Post your Megasquirt tunes/tables! 1 Attachment(s) Starting to see more and more turbo miatas and build threads on here.... figured we should get a tuning thread going as well. Won't even bother attaching on current tune, as I'm still waiting on the engine to get done, so I just threw in a lot guesses to get started. Changed a lot of things like CR, cams, injectors, etc., so going to have to start from scratch basically. I have a DIYPNP running MS2Extra pre3.3alpha5 gslender v2.8 firmware (quite the mouthful). They have newer betas, but I have not bothered to upgrade until I have a running car. To get this thing started, here are my spark table and datalogs from the dyno runs on my old GT2560R setup on stock 99 motor. (Datalogs attached, msl format is not supported, so I just zipped it). Perhaps a little aggressive on the timing, but I was running 50/50 water/meth with a 3gph nozzle, in addition to 93 pump gas. Don't have the VE table anymore, but I believe it was around the 11.5 AFR range. On the dyno, it's a bit rich as you can see in the print out, as I had just swapped in a new fuel pump earlier that day and didn't have time to re-tune. http://i165.photobucket.com/albums/u...Tables/new.png http://i165.photobucket.com/albums/u...Dyno_275-1.jpg |
not too shabby. I have about a 4 month break before my next race--whether it be TT or Time Attack, and a tune is on the short list. |
Aaron did you take this to MBT or have any sort of knock detection device? |
Quote:
I now have some detcans and plan to spark tune my built motor once its ready. I will definitely need to, to get the most out of it, as I bought the lowest CR pistons I could find, and my custom cams will lower the dynamic compression ratio even more...might be kinda a dog out of boost. When I bought my DIYPNP there didn't seem to be any great built-in active knock systems...but maybe there are now. I wouldn't mind throwing something simple on, to at least give me some sort of warning that, "hey i hear some knock". I am not sure what my best route is though. I see the new MSPNP2s have built in knock circuits, not sure if that's something I can adapt into my DIYPNP or what. IIRC DIYPNP has knock input and a basic 'sensitivity' adjustment...but really no proper conditioning circuitry. |
apparently you want MS3 then, im making use of none of this right now though.... http://i1191.photobucket.com/albums/...ps5981bd7a.jpg http://i1191.photobucket.com/albums/...pseb289f65.jpg http://i1191.photobucket.com/albums/...ps4bd1db6a.jpg http://i1191.photobucket.com/albums/...ps05566add.jpg |
Quote:
I feel proper knock detection is the one thing missing from the MS repertoire and I also feel the MS3 is overkill for any of the cars that can switch to full standalones. For a long time I've been thinking of putting together a refined knock filtering circuit but just haven't had the time. The Phormula units seem to be nice but expensive. Quote:
Quote:
Pretty cool all the knock stuff MS3 has built in. I'm still going to hold out for some sort of mod to MS2 I think though- other than this knock stuff, the MS2 with new firmware is great, no complaints. I saw Reverant was working on some sort of knock circuit for use on his MS2s, but I don't really know any of the details or if it would be possible on a vanilla DIYPNP. |
Quote:
Knock control on the MS2 - Miata Turbo Forum - Turbo Kitten is watching you test compression. Enhanced Megasquirt - now with more features! - Miata Turbo Forum - Turbo Kitten is watching you test compression. MS Labs Enhanced MS2 ECU for the 01-05 and 04-05 MSM out now! - Miata Turbo Forum - Turbo Kitten is watching you test compression. TPIC8101 DSP chip, it says @Lex, you should develop some sort of "external knock module" for DIYPNP/MS2, I'd buy it! On the miata forum I believe there would be a good market for it, assuming price was reasonable (they are cheap asses) |
Quote:
i need to get with the program and make use of a knock sensor in my build. |
Damn you all, got me thinking about picking up a MS3X again.... decisions, decisions. |
Quote:
MS3x Knock Module Settings Thread - Miata Turbo Forum - Turbo Kitten is watching you test compression. |
Quote:
| All times are GMT -7. The time now is 06:40 AM. |
