> MazdaSpeed 3/6 - Appearance
Like Tree90Likes
 Old 09-26-2015, 12:20 AM   #561
calinflorinalexandru's Avatar
Posts: 90   (View Stats)
calinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud of
Groaned at 32 Times in 15 Posts
This is my dirty and messy engine bay
Silver Mazda 6 MPS /Built Engine/ GramLights 57xtreme 18x8.5 et45 \ Vredestein Ultrac Vorti 225x40R18
calinflorinalexandru is offline   Reply With Quote
 Old 09-27-2015, 02:39 PM   #562
theurgy's Avatar
Posts: 2,580   (View Stats)
This is from the work I did last night, installed my BNR s3, Steedspeed Exhaust Manifold and JBR FMIC Undermount kit, and JBR 3" Fullpath Intake.
Still need to rerun all the vacuum lines for black (To get rid of all the blue in my engine bay now). Might figure something out with a vacuum block or something (kinda tired of running T's everywhere).
 Old 09-27-2015, 02:47 PM   #563
torquemaniac's Avatar
Posts: 733   (View Stats)
Built 2011 CX-7
mituc, Turbo gI and Swinger13 like this.
2011 CX-7 AWD 2.3 turbo
The Following 7 Users Say Thank You to torquemaniac For This Useful Post:
Funkster777 (09-29-2015), Micha (10-01-2015), mxlplx71 (10-01-2015), NCspecV81 (10-03-2015), speed3 britz (10-02-2015), Swinger13 (11-27-2015), TRBLSM (10-01-2015)
 Old 10-01-2015, 12:26 PM   #564
cam1391's Avatar
Posts: 326   (View Stats)
Built 2011 CX-7
As incredible as what @torquemaniac; did, its mind blowing that he did ALL of the welding AND fabrication HIMSELF!
This guy is a god in my book
Turbo gI likes this.
 Old 10-01-2015, 01:38 PM   #565
theurgy's Avatar
I agree, a CX-7 is not an easy platform to mod and build for.
Well done and your engine looks very clean and well sorted.
Kudos.
 Old 10-01-2015, 06:34 PM   #566
MortalMechanica's Avatar
Posts: 165   (View Stats)
MortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond reputeMortalMechanica has a reputation beyond repute
stock but I take care of her and keep her clean as often as I can. Damn california road dirt.
MortalMechanica is offline   Reply With Quote
 Old 10-03-2015, 01:56 AM   #567
skoski17's Avatar
Posts: 1,235   (View Stats)
skoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the worldskoski17 is the leader of the world
Too much for you
skoski17 is offline   Reply With Quote
 Old 04-15-2016, 07:11 AM   #568
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
need to tuck lotsa wires.
Resurrection! Do you remember what color blue this is, thanks?
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 04-15-2016, 09:01 AM   #569
wes3id's Avatar
Posts: 611   (View Stats)
still a lot more to do, but coming along.
wes3id is offline   Reply With Quote
 Old 04-15-2016, 09:05 AM   #570
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
 Old 04-15-2016, 10:28 AM   #571
I think you might like blue.
sent from my Nexus 6P
wes3id likes this.
 Old 04-20-2016, 09:41 AM   #572
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
Groaned at 22 Times in 16 Posts
Swapped in a v8
2015 MUSTANG GTPP
gtlaw is offline   Reply With Quote
 Old 05-23-2016, 07:01 PM   #573
chemmedic's Avatar
Posts: 127   (View Stats)
chemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond reputechemmedic has a reputation beyond repute
Originally Posted by gtlaw View Post
Swapped in a v8
Are you serial?
chemmedic is offline   Reply With Quote
 Old 05-23-2016, 07:41 PM   #574
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Done... For now
Atomic41 (05-23-2016), mazdaspeedmyk (05-24-2016)
 Old 08-05-2016, 11:01 PM   #575
theurgy's Avatar
Figure I'd revive an old thread, here's my latest engine bay pics following a successful wiretuck:
darkcherry likes this.
torquemaniac (08-06-2016)
 Old 08-06-2016, 07:31 AM   #576
DAMN...you've got wireless coil pack
APEXistud likes this.
 Old 08-06-2016, 07:57 AM   #577
theurgy's Avatar
Hahahaha yeah, got them off eBay, company had "speed" in the name so they must be good.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f228/post-your-engine-bay-124832/
Painted engine bay This thread Refback 05-20-2014 03:09 PM
Painted engine bay This thread Refback 03-09-2014 09:23 AM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 1 04-13-2012 09:13 PM
streetunit marks engine build post ? jracer Mazdaspeed3/6 General Discussion 1 11-25-2010 05:23 PM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 0 07-10-2008 11:10 AM
Page generated in 0.36618 seconds with 33 queries
