground Point Locations -- Engine Compartment I haven't found this on the boards yet and if it is already, someone needs to sticky it. I cannot seem to find a directory, so unfortunately for the time-being you have to click "next" to progress to each page..but this thing is a life saver. Currently working out some electrical issues myself and this has come in real handy.
__________________ |
| The Following 12 Users Say Thank You to helmetface For This Useful Post: | BigBoostMS3 (01-23-2013), breakfstincluded (12-23-2012), Design (03-16-2013), exentix (09-23-2012), Koke382 (01-06-2013), meicalnissyen (09-20-2012), rfinkle2 (03-13-2013), Rokusek (10-16-2012), smoogs12 (10-26-2012), snailD (09-20-2012), TiGraySpeed6 (09-20-2012), TWOptSL0W (03-13-2013) |
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score yup, thats a sticky for true
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
![]() Join Date: Mar 2012 Location: Houston
Rep Power: 1355 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,163
Groaned at 56 Times in 11 Posts
| Not Ranked : 0 score thank you!
__________________ 2007 Mazda Mazdaspeed 3 -- Black Mica ¤Rear Cat Delete¤HTP 3" full Intake¤Grimmspeed EBCS¤KMD Internals¤Cobb Accessport (tune in progress)¤ JBR 88 Duro RMM¤Sure Torq S3 Passenger Mount¤SU Billet TMM¤ ¤JBR Solid Shifter Bushings¤CPE Tow Plate¤JBR Rear Sway Bar¤ Status: Comatose |
| The Following User Says Thank You to simply_pandora For This Useful Post: | trekkie1031 (11-17-2013) |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score I'm having issues locating one of the grounds near the passenger side headlight on the front harness. I can only see the ground that's under the brake fluid reservoir. Does anyone know where the 2nd one is? At first I thought it might be referring to the ground attached to the PMM, but that's not connected to the front harness at all, just back to the chassis.
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score I have the full Mazdaspeed 6 electrical wiring manual if it would be of any help. |
![]() Join Date: Mar 2012 Location: raleigh, nc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score I have the full Mazdaspeed 6 electrical wiring manual if it would be of any help. I would appreciate some wiring help with my bose subwoofer. I'm replacing it with a boss sub. I don't need a n amp and want to know how to tape into the stock wiring. |
| The Following User Says Thank You to adman98 For This Useful Post: | simply_pandora (12-17-2013) |
![]() Join Date: Jan 2014 Location: Tampa Florida Area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
| Not Ranked : 0 score | |
| Electrical Issue | MazdaSpeedster | Mazdaspeed3/6 General Discussion | 13 | 02-25-2012 11:41 AM |
| Yet another electrical problem | MazdaSpeedster | Mazdaspeed3/6 General Discussion | 2 | 01-29-2012 05:56 PM |
| No electrical power... Anywhere. | BlueStreak | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 19 | 07-15-2011 08:18 AM |
