Miata MX-5
> Miata - Forced Induction
Like Tree6Likes
 Old 06-06-2011, 10:47 AM   #1
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Default Guess my whp - Dyno Completed
Dyno complete. Results below.
1999 Mazda Miata
Stock engine
GT2506R @15-16psi
DIYPNP
550cc RX7 injectors
Devil's Own Meth/water injection
ARTech manifold
ARTech 3" downpipe and exhaust
CXRacing "George foreman grill" FMIC
Did 3 runs. First was in 3rd gear and didn't include it in the printout, it made 263whp. Probably about a 1 minute break between each pull. No fan or anything in front of the car (looking back I should have made them set something up). Car kept making more power each pull.
Some of you may remember my boost creep issue... still not perfect. Tried to flatten boosted out with EBC, but it's less than ideal. Going WOT at 2500rpm like this, the boost will hit 11-12psi intially, then easy up and hold 15-16 most of the way and creeps about 1psi past that past 6000. This helps hold some of the power past peak I'm sure...but maybe not, might be outflowing the turbo at this point.
Going GT2781R and EWG next. Wanted to get a good 'baseline' in this setup before moving on... probably run about 12-14 with that turbo until I can build the motor and get a 6 speed tranny.
275whp/258wtq SAE Corrected
#x202a99 Miata GT2560R Dyno&#x202c‏" target="_blank">YouTube - &#x202a99 Miata GT2560R Dyno&#x202c‏
The Following 6 Users Say Thank You to aaronc7 For This Useful Post:
4G63 (06-06-2011), 802MS3 (06-06-2011), AZSPEED3 (06-06-2011), DaleNixon (06-06-2011), jracer (06-07-2011), MATT DAMOND (06-06-2011)
 Old 06-06-2011, 10:48 AM   #2
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
i call dibs on 12whp.
and 243whp.
 Old 06-06-2011, 10:49 AM   #3
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
234whp
07 MS3
The original Genpoo Hater
 Old 06-06-2011, 10:50 AM   #4
aaronc7's Avatar
Groans: 370
69whp
actually, I'm going to guess 350whp, motor blows, slips on the dyno, and flips over, crashes, and @Darksun280 tells me to try and get it covered under insurance.
Boosted Beluga and Bucker like this.
The Following 20 Users Say Thank You to aaronc7 For This Useful Post:
4G63 (06-06-2011), 802MS3 (06-06-2011), alien_sporez (06-06-2011), AZSPEED3 (06-06-2011), bcmountainspeed (06-06-2011), cbusby (06-06-2011), cpolly69 (06-06-2011), DaleNixon (06-06-2011), danesti (06-06-2011), emag remrofni (06-06-2011), i8urgti (06-06-2011), jracer (06-07-2011), laxplayermjd (06-06-2011), manelscout4life (06-06-2011), MATT DAMOND (06-06-2011), RayRayBauder (06-06-2011), spoolin00 (06-06-2011), superskaterxes (06-06-2011), thanox2 (06-06-2011), the_caruch (06-06-2011)
 Old 06-06-2011, 10:53 AM   #5
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
1fwhp
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
The Following User Says Thank You to RayRayBauder For This Useful Post:
 Old 06-06-2011, 10:58 AM   #6
aaronc7's Avatar
Groans: 370
The Following 12 Users Say Thank You to aaronc7 For This Useful Post:
alien_sporez (06-06-2011), asiandude74 (06-06-2011), AZSPEED3 (06-06-2011), DaleNixon (06-06-2011), danesti (06-06-2011), jracer (06-07-2011), MATT DAMOND (06-06-2011), Nazarite (06-06-2011), RayRayBauder (06-06-2011), spoolin00 (06-06-2011), thanox2 (06-06-2011), wankular (06-06-2011)
 Old 06-06-2011, 11:01 AM   #7
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
272RWHP, 285TQ
403whp/451ft/lb Dry Shot
 Old 06-06-2011, 11:01 AM   #8
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
lol wtf?
2008 STi
Intake
Turboback
AP
The Following User Says Thank You to danesti For This Useful Post:
4G63 (06-06-2011)
 Old 06-06-2011, 11:01 AM   #9
SRTie4k's Avatar
Posts: 1,715   (View Stats)
226WHP.
 Old 06-06-2011, 11:01 AM   #10
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
I vote that you start feeling less gay, and with your new found hetero-ness, you accidentally take you MZ6 to get dyno'ed, because it's slightly less gay than your Miata, and make 134whp.
Current Fail:
 Old 06-06-2011, 11:05 AM   #11
deuce_WI's Avatar
Posts: 234   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
249 horses
263 torques
Same as my 3 when she was new and bone stock (mustang dyno).
deuce_WI is offline   Reply With Quote
 Old 06-06-2011, 11:10 AM   #12
i8urgti's Avatar
Posts: 1,660   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
 Old 06-06-2011, 11:10 AM   #13
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
250 hp 240 torques
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 06-06-2011, 11:11 AM   #14
aaronc7's Avatar
Groans: 370
miata is a 1.8, *always* makes more HP than TQ... honestly im just gonna hope for 250 but we'll see.
 Old 06-06-2011, 11:11 AM   #15
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Originally Posted by aaronc7 semi gay now View Post
69whp
This plan will never work since every time you call insurance and tell the agent the car you are reporting a claim on they will burst out in uncontrollable laughter until your forced to hang up and try calling again.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 06-06-2011, 11:40 AM   #16
aaronc7's Avatar
Groans: 370
@Darksun280 @Haltech
so what is the whp threshold that I need to be above to get my normal aaronc7 name back?? lol keep in mind its a 9:1 compression 1.8 motor in a 2300lbs car... with like, 140bhp stock?
 Old 06-06-2011, 11:42 AM   #17
Fux Wit It
Darksun280's Avatar
Groans: 175
You have to be able to dyno higher then a 99 v6 mustang.
 Old 06-06-2011, 11:43 AM   #18
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
230ish my friend
 Old 06-06-2011, 11:46 AM   #19
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
20psi now
Witch shouldn't be too hard to do....lol
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Last edited by Boosted Beluga; 06-06-2011 at 11:46 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-06-2011, 11:56 AM   #20
Groans: 50
I seen a full bolt on v6 mustang do like 210 to the wheels. I forget the year but it was a 98-01.
08 Mazdaspeed 3
 Old 06-06-2011, 11:56 AM   #21
aaronc7's Avatar
Groans: 370
ok let me track down a 99 v6 mustang dyno.
phillyb says 170whp for my powa
it's even cammed lol. 196whp @Darksun280
 Old 06-06-2011, 12:00 PM   #22
Groans: 50
Wow thats horrible.
08 Mazdaspeed 3
 Old 06-06-2011, 12:01 PM   #23
Blue 2 shims
Nazarite's Avatar
Posts: 2,254   (View Stats)
Groans: 66
Good luck man, in for you reacquiring hetero-ness via insurance fraud.
Boosted Beluga likes this.
Nazarite is offline   Reply With Quote
 Old 06-06-2011, 12:10 PM   #24
Fux Wit It
Darksun280's Avatar
Groans: 175
Lord Jesus these things make 156whp stock.
SMH......
 Old 06-06-2011, 12:10 PM   #25
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
237 whp
Past Mazdas & Speeds
 Old 06-06-2011, 12:12 PM   #26
Fux Wit It
Darksun280's Avatar
Groans: 175
Originally Posted by Bob Loblaw View Post
237 whp
Is that with with or without Aaron's girlfriend sitting in the trunk keeping the wheels down on the rollers?
 Old 06-06-2011, 12:26 PM   #27
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
I fucking love your miata aaron! Hope you get the numbers you want man pulling for ya! You make me want a miata very bad. Post video of dyno!
2003 Evo VIII
 Old 06-06-2011, 12:28 PM   #28
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
237-238whp
 Old 06-06-2011, 12:40 PM   #29
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
I'll go a little high 253/238
Black Metal is offline   Reply With Quote
 Old 06-06-2011, 12:53 PM   #30
alien_sporez's Avatar
Posts: 1,199   (View Stats)
alien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the world
I say 255 whp.
● 2011 Jaguar XFR ● Full Resonator Delete ● Mina Cat-Back Exhaust ● Staggered Giovanna Portofinos ●
● 2010 Mazdaspeed 3 - GONE ●
alien_sporez is offline   Reply With Quote
 Old 06-06-2011, 01:52 PM   #31
Neverlift's Avatar
Groans: 1,143
What the fuck does it matter?
 Old 06-06-2011, 01:53 PM   #32
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
227hp
218tq
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 06-06-2011, 01:54 PM   #33
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
is this like price is right?
1whp
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
-cj- (06-06-2011)
 Old 06-06-2011, 01:57 PM   #34
Fux Wit It
Darksun280's Avatar
Groans: 175
Heard weighing down the rear gives an extra hp or 2
 Old 06-06-2011, 02:01 PM   #35
mrFanel's Avatar
Posts: 487   (View Stats)
mrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the worldmrFanel is the leader of the world
You are missing COPs homes
220 whp, 215 whtq.
'12 GTI 6M.
mrFanel is offline   Reply With Quote
 Old 06-06-2011, 02:08 PM   #36
cpolly69's Avatar
Groans: 27
220 whp, 215 whtq.
indeed sir
this among many other little things are the reasons i just went ahead and shelled out a bit more for my car...
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 06-06-2011, 02:11 PM   #37
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
my guess is 69GWHP and 69GWTQ
GTWHP (gay wheel horsepower)
GWTQ (gay wheel torque)
Last edited by surebOOst; 06-06-2011 at 02:11 PM. Reason: MSF Database - Automerged Doublepost
surebOOst is offline   Reply With Quote
The Following User Says Thank You to surebOOst For This Useful Post:
 Old 06-06-2011, 02:22 PM   #38
SRTie4k's Avatar
Just the fact that you had to explain that is pretty gay. Next time be wittier.
The Following User Says Thank You to SRTie4k For This Useful Post:
 Old 06-06-2011, 02:26 PM   #39
I believe that is a dynojet, so I'll take a stab and say 240whp, 210 ft lbs torque.
 Old 06-06-2011, 02:32 PM   #40
surebOOst's Avatar
I am starting to think that you took offense to that. Yes we know you "gay people" have the same rights as the rest of us but, that doesn't change the fact you are a douche bag.
I explained it so anyone who did not understand could catch it. You sir are a genius!
andrew88 likes this.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f15/guess-my-whp-dyno-completed-82670/
JCH13 - Turbo Miata Build/Auto-X Prep - UPDATE 4/29/2011 MOAR VIDEO! - Page 8 - AnandTech Forums This thread Refback 06-06-2011 07:11 PM
DEFI Gauges completed.... FINALLY drknyte MazdaSpeed 3/6 - Appearance 50 10-03-2011 05:40 PM
Completed set of Bolted Tires SnoXRacer183 2010 MS3 - Wheels & Tires 46 05-31-2010 07:10 AM
Nardelli to leave Chrysler once bankruptcy completed Haltech Automotive News 0 04-30-2009 12:10 PM
Aston Martin unveils the first completed One-77 in Italy Haltech Automotive News 0 04-25-2009 06:00 PM
SU Side Engine Mounts Completed & Installed Grim MazdaSpeed 3 - Engine, Transmission & Driveline 22 10-30-2008 02:29 PM
Page generated in 0.61625 seconds with 44 queries
