Autosports Area
> Drag Racing
Like Tree6Likes
  • 2 Post By Etipp98
  • 1 Post By MS3Shadow
  • 1 Post By HOCKEYNUBE
  • 2 Post By rodrigo
 Old 10-02-2015, 10:20 PM   #1
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Default 11.43@128
@HOCKEYNUBE; car. Couldn't get a good burnout all night, here is his best pass.
http://www.youtube.com/watch?v=EbVsc...ature=youtu.be
It wont embed for me...
Micha and MS3Shadow like this.
The Following 22 Users Say Thank You to Etipp98 For This Useful Post:
Cheapspeed (10-03-2015), Code Monkey (10-02-2015), cshunter (10-03-2015), DingoDave (10-03-2015), Easter Bunny (10-03-2015), h.h.sk1nny (10-02-2015), Hammology (10-28-2015), Hush (10-03-2015), Jester2552 (10-31-2015), JgamB (10-29-2015), Micha (10-03-2015), ms3blackmica (10-04-2015), MS3Shadow (10-03-2015), mxlplx71 (10-03-2015), qtrmile beast (10-15-2015), rodrigo (10-03-2015), Scare Dem (10-05-2015), sh4d0w (10-06-2015), sho (10-03-2015), Snyeed (10-03-2015), speed23 (10-03-2015), Vadim aka ScooteR (11-08-2015)
 Old 10-02-2015, 10:56 PM   #2
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
Nice run man. Two things for you to make improvements on that I can see right off the bat. 1: Those QTP's need a longer burnout to get warmed up. Try sitting in the box for 10 sec and then take the ebrake off, letting the car pull you out. 2: Air pressure looks too low. Those are happy at 10-15psi. Keep up the good work. Drop that 60' down and you'll be biting at 10s
h.h.sk1nny is offline   Reply With Quote
 Old 10-03-2015, 07:59 AM   #3
Fixed. Take off the s in https to embed.
MSF hasn't updated to include https://, only http://
sent from my Nexus 6P
Etipp98 likes this.
impossible (01-07-2016)
 Old 10-03-2015, 08:13 AM   #4
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Even if it wasn't a great run, the afterfires were fantastic.
EDIT: These are the diesel gears? Sounds like you were in 4th at the end of the run?
 Old 10-03-2015, 08:45 AM   #5
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Pu trans, but revving to 8200
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
The Following 5 Users Say Thank You to sho For This Useful Post:
Cheapspeed (10-03-2015), Easter Bunny (10-03-2015), Hammology (10-28-2015), Mauro_Penguin (10-06-2015), Micha (10-03-2015)
 Old 10-03-2015, 09:50 AM   #6
HOCKEYNUBE's Avatar
Posts: 144   (View Stats)
HOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the world
I was cutting 1.8 60fts all night, I was doing everything in my power to get a longer burnout, in this video I tried to pedal it, didn't work so great, in all the other passes its relatively thing same thing though. I was pulling right through the e brake
Tire heat is all relative to the track surface temp. Huge nasty burnouts arnt always needed, exspesially when it's low 50* outside. In this case a couple seconds sitting still would have been great and that's about it.
But that you everyone
2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller
HOCKEYNUBE is offline   Reply With Quote
The Following 4 Users Say Thank You to HOCKEYNUBE For This Useful Post:
Easter Bunny (10-28-2015), h.h.sk1nny (10-03-2015), Realgib3 (10-05-2015), sho (10-03-2015)
 Old 10-03-2015, 11:11 AM   #7
Cheapspeed's Avatar
Okay, makes more sense. I was just reading his signature, but thought 3rd on diesel gears would've gotten him through a 1/4.
 Old 10-03-2015, 11:34 AM   #8
sho
sho's Avatar
Yes. It's @HOCKEYNUBE; car .not etipp98's. he just posted it for hockeynube.
FD wheels
E48 mix
Tuned by Realgib3
The Following User Says Thank You to sho For This Useful Post:
 Old 10-03-2015, 04:19 PM   #9
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
this is what works best from my experience,
a) make sure you start the burnout on wet on the inside of the edge of the puddle
b) pump brake pedal 3 times all the way down and up , hold it there until ebrake is applied
c)yank the ebrake fully and i dont mean 3/4 way i mean until its hard to even release it
d) second gear bring up to 6500 or so
e) dump clutch and modulate throttle to ensure wheelspeed stays up , if you feel the rpms start going south bring it up to 7k
f) stay for 3-5 seconds spinning once you see tire smoke above BOTH front fenders
g) release e brake and back off the throttle as you pull forward
if you start the burnout in a spot that isnt too wet or one side is and the other side isnt it will be botched, if you dont put enough hydraulic pressure and physical pressure via cable the rear tires will roll , if you dont do 2nd gear u wont have enough wheelspeed to generate the right heat and the low speed will pull u out eventually
i know its alot to think about but that is the first step in ensuring a successful run ..... everything else about the video looks right fyi ... that is the only part that didnt and your 60ft reflects it
will look like this from outside
or like this on the inside (notice the vehicle does not move fwd until the e brake is released)
good luck man, nice work
The Following 16 Users Say Thank You to rodrigo For This Useful Post:
802MS3 (10-05-2015), amggilly305 (10-27-2015), amoosenamedhank (10-05-2015), Code Monkey (10-05-2015), DevinS (02-27-2016), Easter Bunny (10-28-2015), HOCKEYNUBE (10-05-2015), Jester2552 (10-31-2015), JgamB (10-29-2015), Mauro_Penguin (10-06-2015), mxlplx71 (10-05-2015), Realgib3 (10-05-2015), SarcasticOne (10-05-2015), Scare Dem (10-05-2015), TRBLSM (10-05-2015), WetzMS3 (10-05-2015)
 Old 10-05-2015, 12:58 PM   #10
HOCKEYNUBE's Avatar
^ is there anyway I can triple thank this guy! That's some great info, I will definitely try this next time!
tbcota25 likes this.
 Old 10-05-2015, 10:18 PM   #11
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
yes, go kick some ass at the track and get some low 1.7s and 11.2s ...always love watching good runs and people improving
 Old 10-06-2015, 09:03 PM   #12
HOCKEYNUBE's Avatar
Won't be happening this year unfortunately, but there is no doubt in my mind that I can bust out a lower 11, I don't think a 10 is achievable without a better driver mod... New fuel setup, new suspension setup, and prolly investing in actual slicks rather than QTPs... But on another note your previous how to post needs to be a sticky thread or something in the drag racing section
 Old 10-06-2015, 09:09 PM   #13
sh4d0w's Avatar
Posts: 565   (View Stats)
sh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the world
Groans: 45
lol dude dem back fire's are epic... Nice runs!
2010 Black MS3
Cobb AP // Cobb EBCS // Cobb Downpipe // Cobb RMM // JBR Tru 3.5'' Intake // JBR TMM // JBR PMM // JBR RSB // CP-E Cat Back // NGK One step colder plugs // GT 3071r // Azenis 615k // Bilstein PSS B14 Coilovers // Treadstone TR8 FMIC // Bully Stage 4 Clutch // Damon EGR Delete // Autotech HPFP // AEM V1 Meth Kit 50/50 // Freektuned 94 Oct
sh4d0w is offline   Reply With Quote
 Old 10-06-2015, 09:14 PM   #14
HOCKEYNUBE's Avatar
Gallons of meth, wot box, and ffsing at 8k+ will do that for ya!
 Old 10-06-2015, 11:19 PM   #15
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
qtps are ok ... but qtps on 15s is what u need ... or the m&h on 15s ... either one is fine... the 16 inch wheels limit your sidewall height which is the money maker in absorbing the initial torque hit off the line.
10s with 128 mph are mathematically achievable , drop a few lbs off the car ... we ran basically the same ET as u with no more than 121mph (re tapped the limiter but on a previos run it hit 121.xx ) ... at a track well known for being a big ole pile of shit.
11.49 @ 121 was easily achieved after 4 passes on a new motor of 415whp ... to knock off another 5/10ths we woulda needed at most 6-7 mph so 127-128 is the limit ... grant u the driver has 7 + years of ms3 drag racing so its not like u can get to that level overnight but its not that difficult really.
in the end, fuck 10s .... be faster today than u were yesterday and one day u look back and u wont believe how many seconds u shaved off the et in a few years
most importantly , have fucking fun .
donjohnk and Justin@Freektune like this.
The Following 9 Users Say Thank You to rodrigo For This Useful Post:
amggilly305 (10-27-2015), chaser27 (10-07-2015), DevinS (02-27-2016), Etipp98 (10-07-2015), Hammology (10-07-2015), Justin@Freektune (10-07-2015), pmartz16 (10-07-2015), Realgib3 (10-07-2015), sh4d0w (10-09-2015)
 Old 10-28-2015, 07:15 PM   #16
HOCKEYNUBE's Avatar
so @rodrigo; ill have you know that I'm installing a line lock in my car over winter... super cheap to do and that'll keep them rear wheels held while I can do a long enough burnout
 Old 10-31-2015, 09:11 PM   #17
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
good shit ... if it helps u stasy still and generate enough heat on the slicks then money well sprnt
Page generated in 0.41329 seconds with 26 queries
