Miata MX-5
> Miata - Car Audio & Electronics
 Old 08-03-2010, 12:51 PM   #1
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
Default upgrading miater's sound system
i know nothing about audio.
there are four total speakers right now, two in each door. i have the bose package.
where should i start? the shit just isn't loud enough.
start with a head unit?
or upgrade the speakers?
if i want to amp the speakers, how many channels? 2 or 4?
head units have different wattage ratings...can i go the cheap route and get a 50watt head unit?
 Old 08-03-2010, 04:12 PM   #2
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
In before wiring fail leads to a car fire.
What a lovable bunch we are!!
The Following 2 Users Say Thank You to predapio For This Useful Post:
FreeFlyFreak (08-04-2010), woowoooooo (08-03-2010)
 Old 08-03-2010, 04:13 PM   #3
phillyb's Avatar
Groans: 1,940
oh no...
i'm not doing this shit...
 Old 08-03-2010, 04:24 PM   #4
woowoooooo's Avatar
Posts: 210   (View Stats)
woowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the worldwoowoooooo is the leader of the world
philly if you catch the car on fire you get more weed money
Originally Posted by Addikted To Boost View Post
the car knew better than to try to race the ms3, so it decided suicide was the best available option
woowoooooo is offline   Reply With Quote
 Old 08-03-2010, 05:09 PM   #5
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Doesn't the stock Miata sound system sound like two fat hairy guys butt fucking? Jeez Philly, I thought you'd enjoy that shit.
 Old 08-03-2010, 05:19 PM   #6
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
New radio up front, 8" comps in the front door(you can fit a massive speaker in the doors of those things), a good two channel amp for them.... Swap the rears for a decent coaxial and run them off the radio...
 Old 08-03-2010, 05:19 PM   #7
Alpine Head Unit
DEI Class D amp for subs
DEI Class A amp for Mids/Highs
Infinity Kapa, Boston, MQ Quart, Focal for components
Custom sub enclosure for trunk
Should fuckin rock.
 Old 08-03-2010, 05:30 PM   #8
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
we can do audio easily philly.
shit man, after all the fail we have been through audio is relatively safe
 Old 08-03-2010, 06:58 PM   #9
Groans: 60
I passed an intrepid on the way home that was burned out from the rear doors back. I bet his buddy to him "we can do that amp shit easy"...
Come by my shop in NC Philly, and I'll give you half off of double price....LOL
The miata is pretty easy to work on though, just watch the dash around the radio, that plastic gets brittle after a few years in the sun..
 Old 11-25-2010, 08:58 PM   #10
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
Clearwater Audio Products
and maybe a new head unit
bigx5murf is offline   Reply With Quote
 Old 11-25-2010, 09:18 PM   #11
neotide87's Avatar
Posts: 1,388   (View Stats)
neotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the world
a new headunit I doubt would put out 50 watts I thought they would put out maybe 20.
I would start with speakers then go from there. My next move is a 4 ch. amp for my Infinity Kappas I have in my doors then to sub/amp off of factory stereo
2007 Mazdaspeed 3 Sport SSM
Corksport SRI / HPFP Internals / Front Arm Bar // Cp-e RMM 75d // JBR RSB / IM & TB Gaskets / Bypass Valve Hose // Cobb AP / Shifter Weight // SU Shifter Bushings // Sure TIP // Viper 5901
neotide87 is offline   Reply With Quote
 Old 11-25-2010, 09:38 PM   #12
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
in older cars usually new headunit does the most... was the case in my old 99 civic. I added speakers after headunit, and it helped some of the clarity and low end sound, but headunti really did the most, having more power behind everything
neotide87 (11-25-2010)
 Old 11-27-2010, 12:16 AM   #13
messiahx's Avatar
Posts: 59   (View Stats)
messiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to beholdmessiahx is a splendid one to behold
Go with a new headunit (will make a huge difference, and yes, they can put out 50w x 4) and some better 6" speakers for the doors. Maybe tweeters (probably make the biggest difference with the top down). You can get some that you can stick to the top of the dash or some you can put higher up in the door. Personally, I wouldn't put too much $$ into it just for the fact that regardless of what you do, it's still not gonna sound great because of the car being a convertible.
messiahx is offline   Reply With Quote
Upgrading The Stereo mjwms3 2010 MS3 - Car Audio & Electronics 17 03-24-2010 02:13 PM
upgrading exhaust Vinnie MazdaSpeed 3 - Engine, Transmission & Driveline 21 02-18-2010 10:47 AM
sound system 06speed MazdaSpeed 3/6 - Car Audio & Electronics 18 08-24-2009 01:13 PM
Buzz sound when you hit Aux button w/Bose system lengbros MazdaSpeed 3/6 - Car Audio & Electronics 5 05-08-2009 04:13 PM
Protect your sound system with smarts Haltech Automotive News 0 07-14-2008 02:30 PM
Page generated in 0.31535 seconds with 30 queries
