> MazdaSpeed 3/6 - Appearance
  • 1 Post By romeox929
 Old 04-17-2010, 09:34 PM   #1
OG_MS3's Avatar
Posts: 2   (View Stats)
OG_MS3 will become famous soon enough
Default hood spacers will they fit the ms3?
good way to direct heat out ....sorry if this is the wrong section.
OG_MS3 is offline   Reply With Quote
 Old 04-18-2010, 08:13 AM   #2
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
This belongs in the following section.
Rice of the Day
Beanfab / Tuned by Nishan
The Following 15 Users Say Thank You to doubleflusher For This Useful Post:
Addikted To Boost (04-18-2010), danesti (04-21-2010), Dash08 (04-18-2010), Driverman5777 (04-21-2010), felt (04-18-2010), FreeFlyFreak (04-18-2010), HLR Element (04-18-2010), IneptSideKick (05-21-2010), m4tic (04-18-2010), madvillain (04-18-2010), mtnrunner (04-21-2010), Night Wolf (05-11-2010), nyghtryder (05-23-2010), phillyb (04-18-2010), rigor (04-18-2010)
 Old 04-18-2010, 08:16 AM   #3
c.a.t.a.p's Avatar
Posts: 67   (View Stats)
c.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to all
where did you find those at im thinking about picking up a set
c.a.t.a.p is offline   Reply With Quote
 Old 04-18-2010, 12:31 PM   #4
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Looks like you were in a crash and went to a shitty body shop.
Suspension:
The Following User Says Thank You to FreeFlyFreak For This Useful Post:
2007speed3 (05-21-2010)
 Old 04-18-2010, 12:47 PM   #5
HLR Element's Avatar
Posts: 2,477   (View Stats)
HLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the worldHLR Element is the leader of the world
Groans: 109
I think i was one a different forum where they were trying to see if that even helped at all... i forget, cause with the hood properly down it creates certain areas of high and low pressure. But yea... it looks like crap
Mk7 GTI
HLR Element is offline   Reply With Quote
 Old 04-18-2010, 12:49 PM   #6
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
On the ms6 you can just remove the rubber molding on the back of the engine bay, and it'll let heat out.
Whether or not it helps, i have no clue.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 07-05-2019, 01:06 AM   #7
mike16241's Avatar
Posts: 46   (View Stats)
mike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of light
I like this idea. Im top mount TS gtx3576r with 3.5in intake and stock battery location. Just barely fits under the hood. Risers would allow me a 4in ontake but i hate the look. Think i'll pull the weather strip at the back. Relocate battery do a nice big 4in.
mike16241 is offline   Reply With Quote
 Old 04-18-2010, 12:58 PM   #8
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Somebody already tested these things on an MS3 to see if it actually decreased temps and it was major fail.
No benefits what so ever. The only thing you get is a hood that doesn't line up and looks like shit.
Stop wasting your time and money on these rediculous mods. Buy real parts that make real differences. Leave this stupid shit to all the ricers, they're good at polishing shit.
this forum serves 2 purposes
 Old 04-18-2010, 01:22 PM   #9
OG_MS3's Avatar
What so rice about it? Hood spacers allow hot air to be able to circulate out of the engine bay. very popular in Japan, especially for highly modified cars.
all i wanted to know thanks
Last edited by OG_MS3; 04-18-2010 at 01:22 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-18-2010, 02:13 PM   #10
m4tic's Avatar
Posts: 4,928   (View Stats)
when your car is highly modified.... that is >400whp , let us know
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 04-18-2010, 01:23 PM   #11
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
The idea is to use the high-pressure area created at the windshield to blow air down into the engine bay, however this generally works much better on older cars that don't have windshields at such a high rake.
Either way, it looks like someone broke something.
 Old 04-21-2010, 12:10 AM   #12
romeox929's Avatar
Posts: 207   (View Stats)
romeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud of
stop talking for those that seem to know everything. it is not rice, but IMO function>form.
import tuner did a little segment on these "JDM hood props"
JDM Hood Prop - Import Tuner Magazine
ESB Jiu JItsu likes this.
-cookie cutter mods-
romeox929 is offline   Reply With Quote
 Old 05-21-2010, 03:12 PM   #13
I gotthatzumzum's Avatar
Posts: 552   (View Stats)
I gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the worldI gotthatzumzum is the leader of the world
Thats actually a suprising result. I still don't think I would do it though... I think it looks like crap.
Originally Posted by martyxattack View Post
i wish more than like 2 colors didnt look stupid on my fucking brightest red ever car
I gotthatzumzum is offline   Reply With Quote
 Old 04-21-2010, 10:08 PM   #14
ispypsi's Avatar
Posts: 303   (View Stats)
ispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the world
Is your car overheating? No? Then don't buy them.
"But they're JDM YO!"
Dan - '08 MS3, some kinda silver
ispypsi is offline   Reply With Quote
 Old 05-21-2010, 04:09 PM   #15
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Kdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the world
sofa king
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 07-12-2011, 12:31 AM   #16
zoom-zoomhatch's Avatar
Posts: 76   (View Stats)
zoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to behold
If they work with the top mount, if it would get bat's down any at all it would be worth it if it isn't rediculous expensive. In for any real insight that isn't just sighting the obvious, it's fugly, but so is 120+ bat's on the highway all summer long.
zoom-zoomhatch is offline   Reply With Quote
 Old 07-12-2011, 12:47 AM   #17
theschrum's Avatar
Posts: 1,031   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
More rice than function.
I must admit that I had this on my SE-R back in my ricer days. With a TMIC, I could see these having more of an adverse affect for sure.
And BTW, I just used washers.
06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block...
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
wheel spacers ZoomByU Wheels & Tires - BLACK 10 02-24-2010 04:57 PM
Got Spacers? superskaterxes Appearance - BLACK 24 07-31-2009 08:47 AM
Would I need spacers? Element MazdaSpeed 3/6 - Wheels & Tires 1 04-27-2009 04:43 PM
wheel spacers? tbone Mazdaspeed3/6 General Discussion 3 11-12-2008 12:34 AM
Page generated in 0.36591 seconds with 36 queries
