Autosports Area
> Drag Racing
Like Tree16Likes
  • 9 Post By Justin@Freektune
  • 1 Post By ge3kspd
  • 1 Post By ge3kspd
  • 1 Post By calizoomzoom
  • 1 Post By rodrigo
  • 1 Post By JgamB
  • 1 Post By Justin@Freektune
  • 1 Post By rodrigo
 Old 10-16-2014, 06:24 AM   #1
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Default 11.54@125
As many of you know, been chasing 11's for a little bit. The ACT street disk, just wasn't up to the task. Everytime I would get a decent launch and 1-2 shift, it would slip like hell in 3rd and 4th. Finally got my 6puck installed. Started at 12.1 which was already better than the 12.2-12.4's I was getting, then managed 3 11.9's in a row. Made a couple minor adjustments to tire pressure and LC limiter, and managed to get myself an 11.54@125. So freekin pumped right now. lol
Next up is stiffen rear all the way stiff, go with less gas (sleeping at the pump and put way too much in) and pull rear seats out. Had pulled passenger seat and spare for these runs.
https://www.youtube.com/watch?v=u9dLiXnxKkQ
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 42 Users Say Thank You to Justin@Freektune For This Useful Post:
802MS3 (10-16-2014), 865ms3 (10-16-2014), Ayerspeed (10-16-2014), blam1 (10-16-2014), breakfstincluded (10-16-2014), bwspeed (10-16-2014), Cevaes_64 (10-16-2014), CockWarner (10-16-2014), Code Monkey (10-16-2014), daafisch (10-16-2014), dan7225 (10-16-2014), doubleflusher (10-16-2014), Easter Bunny (10-16-2014), helmetface (10-16-2014), Hush (10-16-2014), InkedInspector (10-16-2014), JgamB (10-17-2014), killer-ms3 (10-16-2014), Lakespeed6 (10-16-2014), maisonvi (10-16-2014), Matt H. (10-17-2014), Micha (10-16-2014), mmikepetch (10-16-2014), Monotonous ONE (10-16-2014), ms3blackmica (10-17-2014), mxlplx71 (10-18-2014), mzr0818 (10-16-2014), nindoja (10-16-2014), qtrmile beast (10-16-2014), Realgib3 (10-16-2014), rodrigo (10-16-2014), rymanmazda (10-17-2014), Scare Dem (10-16-2014), shaneski (10-19-2014), smoogs12 (10-16-2014), Swinger13 (10-16-2014), T2J (10-16-2014), taf0422 (10-16-2014), Vadim aka ScooteR (10-27-2014), WetzMS3 (10-16-2014), xxdjfate76xx (10-16-2014), Yatta (10-16-2014)
 Old 10-16-2014, 06:56 AM   #2
Good shit
Which turbo are you on now? You change so much I lose track. If you have a recent vdyno that would be awesome too.
Justin@Freektune (10-16-2014)
 Old 10-16-2014, 06:58 AM   #3
Good shit
My gtx3076 got killed by debris that got sucked in by a new intake. So I decided to just switch it up to a PTE5858. Essentially at the same power level as the gtx3076 due to being out of fuel. Here is my dyno chart
PTE 6062
633HP/523TQ
 Old 10-16-2014, 07:00 AM   #4
Dyno chart without all the numbers cut off?
Edit nevermind I interpolated.
What is the 5858 roughly equivalent to?
 Old 10-16-2014, 07:01 AM   #5
CockWarner's Avatar
Posts: 265   (View Stats)
CockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the world
Congrats!
2011 MS3
GT3071 EWG | Cobb AP v2 | Autotech Internals | HTP 3.5 | ETS TMIC | CP-E Downpipe | CP-E Triton | DIY PnP Intake Manifold |
Cobb XLE BPV | Grimmspeed EBCS | Bosch 3-Bar MAP | DM OCC | DM PMM | JBR 88 Duro RMM | JBR 88 Duro TMM | Kozmic EGR Delete | JBR TB TIG & Coolant Bypass
CockWarner is offline   Reply With Quote
The Following User Says Thank You to CockWarner For This Useful Post:
 Old 10-16-2014, 07:02 AM   #6
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
you have a 6 puck with pro-lite flywheel now?
The Following User Says Thank You to Cevaes_64 For This Useful Post:
 Old 10-16-2014, 07:04 AM   #7
5858 is equivalent to the gtx3076. They even spool the exact same
Yesssir
PTE 6062
633HP/523TQ
Last edited by Justin@Freektune; 10-16-2014 at 07:04 AM. Reason: MSF Database - Automerged Doublepost
Cevaes_64 (10-16-2014), Easter Bunny (10-16-2014), Lakespeed6 (10-16-2014)
 Old 10-16-2014, 07:13 AM   #8
CockWarner's Avatar
So, what's the plan from here? Weight-reduction and suspension work?
2011 MS3
 Old 10-16-2014, 07:27 AM   #9
Mostly just stiffening up my coil overs, and pulling my rear seat. Nothing crazy, but I think the the stiffer suspension and working on my shifting should see some nice gains
PTE 6062
633HP/523TQ
CockWarner (10-16-2014), Lakespeed6 (10-16-2014)
 Old 10-16-2014, 07:36 AM   #10
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
how much boost is that at?
Performance:
Stratified Tune in progress
 Old 10-16-2014, 07:43 AM   #11
28psi
PTE 6062
633HP/523TQ
Swinger13 (10-16-2014), WetzMS3 (10-16-2014)
 Old 10-16-2014, 07:49 AM   #12
Micha's Avatar
Posts: 3,436   (View Stats)
I want these feels.
Great job Justin.
I am slow again.
I modded it a little.
The Following 2 Users Say Thank You to Micha For This Useful Post:
Justin@Freektune (10-16-2014), WetzMS3 (10-16-2014)
 Old 10-16-2014, 08:20 AM   #13
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
This makes me want the 5858. Nicely done!!! Shit just scoots along!!
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 10-16-2014, 08:28 AM   #14
#WUTLIP
ge3kspd's Avatar
Posts: 201   (View Stats)
ge3kspd has disabled reputation
Good shit man. Inb4 Freek in the 10s soon!
Justin@Freektune likes this.
Atp Gtx2871r Hypnotic tuned with sprinkles of unicorn jizz.
ge3kspd is offline   Reply With Quote
The Following User Says Thank You to ge3kspd For This Useful Post:
 Old 10-16-2014, 08:57 AM   #15
Cevaes_64's Avatar
In before Justin breaks in the 10s before bryce
The Following 3 Users Say Thank You to Cevaes_64 For This Useful Post:
chaser27 (10-16-2014), Easter Bunny (10-16-2014), killer-ms3 (10-16-2014)
 Old 10-16-2014, 09:00 AM   #16
Honestly, I never thought in a million years my power level could get me there. But with the time I got, and how much room for improvement there is just by looking at my slip and video. You never know.....
PTE 6062
633HP/523TQ
Easter Bunny (10-16-2014), ge3kspd (10-16-2014), killer-ms3 (10-16-2014)
 Old 10-16-2014, 09:03 AM   #17
#WUTLIP
ge3kspd's Avatar
All I'm saying is I won't be surprised to hear it in the next couple weeks...
The Following 4 Users Say Thank You to ge3kspd For This Useful Post:
Easter Bunny (10-16-2014), Justin@Freektune (10-16-2014), mmikepetch (10-16-2014), PapaSmurf (10-16-2014)
 Old 10-16-2014, 09:51 AM   #18
calizoomzoom's Avatar
Posts: 684   (View Stats)
calizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the world
Groans: 47
it would be nice to say "Yea, Im tuned by the guy with the only 10 sec ms3" lol. Congrats Justin
calizoomzoom is offline   Reply With Quote
The Following 3 Users Say Thank You to calizoomzoom For This Useful Post:
Easter Bunny (10-16-2014), Justin@Freektune (10-16-2014), taf0422 (10-16-2014)
 Old 10-16-2014, 11:43 AM   #19
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
great that u posted the progression of the night man .... u can see how u improved . what was your launch rpm on your low 1.9s vs the mid 1.8s ??? notice also how your mph goes up soon as u launch harder .... that is the double benefit of pushing wheel speed out of the hole ..lower 60s and you get going sooner aka trap higher
super nice progress for 1 night of r&d ...got a lot left in that car as is
Justin@Freektune (10-17-2014)
 Old 10-17-2014, 11:27 AM   #20
On the earlier runs I was launching at 5500, then I ended up at 6k for the last and best pass, which seemed just about perfect. I would LOVE to get in the 1.7's though. Maybe next time
PTE 6062
633HP/523TQ
 Old 10-17-2014, 11:54 AM   #21
JgamB's Avatar
Posts: 2,566   (View Stats)
What the hell, go balls out and strip the car one good time. Yoink the exhaust, chassis braces, rear crash bar, spoiler. The season is about over up north - You Can Do EeT!
Easter Bunny (10-17-2014), Justin@Freektune (10-17-2014)
 Old 10-17-2014, 12:05 PM   #22
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
just remember that the TIRE does the work , trying to get traction by launching lower is not the right answer ever because you trade 60ft for 330ft .... on a gen 2 mid 1.7s on 15s should be the norm without much effort , just smart choices before u even launch
i do have an awesome video though for you to watch to help you "motivate" you to give powershifting a try .....
Last edited by rodrigo; 10-17-2014 at 12:05 PM. Reason: MSF Database - Automerged Doublepost
The Following 5 Users Say Thank You to rodrigo For This Useful Post:
chaser27 (10-17-2014), cshunter (10-17-2014), h.h.sk1nny (05-19-2015), Jeremy M (10-19-2014), Justin@Freektune (10-17-2014)
 Old 10-17-2014, 12:15 PM   #23
LOL, leave it to the mustang guys to make PB+J sammiches between shifts.
LumberJack likes this.
PTE 6062
633HP/523TQ
 Old 10-17-2014, 12:33 PM   #24
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
all joking aside .... u knock off 1/10th off that 60ft will turn into 2/10 on the ET .... some powershifting (after 2 beers) and u can probably pick up another 1/10 or two .... the math is there .... thats an easy 11.1-11.2 car as it sits right now ...also ... if you truly want to get the most out of your car down the strip then understand that until your 8th mph gets closer to 100 you are leaving shit on the table ... there is always a direct relationship between 660mph and 1320mph , the tighter the two are in distance the more efficient the run is .
all bs aside ...seriously good start now that u have the correct tire
Easter Bunny (10-17-2014), JgamB (10-18-2014), Justin@Freektune (10-17-2014)
Page generated in 0.47031 seconds with 30 queries
