Miata MX-5
> Miata - Engine, Transmission, Driveline
  • 1 Post By Alejo_NIN
 Old 09-25-2013, 01:17 PM   #1
Alejo_NIN's Avatar
Posts: 1,700   (View Stats)
Alejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the world
Groans: 88
Groaned at 186 Times in 83 Posts
Default Miata Turbo Build..done..semi-right.
Well, this is my brother's car.
i'm helping him build it.
He bought this miata for 750$ with a blown motor...the piston shattered and luckily did not scratch the cylinder wall...yep..cylinder #4..probably cooling issue.
we removed the engine and took it to get machined, hopefully getting it back in two days.
this si the car when we got it
when removing engine:
over the weekend, we got a little carried away on the "removing stuff we don't need" and ended up completely rmeoving:
dash board, carpet, a/c, heater core, and pretty much everything byt the wiring.
my brother getting ---- about cleaning...
end result as it sits on my driveway right now:
the brother helping disassemble the engine:
note*this is his first time ever playing with an engine...it bit him back and he bled ....bad!
we then proceeded to power wash away 15 years of dust and other disgusting matter form the engine bay and inside the car.
we are having fun and have big plans for the car.
we are on a budget but also want to do things right.
the plan is to go boost...no idea how yet, but we'll figure it out.
engine wise we are probably going with either weiseco or supertech pistons @ 9.5~:1CR, Eagle Rods, DIYPNP for management, rmeoving EVERYTHING that is not necessary to drive the car including a radio!, ARP headstuds, skunk2 throttle body(gotta convince him of this).
the car already has a good stage2 clutch by ACT, transmission is sound.
we have a lot to learn and believe me, we've been reading non-stop.
i know these types of forums and won't be asking stupid questions wihtout searching extensively before.
hope to get a lot of help from you guys!
by the way, the car is a '96 STO Miata on Montego Blue (faded color though)
i believe it has what appears as stock rims...they are getting changed.
i'll let my brother update you more on the looks of the car since i am not really interested in that
he currently drives a mlightly modded MS3 '12, i drive a completely stock MS3 '10 and i also own a heavily modded mazda protege MP3 '01 @ 14PSI with mods too long to list...
Update: 3/8/2013
Total money invested: 350$
Machine Shop did the following:
cut the head slightly..didn't have to cut too much becasue head wasn't warped or anything
seated the valves, overall cleaning...thing is beautiful
cleaned the block, .20 over bore and honing
cleaned the crank, .10 rod bearing, .10 crank bearings, polished.
this is AWESOMENESS
nothing else done to the block.
was advised not to replace the coolant seals...
project keeps moving foeward.
Update: 3-13-2013
interior starting to take shape. changed the carpet for a NB's black carpet.
it seems like convertible top won't drop it..minor modifications might have to be done
Update 3-16-2013
carpet in, seats in, painted metal pieces on top of the gas tank, they were all rust-free but wanted to future proof.
install convertible top.
[IMG][/IMG]
[IMG][/IMG]
Latest
started building the engine
installed pistons, rods, oil squirters, crank shaft
all bearings were clevite
using lucas assembly oil FTW
original reason why the motor blew.
some updates
decided to paint manifold black
timed:
EGR block off plate done
coolant bypass block off plate done
the progress so far.
SS Braided Brake lines all around.
yes, i need rotors, aSAP
yes, had to..because the house makes a weird turn. so we measured and cut.
here is first start up:
as promised, the old rotors didn't last long...
did some more modifications. fixed the convertible top, and installed a break out strip for the gauges..i just wasn't happy with the way the wiring was done.
wired up fuel, coolant temp and other gauges.
car idles much better now and it no longer has the issue of not starting when hot.
we found out that the timing was off by like 1 tooth, so rmeoved timing belt and redid timing, set the timing to zero with stock ECU, wired in megasquirt and configured timing..car idles so much better now.
also wil be replacing the MAF with a IAT and installing a boost controller from DIYAutoTune.
more wiring than i'd like to see,,,wire tuck will be done prior to paint.
radonelement.com
Alejo_NIN is offline   Reply With Quote
The Following 9 Users Say Thank You to Alejo_NIN For This Useful Post:
Chief_Wiggum (10-26-2013), Hush (09-25-2013), jk_ms3 (09-25-2013), Koke382 (10-19-2013), kritz (09-25-2013), obijack (10-19-2013), SpencerC (09-25-2013), trancehead (09-25-2013), turbo test (10-21-2013)
 Old 09-25-2013, 01:24 PM   #2
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Nice build brownie!
Nator is what it does.
 Old 09-25-2013, 01:28 PM   #3
trancehead's Avatar
Posts: 1,841   (View Stats)
trancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the worldtrancehead is the leader of the world
Sexeh
2012 CWP MS3
2014 SWP WRX
2014 SWP Mazda 3
trancehead is offline   Reply With Quote
 Old 09-25-2013, 01:35 PM   #4
Alejo_NIN's Avatar
Groans: 88
still mcuh to go...
we just got the FMIC yesterday:
we will have it installed by a guy who will weld as many pieces as he can..this is a universal kit but he will weld what he can to have the leats amount of couplers.
then, he will also do a stainless steel exhaust.
we haven;'t deiced yet on what muffler to use.
radonelement.com
 Old 09-25-2013, 01:35 PM   #5
SpencerC's Avatar
Posts: 2,159   (View Stats)
When you are all done, can you get to work on mine?
Thanks.
Seriously, looks good.
Alejo_NIN (09-25-2013), kritz (09-25-2013)
 Old 09-25-2013, 01:37 PM   #6
hamfisted's Avatar
Posts: 92   (View Stats)
hamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant future
Looks good. I had a '97 that I put a JR M45 supercharger kit on, and it was a blast. Engine management (piggyback) was definitely the weak spot, so you're on the right path using the Megasquirt.
hamfisted is offline   Reply With Quote
The Following User Says Thank You to hamfisted For This Useful Post:
 Old 09-25-2013, 01:41 PM   #7
Alejo_NIN's Avatar
Groans: 88
you def can't go wrong with a full management
yes, it will be harder to work with but once you are done...the possibilities are endless
currently i am tuning off of AFRs and MAP
i will be able to add meth inj and have it work off RPM/SPEED/BOOST/ anything!
will also be able to do flat shifting and launch control.
i can even to anti-lag
i cna control so many things like A/C, intercoler sprayer..man...it is gonna be awesome!
i cna even wire in a external waterpump and just remobve the one from the car...get rid of the thermostat altogether and only run the pump when i want to....
this is my brother's car..but soon, i will be going MS on my protege (pictured on my sig)
radonelement.com
Last edited by Alejo_NIN; 09-25-2013 at 01:41 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Alejo_NIN For This Useful Post:
 Old 09-25-2013, 04:02 PM   #8
kritz's Avatar
Groans: 95
Anti lag huh, So no timing and rich as fuck?
 Old 09-25-2013, 06:59 PM   #9
Alejo_NIN's Avatar
Groans: 88
no timing, rich as fuck..and a special sparkplug on the exhaust manifold before the turbo...
kritz likes this.
radonelement.com
 Old 10-19-2013, 05:36 PM   #10
Alejo_NIN's Avatar
Groans: 88
more updates
FMIC install
pipe size : 2.25
CXRacing Intercooler
took 9 hrs..wtf?
radonelement.com
 Old 10-19-2013, 05:43 PM   #11
jeymz's Avatar
Posts: 163   (View Stats)
jeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond repute
Looks great, wish I had the skills to do something like this.
2011 LSM w/ Tech Pkg
Cobb AP - OTS Stage 2 | Ultragauge | Autotech HPFP Internals | DENSO ITV22s | Forge BPV v2 | CS TMIC | CS Boost and BPV Tubes | CPE Nano SRI w/ Amsoil filter | CS TIP | OBX race pipe | CPE Stage 2 RMM | JBR PSMM 80 | JBR TMM 80 | JBR Shift knob, weight, bushings | JBR RSB | JBR Rear camber arms | Sure SSP | MD OCC | Corksport Springs | Bilstein Sports | FCM Rear Bumpstops | FoMoCo tranny fluid | CS Tow Plate | CS LED Kit | CS Fog LEDs
jeymz is offline   Reply With Quote
The Following User Says Thank You to jeymz For This Useful Post:
Alejo_NIN (10-19-2013)
 Old 10-19-2013, 05:56 PM   #12
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
Fuck now I miss my miata even more now......
Good build tho. Looks sick
sent from my peepee
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 10-21-2013, 07:47 AM   #13
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
sent from my peepee
Wait didn't you just buy the miata this year? What happened?
Yeah I've been neglecting msf lately, gotta catch up on things.
Sent from my EVO using Tapatalk
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
The Following User Says Thank You to turbo test For This Useful Post:
Koke382 (10-21-2013)
 Old 10-21-2013, 08:47 AM   #14
Koke382's Avatar
Groans: 32
I sold it :/ it was literally just sitting collecting dust lol. Im buying another one this coming year cuz I miss that shit lol.
Sold it cuz I needed money to move to our new place. We needed some new furniture.
sent from my peepee
1993 Red Na6
The Following 2 Users Say Thank You to Koke382 For This Useful Post:
Alejo_NIN (10-21-2013), turbo test (10-21-2013)
 Old 10-21-2013, 08:38 AM   #15
kritz's Avatar
Groans: 95
It is still ghey, but just a little faster.
The Following 2 Users Say Thank You to kritz For This Useful Post:
ABolewski (11-14-2013), Alejo_NIN (10-21-2013)
 Old 10-21-2013, 09:23 AM   #16
Zpuhalla's Avatar
Posts: 244   (View Stats)
Zpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the world
Groaned at 32 Times in 14 Posts
Subbed.
ATP GTX3067R, ATP Catted DP, HTP 3" Intake, UR FMIC, Stratified GA, Stratified EBCS, Bilstein B8's, Cobb Springs, JBR RSB, JBR Mudflaps, JBR OCC, GFB 50/50 BPV, Autotech Internals, JBR Shifter Bushing, Cobb RMM, Cobb AP
Zpuhalla is offline   Reply With Quote
 Old 11-14-2013, 02:48 AM   #17
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
Wow you mofos work fast! Are you using a Haynes manual? If so, don't trust all their torque specs, especially if you're using aftermarket fasteners. For example, ARP head studs require higher torque spec than factory.
bigx5murf is offline   Reply With Quote
 Old 11-14-2013, 03:37 AM   #18
ABolewski's Avatar
Posts: 1,279   (View Stats)
Sick build! I'm hoping to do exactly this someday.
(sold)
 Old 06-02-2014, 09:11 PM   #19
Alejo_NIN's Avatar
Groans: 88
thought you guys deserved an update.
so here it is:
after 1 year and 2 motnhs...it finally starts
it's been a while since a last update
so far this is what it looked like before the car went under the knife for about 3 more times...
old old old
replacing bumpers and fenders
giving some life to otherwise boring parts....wrinkle paint valve cover
at this point i really thought to myself: i need to trim these wires
i attempted to make it look nice but those wires and fuse box...they had to go
so out comes the dash board, again
trimming, fixing, taping, rolling
cleaning ziptying etc
dash back on
still not happy tho
it doens't look that bad but it could be better
so out comes the dash again
and now the whole wiring harness comes out as well.
time for some trimming and soldering
the pile on the right is all unused wiring
take advnatage of the situation to install MSM pedals
this is the passenger side wiring harness..not much to do to this one
taking apart fuse box (tags: miata fuse block fuse box fuses relocation move dash)
took off all the leads
removed the airbag
getting ready for paint
finished fuse box relocation under dash
starting to lok better...could be better tho
wrinklepainted my old oil catch can and installed
driver side engine bay cleaner
dash back on, pedals installed, painted steering rack back on
bucket of wires...to be sorted and thrown out
first wash in 1 yr
the proof is in the pudding. drove the car to a friends house to show off
installing SSQV
installing EBC for the MSPNP2
venting it for now while i figur eout what to do
need to figure out an intake for this as well
that's all
so here it is:
old old old
dash back on
still not happy tho
removed the airbag
first wash in 1 yr
installing SSQV
that's all
radonelement.com
Last edited by Alejo_NIN; 06-02-2014 at 09:11 PM. Reason: MSF Database - Automerged Doublepost
bigx5murf (06-03-2014)
'97 Turbo Miata Build - Water-toAir IC Alejo_NIN Miata - Forced Induction 17 11-14-2014 07:53 PM
aaronc7's Turbo Miata Build aaronc7 Miata - Forced Induction 733 07-15-2014 09:55 PM
Miata BP Build Midnitehours Miata - Engine, Transmission, Driveline 18 06-11-2013 06:11 PM
NA Miata 1.8 Turbo Build. Big Question! Pintozoz Miata - Engine Conversions 0 04-15-2013 07:15 AM
3 years on here, finally making a semi build thread speedms6 MazdaSpeed 3/6 - Build Diaries 0 11-20-2012 08:19 PM
Page generated in 0.65509 seconds with 30 queries
