| MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here. |
![]() Join Date: Mar 2008 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 116
__________________ 2012 G37S; 7 speed paddle shifters 2007 Mazdaspeed3 GT; Hypertech Tuned, MS CAI, ETS 3" TMIC, Catless CorkSport Down-Pipe, Catted Corksport Mid-Pipe, Corksport Cat-Back Exhaust, Forge II BPV, Cobb front and rear sway bars, KW V1 Coilovers, JBR Shifter Plate, TWM STS/Bushing, SU Rear Mount, GROM ipod link, Sub/Amp added to Bose - Sold 1995 Nissan 300ZX Twin Turbo; SRI - ASHSPEC ECU - MBC @ 14psi - Turbo-Back Exhaust - Larger Intercoolers - RPS Street Sport Clutch - RPS Flywheel - Megan Springs - Subframe Spacers - 51,000 original miles - Thrill Ride and Sold |
| The Following 2 Users Say Thank You to surfwagon For This Useful Post: | DiGi Faggot (07-16-2012), flappypaddles (12-02-2013) |
![]() Join Date: Mar 2008 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score what kind of sub did you get?
__________________ 2008 Black Mica MS3--Corksport DP, Turbo XS Racepipe, Custom 3inch Catback, Cobb SRI, Turbosmart Mbc @ 18psi, ATP BCD, Prosport Boost Gauge, Dashhawk, 6000k HID's, 5% tint Stock Dyno: 227hp/241tq Dyno w/ Cobb SRI/Corksport DP/TXS RP/MBC @ 18psi- 279hp/315tq |
![]() Join Date: Mar 2008 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 914
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score I would like to know too. Also, did you have to run any new wires or anything like that? Is it still under the passenger side seat? or what |
(Thread Starter) | Not Ranked : 0 score I bought Sony XS-LB10S Shallow-mount sealed truck enclosure with one 10" subwoofer at Crutchfield.com and Sony XM-1S Slim Series mono subwoofer amplifier 500 watts RMS x 1 at 2 ohms at Crutchfield.com I bought them somewhere else for a lot cheaper. Crutchfield was selling this combo as a package so I knew it would work well. I also bought a cheap amp wiring kit like this (the lower the gauge for the wire, the better (10 gauge) Here we go: First figure out where you're putting the amp (mine fits in the grove box) and the sub in the hatch. Unplug negative battery terminal Run your power wire from the battery through the grommet for the hood release and to the amp. Unbolt driver's seat and tip it back and out of the way See the wiring harness for the Bose amp below The plug with 4 wires is where you tap into to get the music signal. Gently pull this plug out of the amp. Don't mess with the red or black. The other two wires (white with blue stripe and gray) you will tap and run wires from those to the high level input on your amp. (If you purchase an amp with a high level input, you won't need to buy a LOC) The high level input offers a less distorted signal too. In order for the amp to know to power on/off when the car is turned on/off you need to tap into the "remote signal" you find this on the the wiring harness with the blue plastic tabs. Start by gently pulling this harness out of the amp. There is a series of wires in the top half of the harness and another series on the bottom of the harness. You are looking for the solid blue wire on the bottom half of the harness. Tap into this and run it to your amp. Now run your speaker wire to your sub. I'm pretty sure that's it. If you have any other questions or if anything was too vague let me know. - Marc
__________________ 2012 G37S; 7 speed paddle shifters 2007 Mazdaspeed3 GT; Hypertech Tuned, MS CAI, ETS 3" TMIC, Catless CorkSport Down-Pipe, Catted Corksport Mid-Pipe, Corksport Cat-Back Exhaust, Forge II BPV, Cobb front and rear sway bars, KW V1 Coilovers, JBR Shifter Plate, TWM STS/Bushing, SU Rear Mount, GROM ipod link, Sub/Amp added to Bose - Sold 1995 Nissan 300ZX Twin Turbo; SRI - ASHSPEC ECU - MBC @ 14psi - Turbo-Back Exhaust - Larger Intercoolers - RPS Street Sport Clutch - RPS Flywheel - Megan Springs - Subframe Spacers - 51,000 original miles - Thrill Ride and Sold Last edited by Haltech; 03-30-2008 at 08:23 AM. Reason: fixed img tags |
| The Following 13 Users Say Thank You to surfwagon For This Useful Post: | AlsChopShop (01-04-2014), AndyMS3 (06-26-2009), Eazy (04-01-2008), erod550 (09-16-2009), flappypaddles (12-02-2013), got.zoomzoom (04-11-2012), Haltech (03-30-2008), helmetface (07-11-2012), Jmuch (06-11-2011), mouse0330 (08-29-2009), mroclimbr (03-15-2011), nickpratt (11-02-2013), qwerty4550 (07-17-2008) |
![]() Join Date: Apr 2008
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Sweet!! Im doing this tonight or tommorrow! Thanks for the details. |
(Thread Starter) | Not Ranked : 0 score Let me know if you need help with anything. It sounds fucking amazing.
| Not Ranked : 0 score I did this on Sunday, it sound 10X better than the stock subwoofer. It really feels alot more balanced. I really had to play around with the sound settings on the amp and on the radio to get it clean and not to bassy. Now its sounding great! Thanks for the instructions! |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score Been considering this for a couple days. was thinking about going with the Kenwood KSC-SW1 or the Sony to save trunk space. You have pics of it in your trunk? |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score Where'd you buy your stuff Surf? I need to grab a sub and amp but not sure of a reputable place outside of Crutchfield for car audio really. |
(Thread Starter) | Not Ranked : 0 score I bought the sub and amp off of eBay. I'll get a pic of the sub in the hatch for you guys. This setup will give you a shitload of bass if you want it. My car thump with the volume at 10 or less on the Bose stereo.
(Thread Starter) | Not Ranked : 0 score Pics as promised And for good measure
| The Following 2 Users Say Thank You to surfwagon For This Useful Post: | killyoutoo (04-18-2008), Sumosub (04-15-2008) |
| Not Ranked : 0 score i love the roof rack. sub looks good too.
__________________ Black Mica '07 Mazdaspeed3 Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing Reppin' ProtegeGarage for life! |
| The Following User Says Thank You to mrlilguy157 For This Useful Post: | surfwagon (04-15-2008) |
![]() Join Date: Mar 2008 Location: DFW, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
| Not Ranked : 0 score I was thinking about getting a shallow mount 10 and putting it under the passenger side seat. I've got 2 12's and it eats up most of my hatch. i used to have a fusion 10" tube...but it didnt hit hard enough...lol. Good job!
__________________ 2008.5 Black Mica Z's is bigger than mine |
| Not Ranked : 0 score looks good. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score So what did you do with the stock sub, just disconnect it? Do you guys think I could just disconnect the stock speakers and replace them with my Boston Pro separates w/o using new wires and the crossovers?
__________________ 07 COSMIC BLUE MS3 GT 00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten 09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD 11 BLACK SUZUKI GSX-R750 - totaled 11 BLACK SUZUKI GSX-R750 - totaled...again *OFFICIALLY RETIRED FROM TWO WHEELS* |
![]() Join Date: Apr 2008 Location: Baltimore MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 199
| Not Ranked : 0 score I have a sport Ms3 with the stock radio not the Bose. I would like to add a sub and amp. Do I have to change my head unit for this? Does the stock stereo have a 3rd output? I really want to do this but want to keep the look of my stock interior. |
(Thread Starter) | Not Ranked : 0 score You don't need to change the stock stereo to do this. You can add an amp and sub to your stock stereo. Search on Mazda3forums for the non Bose Wiring Diagram. It's really easy to do.
(Thread Starter) | Not Ranked : 0 score I wanted to try to keep the stock sub. The only reason I would remove it is if you can't find a spot for your amp. Also I would NOT wire those Boston's into your factory deck. The stock stereo with an added sub sounds killer.
| The Following User Says Thank You to surfwagon For This Useful Post: | MadOzodi (05-03-2008) |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score Yeah +1 to that. With a sub added I've been really happy with the Bose. I tapped the INPUT wires into the bose amp and added RCA plugs to the other end of the wires to plug into the aftermarket (kicker) amp. |
| I like that enclosure! did you make that yourself?
So the stock sub effectively takes care of the low end of the mid range while the added sub fills in everything below? If so, that's perfect.
__________________ 07 COSMIC BLUE MS3 GT 00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten 09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD 11 BLACK SUZUKI GSX-R750 - totaled 11 BLACK SUZUKI GSX-R750 - totaled...again *OFFICIALLY RETIRED FROM TWO WHEELS* | |
(Thread Starter) | Not Ranked : 0 score Pretty damn much. The Bose has nice highs and mids but nothing in the low range. You will be very happy after adding your sub. No doubt. Leave everything as is and just add the amp and sub.
| Not Ranked : 0 score Thank God...I don't have to worry about where the heck I'd put my 4ch. Now all I have to do is see if my old 2ch 300W RF amp will fit in the glove box.
![]() | | #24 | ![]() |
Groans: 370
| Neutral : -1 score Haltech, There's a guy on M3F that makes them...He also has a website somewhere. I sent my payment, and he made the thing and sent it to me and it was here within 2 days...awesome. I think it was 110 shipped. It's exactly what I was looking for though. The only drawback is it's for a 8" sub, you could probably put in some kind of space to accomodate a bigger or deeper sub if you needed that. |
![]() | | #25 | ![]() |
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
![]() | | #26 | ![]() |
Negatives aside, I'm happy enough with it for $95. Jack fits with the spare tire w/o any problems too and my amp under the rear plastic tray with a little dremelling so it helped me get what I wanted Last edited by sweetpickles; 05-04-2008 at 10:24 PM. | |
| The Following User Says Thank You to sweetpickles For This Useful Post: | Haltech (05-04-2008) |
![]() | | #27 | ![]() |
![]() Join Date: Mar 2008 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 275
| Not Ranked : 0 score very nice, is there any concern with the amp being in the glove box? i.e. little air flow for cooling
__________________ 07 MS3 GT w/Nav + Mods |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not really. There's no cross air ventilation but there's around 6-8 inches above the amp for air. No issues
![]() | | #29 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score I did mine with an amp and subs left over from my last vehicle. Out of pocket right now for the mod was a 10 spot for 22 feet of 4 gauge power wire. |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Anybody know how much space is under the passenger seat if I were to remove the stock bose sub? Im thinking about just getting a small sub enclosure or something... I need more bump. I wanna get something compact and smallt hat I can squeeze under the seat. |
![]() | | #31 | ![]() |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() Thanks: 8
| Not Ranked : 0 score I cannot imagine that you are going to be able to install anything that will sound much better than the Bose sub under there. There is probably only 3-4" of usable space underneath that seat. There is also a flattened plastic pipe that must be used for air/heat for the back seats routed under there. I removed the factory sub and installed my amp there. I put a 10" sub in the rear cargo area. Ed. |
![]() | | #32 | ![]() |
| Not Ranked : 0 score bumping an old thread. I had a sub and amp installed, but in a litlte different of an old way. anyway, my old amp fried and i dunno why. i hooked up a new amp but for some reason its not working. This amp actually has a high level input, so id like to install it that way. There are 4 wires needed for the high level input, R+ R- and L+ L-. The are only 2 wires the OP is saying to splice, so how would I go about doing that? |
![]() | | #33 | ![]() |
| Not Ranked : 0 score You will need 4 wires. You will need a signal and ground for both the right and left channels. I installed mine off the low level signals going into the amp under the drivers seat. The OP probably installed of the signal sent to the subwoofer from the factory amp. At that point there would only be one set of wires. I do not know if you can just feed that to both sides of your amp since the factory system was feeding a mono circuit as opposed to stereo into the sub. Think of the wire that he is referring to as the output wires from your amp to the sub. Ed Last edited by eddelgado; 06-26-2009 at 06:30 AM. |
![]() | | #34 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
Groaned at 12 Times in 3 Posts
| Not Ranked : 0 score I've always been a little disappointed with the stock bose stereo, It's nice to hear that it can be upgraded for fairly cheap. |
![]() | | #35 | ![]() |
| Not Ranked : 0 score I have been really happy with the stereo after removing the factory sub and adding in a 10" in the back. It fills in everything nicely and adds the deep bass that was missing with the factory system. Ed |
![]() | | #36 | ![]() |
![]() Join Date: May 2009
Rep Power: 372 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score website for mazda3stealthbox.com not working, or is it just my crap connection ?
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
![]() | | #37 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score Shit be broke!
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
![]() | | #38 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 908
| Not Ranked : 0 score anybody try this site...some good info and product Subthump.com— Custom Sub Enclosures for the Mobile Masses http://www.subthump.com/pac.htm |
![]() | | #39 | ![]() |
![]() Join Date: Sep 2009 Location: Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 483
| Not Ranked : 0 score Nice. I will likely be doing something similar to what the OP did. I used to have a pair of Kicker Solobaric 12's back in the day but that was too much bass for what I want now that I'm older. Plus I want to keep it as light as possible as I don't need a 100lb sub box slowing me down. Thanks to the OP for the closeup pic of which wires to tap into. |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm the OP. It's been a year and a half and I'm still happy with it. It's far from the 2 JL 12" subs that I had when I was 17 but it's a nice full sound with very respectable bass for what it is. Since that time I added a GROM ipod interface and I'm happy with it too.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f13/very-happy-after-adding-sub-bose-system-1269/ | ||||
| Best place to get signal for my line out converter on my 2015 mazda 6 | This thread | Refback | 08-01-2014 07:55 AM | |
| exotic-cars - N - Nissan 300ZX Twin Turbo - Page 43 | This thread | Refback | 10-29-2011 02:53 PM | |
| Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 03-29-2008 11:02 PM | |
| 2008.5 Bose issue | NYpest | MazdaSpeed 3/6 - Car Audio & Electronics | 22 | 08-04-2008 11:19 PM |
| Happy Turbo Noises | kneedragger241 | MazdaSpeed 3/6 - Turbo Induction | 5 | 03-18-2008 07:47 PM |
