| MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here. |
![]() Join Date: May 2013 Location: Killeen, TX
Rep Power: 0 ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score I have a 2008 Mazdaspeed 3 with no Bose and no Nav. I need to find where the illumination wire is located in the stock harness so i can tap into it. Can someone please help me out, i have my car apart in my driveway and this is the last piece of the puzzle. Thanks.........
__________________ Bone Stock |
![]() Join Date: Sep 2012 Location: Columbus, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 939
Groaned at 25 Times in 15 Posts
| Not Ranked : 0 score If I'm not mistaken I believe it's orange. I'm not sure though. That's how it's been on my last three cars. Google wiring diagram for our cars. |
(Thread Starter) | Not Ranked : 0 score i can't seem to find any answers on it. I thought i was 1g in the pin, but there is no wire even in that section. Can anyone point me in the right direction? any know the color?
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score Depends what you illumination wire you mean, the interior illumination wire? Also do you want it to be dimmed with the use of the dimmer dial on the left? What are you installing that needs it?
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
| The Following User Says Thank You to theurgy For This Useful Post: | Honorary Title (05-18-2013) |
Hi "theurgy", thanks for being so exact with your questions. I am installing a stereo into my car and i want the unit to dim when the headlights come on. i accidentally wired into the dimmer switch and need to get the right wire this time. Any help is appreciated. i have a 2008 mazdaspeed 3 with no Bose and no Nav.
__________________ Bone Stock | |
| Not Ranked : 0 score This page might be useful for you: http://d5102.wikispaces.com/Mazda+3+Stereo+Harness
![]() Join Date: Feb 2010 Location: Oakley, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 633
| Not Ranked : 0 score What harness are you using, mated to what stereo? When I wired mine up, everything on the aftermarket harness and stereo harness pretty much lined up perfectly, no need to hunt down wires. Oh, and the more helpful answer could be "I'm pretty sure it was orange, maybe with a white or silver stripe." Last edited by Fozzy; 05-18-2013 at 07:38 PM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score Yeah, are you using one of those OEM adapter harnesses? Make sure you use one of those and not cutting the stock harness off.
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score Can you not use an add a circuit to the fuse box?
__________________ it's fun to do bad things |
| Not Ranked : 0 score He shouldn't need to use an add a fuse. If he's wiring his stereo the right way, using a harness, he shouldn't have to tap anything. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f13/illumination-wire-please-help-145479/ | ||||
| MazdaSpeed Forums - Number One Mazda Enthusiast Tech Site | This thread | Refback | 05-19-2013 03:24 AM | |
| Backup wire and speed sensor wire? | Fozzy | MazdaSpeed 3/6 - Car Audio & Electronics | 4 | 06-01-2013 05:43 AM |
| Light Mine Pro is naval warfare-inspired underhood illumination | Haltech | Automotive News | 1 | 01-02-2012 09:10 AM |
| aux wire | Port90 | Gen2 MS3 General Discussion | 7 | 04-05-2011 04:26 PM |
| Prosport Gage Illumination | Stan-O | MazdaSpeed 3/6 - Car Audio & Electronics | 22 | 08-01-2010 07:34 PM |
| Amp wire Run?? | Katfish6913 | MazdaSpeed 3/6 - Car Audio & Electronics | 6 | 05-13-2009 07:55 PM |
