Miata MX-5
> Miata - Forced Induction
Like Tree5Likes
 Old 05-29-2013, 07:21 AM   #1
BoostedM's Avatar
Posts: 178   (View Stats)
BoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the worldBoostedM is the leader of the world
Default 96M Turbo Project
Picked this car up in the late fall in Kentucky, 96M edition 73k orginal miles, Car spent most of its life in Alabama. Recent motor swap to a Imported JDM Motor, car was supercharged at some point in its life. picked it up for 3800, drove it home without a crank sensor. replaced the radiator and added a crank sensor.
The Build Plan
Begi Log manifold, SR20 Oem T25, Megasquirt MS3, 1100cc/Min FIC injectors, M-tuned Coolant ReRoute and Dual Feed Fuel Rail, Toyota Coil on Plug conversion Running Full sequential Spark, Homemade Down Pipe, E85
Progress
Stage 1 Get car running on the Megasquirt on e85 with the Coil on Plugs.
The Previous owner really didnt know what he had and didnt keep the car all that clean on the inside, he left me presents...
oem Mazda ECU placement
The mega-squirt has an internal map sensor that needs a vacuum source, alot of guys run it straight through the firewall. I found on my last miata that this way is a pain in the ass so i decided to do it a different way. looks a little bit more oem from the engine bay prospective.
the head has been gone through at some point, sweet
More to come in the following weeks
ilias and Koke382 like this.
2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow
1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed
BoostedM is offline   Reply With Quote
The Following 10 Users Say Thank You to BoostedM For This Useful Post:
Ace Protege (05-29-2013), Boosted Beluga (05-29-2013), El_Diablo (06-10-2013), forcedinduktion (06-06-2013), Funkster777 (05-29-2013), Jh8909 (05-29-2013), leon78 (05-29-2013), obijack (06-01-2013), smoogs12 (05-29-2013), Tomas (07-21-2013)
 Old 05-29-2013, 09:38 PM   #2
BoostedM's Avatar
Started the day like this. finished up installing the new injectors and mtuned fuel rail.
Struggled with the o2 sensors for a few hours and many torch attemps with a finally result of me-0 o2-1. its not a project around my house if you havnt spilled blood all over it
after getting bandaged up, i took a look at the intake and decided since i dont live in communist California egr must disappear
Final mounted the MS, ignore the blue wire i was testing a ground for the radio.
Final resolution for wideband, cut a hole in the exhaust and weld a 3rd bung in. sounded easy enough till i could find the welders helmet in the sea of boxes in the garage. pulled the set it close and close your eyes method, have to say it looks like a 3 year old did it but should work till i find the helmet and can redo it. no pics of that though. should be ready to setup the tune and first fire on ms tomorrow morning.
The Following 5 Users Say Thank You to BoostedM For This Useful Post:
aaronc7 (06-10-2013), Ace Protege (05-29-2013), Boosted Beluga (05-30-2013), Funkster777 (05-29-2013), jomc111 (05-29-2013)
 Old 05-29-2013, 09:52 PM   #3
Ace Protege's Avatar
Posts: 753   (View Stats)
Ace Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the worldAce Protege is the leader of the world
Solid plan, T25 will probably leave you wanting more though.
'02 Bmw 330ci
Kinda low and really slow.
'94 Mazda Protege -SOLD
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
'05 ZX-6RR - Two Brothers slip on, GPR dampener V1, More to come
Ace Protege is offline   Reply With Quote
 Old 05-29-2013, 09:55 PM   #4
BoostedM's Avatar
yea i already want more and its not installed, but the 220-250ish hp ballpark keeps the rods in the block.
 Old 05-29-2013, 10:00 PM   #5
yep, lol if you note my numbers that's why I'm happy till I decide to do rods and pistons.
T25 will probably be right around 200whp.
'02 Bmw 330ci
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
 Old 05-29-2013, 10:10 PM   #6
BoostedM's Avatar
i squeezed what virtual dyno called 226 out of a 1.6 with a td04 based greddy kit. so i think with some cleaver timing and e85 i can make 230 happen. if not get a bigger turbo.
The Following User Says Thank You to BoostedM For This Useful Post:
J'sSpeed3 (07-21-2013)
 Old 05-29-2013, 10:16 PM   #7
well, only one way to find out! lol btw, where did you get the Mtuned Fuel rail?
'02 Bmw 330ci
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
 Old 05-29-2013, 10:18 PM   #8
BoostedM's Avatar
One of the Miata Turbo Site Vendors 949 Racing , looking forward to having a turbo miata again, the speed is fun but not the same as a turbo miata.
 Old 05-29-2013, 10:30 PM   #9
I only see a listing for a 1.6 rail.
'02 Bmw 330ci
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
 Old 05-29-2013, 10:40 PM   #10
BoostedM's Avatar
well that weird, if your looking for one send emillio an email hes really easy to deal with and can probably either get you one or point you in the right direction.
 Old 05-29-2013, 10:51 PM   #11
yeah, a rail has been on my to-do list for a while and I figure I'll do it when I replace my injector seals and put on a Hondata thermal gasket.
'02 Bmw 330ci
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
 Old 05-30-2013, 11:00 AM   #12
BoostedM's Avatar
regular gas 3.99 at the station i picked up e85 from, E85 was 3.19 thats a win in my book. it starts after you fool the ms into letting it, The tune rev put on its for the gm iat that i dont have yet. i pm'd him about getting one for a maf car for the time being. Once started i found the intake has a bad leak somewhere and the exhaust is leaking around the homemade egr cap, i kinda figured it would. may mess with it tomorrow or Saturday depending on whats going on around here. anyway first idle video for you guys.
 Old 06-01-2013, 06:39 PM   #13
BoostedM's Avatar
figured out the leak was partially the egr block off plate, and partially cyl 4's injector seal not seating correctly. got that fixed and the new map reverent sent me on, forgot to save the old one for when i switch to the gm iat so i will have to get that from rev again. had it idling fine have a leak around the bung i poorly installed into the exhaust, may go get a new welding mask tomorrow morning and fix it(i cant for the life of me find the one we have, its still in a box somewhere). but did a quick around the block running super rich, felt fairly good.
 Old 06-01-2013, 06:47 PM   #14
obijack's Avatar
Posts: 1,830   (View Stats)
Glad to see this build coming along so fast. I cannot wait to start ordering parts for my miata. I will prolly go with a gt28 series from the get go tho.
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 06-01-2013, 07:03 PM   #15
BoostedM's Avatar
i have 200 buck in the manifold and turbo so i cant complain. but if i were buying stuff at normal prices i would got with the gt28 as well.
The Following 3 Users Say Thank You to BoostedM For This Useful Post:
Boosted Beluga (06-01-2013), jomc111 (06-03-2013), obijack (06-02-2013)
 Old 06-03-2013, 11:30 AM   #16
BoostedM's Avatar
Last few pieces I need; oil sandwich plate, adjustable fuel preassure regulator, some mica mandrel bent tubing, ebc solenoid, and gm iat sensor.
 Old 06-05-2013, 07:08 PM   #17
BoostedM's Avatar
so i put off finding the welding mask till this morning, got it re-welded sorta. never again will i weld laying on my back with no room to work. looks horrible, has a small leak. luckily its getting replaced when the turbo goes on so idgaf.
drove it around and got some tuning done, pissed the neighbors off and made allot of noise. all in a good days work if i do say so myself. driving it tomorrow to do some more tuning and get some more of that wonderful E85.
Plan now is to add in some timing and do a virtual dyno run to see if i gained anything over stock power. if i didnt
The Following 2 Users Say Thank You to BoostedM For This Useful Post:
Boosted Beluga (06-05-2013), jomc111 (06-05-2013)
 Old 06-05-2013, 08:16 PM   #18
jomc111's Avatar
Posts: 585   (View Stats)
jomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the world
Im sure you will gain some , glad to hear you have it back on the road
2012 Cadillac CTS-V
2014 focus st
2010 Taurus sho- sold
2009 speed 3 gt cwp -was once a monster -sold
jomc111 is offline   Reply With Quote
 Old 06-05-2013, 08:40 PM   #19
BoostedM's Avatar
thanks it felt good to drive it again, on a side note e85 smells really good but the odor hangs around for a while parked the car and came back out 1hr later and you could smell it 20-30 feet away.
 Old 06-06-2013, 08:42 PM   #20
BoostedM's Avatar
well 1 Launch Control rev blew the temp fix i had on the wideband bung :vash: though adding about 18% across the board on the fuel map got it really close, and VE got it the rest of the way. guess the plan is to cut out crappy pipe, go get new pipe and bung and profit.
Boosted Beluga (06-06-2013), jomc111 (06-06-2013)
 Old 06-06-2013, 08:44 PM   #21
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
awesome project man
 Old 06-06-2013, 08:47 PM   #22
BoostedM's Avatar
Originally Posted by forcedinduktion View Post
awesome project man
thanks man, should get more awesome in the coming weeks. i have alot of custom stuff planed that you should be seeing soon.
Boosted Beluga (06-06-2013), forcedinduktion (06-06-2013)
 Old 06-06-2013, 09:44 PM   #23
jomc111's Avatar
Let me know if you need a hand after this weekend I dont have much going on
2012 Cadillac CTS-V
2014 focus st
 Old 06-07-2013, 02:25 PM   #24
BoostedM's Avatar
oh im going to need some help in a week or so.
In other news im selling my pieced together setup and getting this SS awesome setup. i decieded that i hate messing with exhaust, so get a good one and leave it alone. also comes with a larger turbo then i had previously so win win. oh and its pretty, and sounds healthy to.
Fail_6 and Koke382 like this.
Boosted Beluga (06-07-2013), jomc111 (06-07-2013)
 Old 06-10-2013, 08:53 AM   #25
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
How much?
Sent from my SPH-L900 using Tapatalk 2
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 06-10-2013, 08:57 AM   #26
BoostedM's Avatar
Originally Posted by Koke382 View Post
How much?
I'm assuming you mean for the manifold and turbo stuff. You have a pm.
 Old 06-10-2013, 08:26 PM   #27
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Abe/ARTech is the best. Looks almost identical to what I have. You went with the bigger muffler though!
Did you build the MS3 yourself?
 Old 06-10-2013, 08:35 PM   #28
BoostedM's Avatar
i bought it off mt gently used, and Rev built the ms3. im expecting it to be alot of fun.
 Old 06-10-2013, 08:46 PM   #29
aaronc7's Avatar
Groans: 370
Nice. I'm looking for an excuse to jump from my MS2/DIYPNP to MS3, but I can't quite justify it. Don't have VVT, which is probably the biggest selling point for MS3 right now over MS2.
 Old 06-10-2013, 09:00 PM   #30
BoostedM's Avatar
i just went with the basic ms3. i bought the turbo stuff off fowlermotorsports, he said it should be here Friday so hopefully next week i will be installing. no big deal if its not here friday i still have to do the 949 stage 1 clutch and mtuned coolant reroute so i will be busy for a couple days.
 Old 06-11-2013, 07:59 AM   #31
ajkulish's Avatar
Posts: 412   (View Stats)
ajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the world
Groans: 40
i was very confused reading the last few posts.... i guess ms3 has a couple different meanings haha
2006 Mazdaspeed 6 VRM
GTX3076r|Manley Pistons+Rods|AEM WMI|PnP Head|ACT 6 puck+Streetlite|COBB AP|Dramatuned|CorksportTBE|Autotech Internals|Forge v1|JBR Mounts|H&R Springs
RIP - 2007 Mazdaspeed3 GT 22V
COBB AP+SF+TIH|E30 tuned by Mark Gibson|H&R Springs|eBay Downpipe|CXRacing FMIC|KMD+Aviva|SU RMM|TurboXS Hybrid|TWM Base Bushings|Masonvi Knob
ajkulish is offline   Reply With Quote
 Old 06-11-2013, 08:07 AM   #32
BoostedM's Avatar
Yea it has a couple meanings, we were talking about Megasquirt V3. for those who care here is the comparison chart between the various levels of Megasquirt.
MS Labs ECU Comparison Sheet
obijack (06-12-2013)
 Old 06-11-2013, 08:13 AM   #33
ajkulish's Avatar
Groans: 40
yeah i caught on to that after i read MS2 haha
 Old 06-12-2013, 09:37 AM   #34
BoostedM's Avatar
Adjustable FPR came in
Koke382 likes this.
Boosted Beluga (06-12-2013), jomc111 (06-12-2013), obijack (06-12-2013)
 Old 06-12-2013, 03:18 PM   #35
obijack's Avatar
What are the pros and cons of megasquirt compared to hydra or AEM?
2014 Honda Grom-Red
 Old 06-12-2013, 05:56 PM   #36
BoostedM's Avatar
price - megasquirt is cheaper
Functionality - functions just as well if not better
Most of miata turbo use megasquirt so there is a huge knowledge base
i believe megasquirt is open source so there are different people doing vastly different things with hardware and firmware.
obijack (06-13-2013)
 Old 06-13-2013, 08:48 PM   #37
BoostedM's Avatar
Sold the original setup i had yesterday. surprisingly enough it fit all into a large flat rate box. weighted in at 27lbs.
drove it a little bit today, so picture time.
jomc111 (06-15-2013)
 Old 06-14-2013, 09:04 PM   #38
BoostedM's Avatar
Got home and about cried when i saw the box. thanks ups
But started unpacking and all was undamaged, thankfully. so without further interruption, some fap material for tonight.
i dont think this turbo has ever been on a car
For comparison
Last edited by BoostedM; 07-29-2013 at 09:16 AM. Reason: MSF Database - Automerged Doublepost
jomc111 (06-15-2013), Koke382 (06-15-2013), obijack (06-15-2013)
The Following User Says NO Thank You to BoostedM For This Un-useful Post:
Boosted Beluga (06-14-2013)
 Old 06-14-2013, 09:13 PM   #39
aaronc7's Avatar
Groans: 370
what turbo is that?
 Old 06-14-2013, 09:16 PM   #40
BoostedM's Avatar
2871 clone, just a bit bigger than the sr20 turbo i was going to us.
Page generated in 0.61268 seconds with 28 queries
