![]() | | #41 | ![]() |
| I have candy in my van ![]() Join Date: Apr 2009 Location: Chicago, IL
Rep Power: 2810 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,091
Groans: 70
| Not Ranked : 0 score
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project |
![]() | | #42 | ![]() |
![]() Join Date: Feb 2011 Location: Marco Island, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 839
Groans: 48
| Not Ranked : 0 score |
![]() | | #43 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score 239whp...maybe |
![]() | | #44 | ![]() |
Groans: 239
| Not Ranked : 0 score 50 less than tony's
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #45 | ![]() |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score 666 whp 666 wtq |
![]() | | #46 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
![]() | | #47 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
(Thread Starter) | Not Ranked : 0 score Last edited by Darksun280; 06-06-2011 at 04:43 PM. |
| The Following 5 Users Say Thank You to aaronc7 For This Useful Post: | 4G63 (06-08-2011), AZSPEED3 (06-06-2011), Black Metal (06-06-2011), emag remrofni (06-06-2011), Nazarite (06-07-2011) |
![]() | | #48 | ![]() |
![]() Join Date: Feb 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,098
Groans: 78
| Not Ranked : 0 score | |
| The Following User Says Thank You to Black Metal For This Useful Post: | aaronc7 (06-06-2011) |
![]() | | #49 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
| The Following User Says Thank You to Bucker For This Useful Post: | aaronc7 (06-06-2011) |
![]() | | #50 | ![]() |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score I'll change your name once you change the smoothing on that graph to a 5 so it don't look like shit.......
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
| The Following User Says NO Thank You to Darksun280 For This Un-useful Post: | socks (06-06-2011) |
![]() | | #51 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score whatever. still made more than v6 mustang lol. btw darkie...how much power your car putting down? |
![]() | | #52 | ![]() |
Groans: 175
This past sat with 85 degrees in the shop I did 340whp and 345Tq.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous | |
![]() | | #53 | ![]() |
![]() Join Date: Nov 2010 Location: Eglin AFB, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Damn good numbers. I bet 300whp would be doable with the right tuning. Looks like you could lean it out after 6K RPM, help with that torque curve dropping. I like how the ineffectiveness of the boost control shows up at 5K RPM. Holy torque dip batman! |
| The Following User Says Thank You to messiahx For This Useful Post: | aaronc7 (06-06-2011) |
![]() | | #54 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score Well it's 91 degrees out right now as I'm typing this for me. Let's do some basic math here. Evo X curb weight: 3585lbs 1999 mazda miata curb weight: 2299lbs (I don't have power locks/windows etc...but turbo adds some weight, we'll say 50lbs) so 2350lbs Evo X Power/weight: 0.0948 HP/lbs Miata power/weight: 0.117 HP/lbs Evo X would need 420whp to be 'even' with Miata. And you're quibbling over correction factors??? lol |
| The Following 5 Users Say Thank You to aaronc7 For This Useful Post: | 802MS3 (06-06-2011), AZSPEED3 (06-06-2011), manelscout4life (06-06-2011), rfinkle2 (06-06-2011), thanox2 (06-06-2011) |
![]() | | #55 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score Also I should thanks @messiahx to helping with all the major installs, and tons of stuff in the tuning area. Answered a lot of dumb questions for me and even helped tune the car. He has a miata as well, but he's gonna be building the motor and slapping a huge turbo on. |
![]() | | #56 | ![]() |
Groans: 175
| Not Ranked : 0 score car with you in it is what 2500 pounds. my car with me is like 3800 with out a spare. Your power falls off at 6500 mine holds till about 7-7500 so it would be a good run against you from a high roll. anything below 45 may be in my favor.
![]() | | #57 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score high roll would be good and you might even beat me there. Aerodynamics are not on my side. But peak rpm doesnt make a difference...if had the same gearing perhaps. |
![]() | | #58 | ![]() |
Groans: 175
![]() fuck you for making me e-war with you its funny against you a higher roll would cancel out the weight difference more but my pitifully short gear would leave me high and dry when it comes to how long i could hold out. After 120 I'm dead in the water.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous Last edited by Darksun280; 06-06-2011 at 05:20 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #59 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score I meant smoothing....even more ridiculous than correction factor, lol. all that power comes on sooner and holds longer doesnt mean much, as long as we both drive the cars within their peak power range....in which case all you have to worry about is make sure you shift at the right rpm. |
![]() | | #60 | ![]() |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,113
Groans: 83
| Not Ranked : 0 score Gotta love HP to weight ratio nice numbers
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto |
| The Following User Says Thank You to MSFer87 For This Useful Post: | aaronc7 (06-06-2011) |
![]() | | #61 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score above 100-120 this guy is dead in the water too. aerodynamics pwn miata lol. |
![]() | | #62 | ![]() |
Groans: 175
| Not Ranked : 0 score yeah I heard that to go from like 150-160mph you'd need 100more hp then what it took to get from 140-150mph. Does that make any sense? its just something I read. Would that apply to a light ass car like you at those speeds?
![]() | | #63 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score either way i didnt wanna start an E-War with you... I just needed some ground to get my name changed back to aaronc7. If I was feeling lucky I would even ask for "aaronc7 faster than Haltech"...but I'll be happy with plain old "aaronc7" lol |
| The Following 2 Users Say Thank You to aaronc7 For This Useful Post: | AZSPEED3 (06-06-2011), manelscout4life (06-06-2011) |
![]() | | #64 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Fuckin noobs and their Evo's. Aaron... its not that big a deal above 100. I don't notice it at all til I brake hard from that speed. Takes a bit longer to get the weight to the front tires.
![]() | | #65 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score Yeah car is light and gets floaty, and front end aerodynamics pwn me. But I've only been above 100 like twice and I was videoing, so I didnt' really pay attention and don't have much experience there. The MS3 was super stable at speed, it was nuts Yes that makes sense... air drag increases exponentially with speed. |
![]() | | #66 | ![]() |
Groans: 175
| Not Ranked : 0 score Face it Aaron my E-ness is greater then your E-ness in both length and girth. Comes see me when you put that 1s2 in there. ![]()
I'll let Kev change your name back my black ass ain't touching it.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous Last edited by Darksun280; 06-06-2011 at 05:26 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #67 | ![]() |
![]() Join Date: Feb 2010 Location: Ft lauderdale FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 373
| Not Ranked : 0 score not bad numbers.my buddy scott just did 320 with almost the same setup but on straight 93 no meth and a set of drop in rods.hes running megasquirt and tuning it himself aswell his is in a 99 nb though |
![]() | | #68 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score Thought about LS swap a lot. But it is a lot of money, even beyond just the drivetrain. Ideally I would need stiffer/better suspension, bigger brakes...list goes on. Turbo can reliably get me the power i would want in this light ass car, and I also like dicking around with megasquirt etc.... I also just like turbocharged cars in generals (need mah ricer BOV)
I have 99 NB also :-p Last edited by aaronc7; 06-06-2011 at 05:30 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #69 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Stop fucking with the thing now and get some seat time already.
![]() | | #70 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score OP updated with pic and video I wish. Boost is still no good from part throttle boost to WOT. overboosts like crazy. I need EWG...but I'm gonna be gone again soon. while I'm gone, all the hardware is gonna get taken care of. When I get back....I will get that stuff installed and finally getting seat time-- really looking forward to it. Last edited by aaronc7; 06-06-2011 at 05:44 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #71 | ![]() |
heres the car and one of the first pulls,he bumped the timing later on and made the 320.its been 12.7 at the strip aswell | |
![]() | | #72 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score @03scgt 320whp he should be getting way better than 12.7. Probably just hard to put the power down. Any idea what his trap speed is? Any more info on his build? What turbo? Thanks! |
![]() | | #73 | ![]() |
| Smoothing 5 or gtfo..... Import guys kill me
| The Following User Says Thank You to Haltech For This Useful Post: | Darksun280 (06-06-2011) |
![]() | | #74 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score oh god |
| The Following 2 Users Say NO Thank You to aaronc7 For This Un-useful Post: | Darksun280 (06-06-2011), Haltech (06-06-2011) |
![]() | | #75 | ![]() |
![]() | | #76 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score Just looked at the datalogs. AFR was pretty good around 11.5-11.7 for most of the runs, but past... 6k or so, it goes down, 10.5 by redline lol. I was probably losing some fuel pressure at redline with the stock pump.... threw on the Walbro today and now it's getting too much. Might have been able to eek out a bit more power but whatever, at least it was safe I guess. |
![]() | | #77 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score smoothing or not, thats a solid powerband.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
| The Following User Says Thank You to socks For This Useful Post: | 4G63 (06-08-2011) |
![]() | | #78 | ![]() |
Groans: 175
| Not Ranked : 0 score nigglet how much boost were you running? what your timming maps look like at what point to you start fearing for your pistons or rods well being? Are you faster then Bobs car now?
![]() | | #79 | ![]() |
Groans: 125
| Not Ranked : 0 score read the first post noob.
![]() | | #80 | ![]() |
Groans: 370
(Thread Starter) | Not Ranked : 0 score biggest jumps I'm seeing are ~10whp... ok so average that out- that's still like 270whp... next please. 15-16 psi but it creeps up to 17 by redline. 250wtq considered safe reliable limit... I'm there lol. Here is timing map. Y axis is KPa.. 212 is 16psi. Relatively aggressive timing. I stole it from someone who got a dynotune with GT2560R, but NA 1.8 (I should be able to run more timing than NA 1.8 because of my better head design). I tweaked it a little to smooth it out and that's what I ended up with. I'm also running 3gph nozzle water/meth as a safety blanket. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f15/guess-my-whp-dyno-completed-82670/ | ||||
| JCH13 - Turbo Miata Build/Auto-X Prep - UPDATE 4/29/2011 MOAR VIDEO! - Page 8 - AnandTech Forums | This thread | Refback | 06-06-2011 07:11 PM | |
| DEFI Gauges completed.... FINALLY | drknyte | MazdaSpeed 3/6 - Appearance | 50 | 10-03-2011 05:40 PM |
| Completed set of Bolted Tires | SnoXRacer183 | 2010 MS3 - Wheels & Tires | 46 | 05-31-2010 07:10 AM |
| Nardelli to leave Chrysler once bankruptcy completed | Haltech | Automotive News | 0 | 04-30-2009 12:10 PM |
| Aston Martin unveils the first completed One-77 in Italy | Haltech | Automotive News | 0 | 04-25-2009 06:00 PM |
| SU Side Engine Mounts Completed & Installed | Grim | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 10-30-2008 02:29 PM |
