> MazdaSpeed 3/6 - Appearance
 Old 02-04-2016, 02:16 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
Default Venting bumper for better cooling
I decided to do some cutting on my foglight panels to get better cooling to the power steering cooler as well as FMIC pipes once i get this damn cxracing core raised up where it should be. not finished with the cutting but just a rough idea. i think it will actually look pretty good...wouldn't really be able to tell unless you look hard. I just used a dremel to cut out the lattice area and the backing on the bumper. not finished yet, but what do you guys think?
wes3id is offline   Reply With Quote
 Old 02-04-2016, 02:57 PM   #2
Having the OEM front air dam in place probably does more for cooling and airflow than this will. It could be a good option for brake ducts. I think to make much use of any airflow, you'd have to direct it towards the PS cooler in some way.
BPV not venting properly broseph09 MazdaSpeed 3/6 - Turbo Induction 13 11-23-2014 07:45 PM
hood venting mason Mazdaspeed3/6 General Discussion 90 02-18-2014 06:18 AM
fucking venting bbjoy Mazdaspeed3/6 General Discussion 19 02-11-2011 11:20 AM
Page generated in 0.23409 seconds with 22 queries
