> MazdaSpeed 3/6 - Appearance
 Old 02-05-2016, 01:37 PM   #1
MS6-Kyle's Avatar
Posts: 26   (View Stats)
MS6-Kyle will become famous soon enough
Default MS6 AP Interior Location
Where does everyone have their AP mounted??? Im getting one soon and i have my eyes on this mount
Robot CheckRobot Check
Would probably put it in the same location
Just wondering how everyone else has theirs mounted so i can see what i would like lol
If there is a thread already like this i apologize... ( I did a search and didnt find anything)
2006 Mazdaspeed 6: BNR S3, COBB AP V3, CP-E TMIC, AUTOTECH HPFP, EGR DELETE, 3" HTP INTAKE, 3" CATLESS DOWNPIPE, JBR EBCS and RETROFITTED HEADLIGHTS
MS6-Kyle is offline   Reply With Quote
The Following User Says NO Thank You to MS6-Kyle For This Un-useful Post:
Vansquish (02-07-2016)
 Old 02-05-2016, 02:24 PM   #2
Omega's Avatar
Posts: 441   (View Stats)
I use a windshield mount on the bottom left hand side of my windshield, route the OBD2 cable up along the steering column to that side. I have a zip tie stopper for the cable so I can even close the little cubby on it without the wire dangling everywhere.
I just use my phone mount and change out the backing plate.
2006 Super Clean BCM MS6
 Old 02-05-2016, 02:50 PM   #3
MS6-Kyle's Avatar
I think im gonna do this
 Old 02-07-2016, 12:03 PM   #4
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
There are countless posts here about AP mount options... Here's one I did with stuff already in the garage, but the aluminum & velcro are easily found
Something to consider for your mount- inexpensive & not permanent-
1/8 inch aluminum angle, 1/2 inch on each side, and some velcro. Both readily available at the local hardware store, and the stock might even be found for free from the local machine shop....
Total cost should be under $10 if you buy both
It just tension fits on the dash, between the soft dash and hard center console. I route the wire up by the steering column.
340hp / 371tq
MS3Shadow (02-07-2016), Vansquish (02-07-2016)
 Old 02-07-2016, 12:32 PM   #5
wes3id's Avatar
Posts: 611   (View Stats)
i use the windshield mount for my accessport now, so i don't have to look down. the original jbr mount i've had for years, i use for my ipod.
wes3id is offline   Reply With Quote
 Old 02-07-2016, 01:22 PM   #6
DatWhiteMS6's Avatar
Posts: 98   (View Stats)
DatWhiteMS6 is a splendid one to beholdDatWhiteMS6 is a splendid one to beholdDatWhiteMS6 is a splendid one to beholdDatWhiteMS6 is a splendid one to beholdDatWhiteMS6 is a splendid one to beholdDatWhiteMS6 is a splendid one to beholdDatWhiteMS6 is a splendid one to behold
I just mounted mine on the flat part of the center under the vents. Works fine.
2006 Mazdaspeed 6 GT - Whitewater Pearl Mica
Cobb XLE bpv // HTP 3.5" WP Intake // BNR S4 // Corksport TMIC // Doc Race Manifold // Cobb 3 port EBCS // Bosch 3-Bar // Corksport internals // CPE catted 3" dp // CPE dual exit CBE w/o resonator // Denso ITV22's // Cobb AP v3 // Stoptech Slotteds // EBC Red Stuffs
333 awhp // 343 awtq so far @ 20 psi
More to come...
Freektune loading . . . .
DatWhiteMS6 is offline   Reply With Quote
 Old 02-08-2016, 12:10 PM   #7
MS6-Kyle's Avatar
So many options.. this is gonna be a tough choice
 Old 02-10-2016, 05:06 PM   #8
42boxer's Avatar
Posts: 52   (View Stats)
42boxer is a jewel in the rough42boxer is a jewel in the rough42boxer is a jewel in the rough
My cord is ran behind the dash so I have nothing exposed. Even if the accessport is out theres is 6" of cord that sticks out
2007 Mazdaspeed6
http://www.mazdaspeedforum.org/forum/forum/f415/42boxer-2007-mazdaspeed-6-a-191641/#post2929172
2008 Mazda 3: sold
2000 Toyota Tacoma: sold
42boxer is offline   Reply With Quote
 Old 02-10-2016, 05:25 PM   #9
PhillyCheese's Avatar
Posts: 226   (View Stats)
used the mount that came with the ap and just drilled a couple holes into the console and used a couple nuts and bolts
File Type: jpg 10560336_10204522435961284_2191995279289170261_o.jpg (144.0 KB, 25 views)
MOD LIST
UNDER CONSTRUCTION
 Old 05-04-2016, 06:48 PM   #10
tomazws's Avatar
Posts: 59   (View Stats)
tomazws has much to be proud oftomazws has much to be proud oftomazws has much to be proud oftomazws has much to be proud oftomazws has much to be proud oftomazws has much to be proud oftomazws has much to be proud oftomazws has much to be proud oftomazws has much to be proud oftomazws has much to be proud of
Amazon.com: Car Mount, Mengo Magna-Snap Magnetic Dashboard Or Window Car Mount For iPhone, Samsung, HTC, LG, Nexus, Blu, GPS, and More: Cell Phones & AccessoriesAmazon.com: Car Mount, Mengo Magna-Snap Magnetic Dashboard Or Window Car Mount For iPhone, Samsung, HTC, LG, Nexus, Blu, GPS, and More: Cell Phones & Accessories
This is the best Accessport mount. It's magnetic and you can just slap your Accessport onto it. Doubles as a cell phone holder.
tomazws is offline   Reply With Quote
CX7 owners location Fingerlicker CX-7 > General Lounge + New Member Welcome 4 11-09-2015 10:55 AM
EQ location? chry_spd MazdaSpeed 3/6 - Car Audio & Electronics 0 01-09-2013 10:43 AM
location joewarner CorkSport 3 10-24-2012 05:39 PM
Nozzle tap location nynhex 2010 MS3 - Fuel, Nitrous & Water Injection 9 06-13-2010 08:59 AM
Nozzle Location superskaterxes MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 19 01-08-2009 02:25 PM
Page generated in 0.33548 seconds with 28 queries
