![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
(Thread Starter) | Not Ranked : 0 score Won't even bother attaching on current tune, as I'm still waiting on the engine to get done, so I just threw in a lot guesses to get started. Changed a lot of things like CR, cams, injectors, etc., so going to have to start from scratch basically. I have a DIYPNP running MS2Extra pre3.3alpha5 gslender v2.8 firmware (quite the mouthful). They have newer betas, but I have not bothered to upgrade until I have a running car. To get this thing started, here are my spark table and datalogs from the dyno runs on my old GT2560R setup on stock 99 motor. (Datalogs attached, msl format is not supported, so I just zipped it). Perhaps a little aggressive on the timing, but I was running 50/50 water/meth with a 3gph nozzle, in addition to 93 pump gas. Don't have the VE table anymore, but I believe it was around the 11.5 AFR range. On the dyno, it's a bit rich as you can see in the print out, as I had just swapped in a new fuel pump earlier that day and didn't have time to re-tune. |
| The Following User Says Thank You to aaronc7 For This Useful Post: | Lex (06-10-2013) |
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 739 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score not too shabby. I have about a 4 month break before my next race--whether it be TT or Time Attack, and a tune is on the short list.
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
| Not Ranked : 0 score Aaron did you take this to MBT or have any sort of knock detection device?
Groans: 370
(Thread Starter) | Not Ranked : 0 score Neither. I did a lot of digging around the net and came across a few guys who had spark tuned their cars with very similar setups to mine on 99 engines/heads. Tried to compile all the data as best I could, smooth it out, and tone it down a little bit to be on the safe side. Plus I was spraying the 50/50 mix, so I was pretty comfortable with that. During motor disassembly, there was nothing noted showing evidence of knock/detonation, etc. I now have some detcans and plan to spark tune my built motor once its ready. I will definitely need to, to get the most out of it, as I bought the lowest CR pistons I could find, and my custom cams will lower the dynamic compression ratio even more...might be kinda a dog out of boost. When I bought my DIYPNP there didn't seem to be any great built-in active knock systems...but maybe there are now. I wouldn't mind throwing something simple on, to at least give me some sort of warning that, "hey i hear some knock". I am not sure what my best route is though. I see the new MSPNP2s have built in knock circuits, not sure if that's something I can adapt into my DIYPNP or what. IIRC DIYPNP has knock input and a basic 'sensitivity' adjustment...but really no proper conditioning circuitry. |
![]() Join Date: Apr 2013 Location: London,OH ; Canton, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
__________________ 2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow 1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed |
| The Following User Says Thank You to BoostedM For This Useful Post: | Lex (06-11-2013) |
I feel proper knock detection is the one thing missing from the MS repertoire and I also feel the MS3 is overkill for any of the cars that can switch to full standalones. For a long time I've been thinking of putting together a refined knock filtering circuit but just haven't had the time. The Phormula units seem to be nice but expensive. Have you used it extensively? How effective is it?
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 06-11-2013 at 09:12 AM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score Dont have a knock sensor and the car is still NA so i haven't touched it. but im sure with the right tuning its pretty killer. The Ms3 as a whole was super easy to get setup and running especially running e85.
Groans: 370
(Thread Starter) | Not Ranked : 0 score Pretty cool all the knock stuff MS3 has built in. I'm still going to hold out for some sort of mod to MS2 I think though- other than this knock stuff, the MS2 with new firmware is great, no complaints. I saw Reverant was working on some sort of knock circuit for use on his MS2s, but I don't really know any of the details or if it would be possible on a vanilla DIYPNP. |
Groans: 370
(Thread Starter) | Not Ranked : 0 score Knock control on the MS2 - Miata Turbo Forum - Turbo Kitten is watching you test compression. Enhanced Megasquirt - now with more features! - Miata Turbo Forum - Turbo Kitten is watching you test compression. MS Labs Enhanced MS2 ECU for the 01-05 and 04-05 MSM out now! - Miata Turbo Forum - Turbo Kitten is watching you test compression. TPIC8101 DSP chip, it says @Lex, you should develop some sort of "external knock module" for DIYPNP/MS2, I'd buy it! On the miata forum I believe there would be a good market for it, assuming price was reasonable (they are cheap asses) Last edited by aaronc7; 06-11-2013 at 05:55 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to aaronc7 For This Useful Post: | Lex (06-16-2013) |
Also I wouldn't make an add-in board, it would be a standalone knock detector that you can plug into any standalone. The key is making a simple interface to bring in some nice to have signals for signal filtering such as engine speed. It's on the backburner at the moment.
| The Following User Says Thank You to Lex For This Useful Post: | aaronc7 (06-16-2013) |
| Not Ranked : 0 score i need to get with the program and make use of a knock sensor in my build.
Groans: 370
(Thread Starter) | Not Ranked : 0 score Damn you all, got me thinking about picking up a MS3X again.... decisions, decisions. |
Groans: 370
MS3x Knock Module Settings Thread - Miata Turbo Forum - Turbo Kitten is watching you test compression. | |
__________________ 2006 Speed 6 Cobb AP, SRI, and cat back Magnaflow 1996 Miata M-Edition, Artech Manifold/DP Combo, China 2871, MS3, 1100cc/min injectors, 93/E85, 6-Speed | |
| E85 tunes | qweedqwag | 2010 MS3 - ECU Computer Tuning | 1 | 04-10-2013 10:25 PM |
| Tunes other than AP, SB and HT? | frivolous_rob | MazdaSpeed 3/6 - ECU Computer Tuning | 42 | 01-21-2011 12:05 PM |
| Any risk when setting throttle req load tables high to force boost by gear tables? | 08Anamoly | Cobb ATR Support | 5 | 03-29-2010 08:52 PM |
