Miata MX-5
> Miata - Engine, Transmission, Driveline
 Old 06-06-2011, 10:11 PM   #1
nycMS3's Avatar
Posts: 1,067   (View Stats)
nycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the world
Groans: 129
Default Helped a friend install a new front mount on his MSM
A buddy of mine (Also a member here, big5xmurf) asked me to help him install a new core. I said SURE! how hard could it be...... well it wasn't hard just I didn't think we would be forced to use tools that shouldn't be used on cars.
I carefully removed his bumper and carefully because even though its a 2004 msm, the car only has 7k original miles. I didnt want to scratch or break anything. Here is the bumper next to my car.
This is the core that will be replacing the oem one, quite the difference.
We first cut the oem core out which went smooth, we used a Rigid battery powered hand tool with a cutting wheel. Took sometime but did the trick.
We then mounted the core and that was a bitch, the couplers seemed to small and one of the t-bolt clamps was definetly too small, so we used a worm clamp. That resulted myself in getting stabbed with a screwdriver trying to get the tbolt clamp to fit
Once the core was mounted, my friend began to make the brackets to secure it to the car. This is how we did it, we used a metal grate, an axe and a brick.
After a few cuts, cigarettes and cursing we finally got everything finished. Reinstalled the splash shield and mounted the bumper
And a picture of his car in the garage, my ms3 and his sisters 3 (you can sorta see it)
Also im sure he will chime in soon, he has a few pictures as well. Especially of the brackets installed on the car
NATOR NJ/NY/FL
09 MS3 tuned by Nishan
nycMS3 is offline   Reply With Quote
The Following User Says Thank You to nycMS3 For This Useful Post:
i8urgti (06-17-2011)
 Old 06-06-2011, 10:17 PM   #2
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
looks pretty good
noodz of sister
I was really scared when you said "how hard could it be"
/TopGear
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
The Following 2 Users Say Thank You to PunjabiPlaya For This Useful Post:
predapio (06-07-2011), WAHBAM (09-07-2011)
 Old 06-06-2011, 10:21 PM   #3
messiahx's Avatar
Posts: 59   (View Stats)
messiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to behold
Looks good. Lol at tiny stock ic. I always laugh at those. Ghetto fabbed brackets are the way to go. We used a similar process (except we had an actual vice, which helped) to mount aaronc7's ic. Mine is mounted with some angle bracket used for corners with drywall.
messiahx is offline   Reply With Quote
 Old 06-06-2011, 10:35 PM   #4
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
Home Depot + Ebay = Tuning FTW lol
The brackets were made from 1/8" aluminum strips, lots of trial and error. Learned some things about working with AL. Like bend first then drill, else it'll bend right at the hole. AL also heats up fast, and transfers it fast too (drilling cutting), so have a way to constantly cool it.
We had to relocate the horn... it sounds either broken or vintage, depending if you're the half full/half empty kinda guy.
Here are the individual brackets, 3 total
And one more of the final product
bigx5murf is offline   Reply With Quote
The Following 3 Users Say Thank You to bigx5murf For This Useful Post:
Ms3_Miami (12-22-2011), nycMS3 (06-06-2011), predapio (06-07-2011)
 Old 06-06-2011, 10:52 PM   #5
mazdaspdmike's Avatar
Posts: 784   (View Stats)
mazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the world
Groaned at 50 Times in 30 Posts
this looks awesome, loving the black! You lucky sob with your pre-installed piping and just having to cut the core out xD quite a bit harder for us MS3 guys.
'12 Ford Focus SEL
mazdaspdmike is offline   Reply With Quote
 Old 06-06-2011, 11:38 PM   #6
bigx5murf's Avatar
yea, I wanted to do the black IC since I haven't really seen anyone do it around here. It helps the core was cheap, and comes with a lifetime warranty. People on the miata forums are hating though, claiming the silk-screened "mishimoto" defeats the purpose of a black ic lol
Oh yea, almost forgot this pic... looks like an epic phail about to happen, OSHA would not approve lol
The Following User Says Thank You to bigx5murf For This Useful Post:
 Old 06-07-2011, 06:04 AM   #7
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Looks good.^^^^ Hey Krys, did you burn your hair off or something?
Makes you look like a Lightbulb head.
What a lovable bunch we are!!
The Following User Says Thank You to predapio For This Useful Post:
nycMS3 (06-07-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f19/helped-friend-install-new-front-mount-his-82736/
The 04-05 Mazdaspeed Miata Thread - Page 77 - ClubRoadster.net This thread Refback 11-29-2014 05:21 PM
front mount or top mount? occschemguy MazdaSpeed 3/6 - Turbo Induction 32 05-06-2008 10:15 PM
Musician's Friend Fender American Series Telecaster Electric Guitar $749.99 Free Shipping at Musician's Friend Haltech Hot Deals Section 0 04-12-2008 12:31 PM
Page generated in 0.28484 seconds with 25 queries
