Autosports Area
> Drag Racing
 Old 06-12-2015, 08:42 AM   #41
Spec's Avatar
Posts: 4,472   (View Stats)
Originally Posted by Flawless View Post
What pressures should I aim to run? Any other adjustments I should be making once I get to the track?
If you're stock, the only other one you have would be your tune. You can take a cooler and a few bags of ice, pop the cover off the tmic and ice down the end tanks after a few runs.
I can't in good conscience tell you to go above or below recommended psi in the tires.
I can tell you I ran 50 in the back and mid 20's in the front. Use that information at your own risk. I don't want you to blame me for a blow out and getting the wall at 102mph
 Old 10-06-2015, 12:49 PM   #42
Flawless's Avatar
Posts: 190   (View Stats)
Flawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond reputeFlawless has a reputation beyond repute
Update on this guys, I don't know what I did, but I'm not experiencing the lockout issues anymore (I"ve only changed my tune/suspension since the last trip, but it has gotten a lot cooler around here).
Still have horrific launch issues. Wheel hop for days. Thinking about picking up a trilogy set of mounts . . .only have a rear at the moment.
Korn Killer
2012 Black Mica MS3 || Cobb SRI || Cobb TIP || Freek E44 tune || Cobb FMIC || Autotech Internals || JBR SSP || JBR RSB || JBR Trilogy Mounts (RMM, PMM, TMM) || Koni Yellows || H&R Sport Springs || UR Test Pipe || UR Downpipe || GFB BPV || JBR Solid Shifter Bushings || RPF1 17x9 +45 245/40/17 RE71Rs
Flawless is offline   Reply With Quote
 Old 10-06-2015, 12:55 PM   #43
Definitely get the DM trilogy mounts. 100% can't go wrong.
JgamB (10-06-2015)
 Old 10-06-2015, 01:05 PM   #44
JgamB's Avatar
Posts: 2,566   (View Stats)
And also the ultimate solution to fixing gear shifting slop. I can ram it home like a boss now, and if I missed the gear, it's because I completely fucked up - nothing at all like the spongy hesitation and then thunking into gear like it used to.
DM Threesome > any shifter you can buy IMO.
 Old 10-06-2015, 02:39 PM   #45
SparkySparks's Avatar
Posts: 1,314   (View Stats)
I'm happy with my JBR Trilogy but some people are little babies and can't handle it, I've not heard anything bad about the DM trilogy either. Before I did a full replacement of my shifter, the solid bushing made a difference over the stock rubber bushing also.
On Order:
Coming Soon:
DIY Projects:
 Old 10-06-2015, 06:34 PM   #46
Flawless's Avatar
I'm thinking jbr (just because I have a jbr rear, and it's great). Would that be worth it over getting a front slick setup? I'll probably do one or the other before winter hits.
Korn Killer
 Old 10-06-2015, 10:08 PM   #47
Spec's Avatar
Check your ball joints. I went through a couple as they were destroyed from hopping, fully mounted.
Help diagnose my Southbend Clutch issue - hard shifting, gear lockout etc. Matrix311 MazdaSpeed 3 - Engine, Transmission & Driveline 62 04-06-2015 11:24 AM
Gear lockout on the track with drag radials. pwned Drag Racing 34 06-02-2013 09:10 PM
Transmission - 1st/2nd gear lockout? f-castrillo 2010 MS3 - Engine, Transmission & Driveline 9 07-26-2011 03:54 PM
3rd gear lockout Ace99899 2010 MS3 - Engine, Transmission & Driveline 9 07-01-2011 02:44 PM
Page generated in 0.28555 seconds with 24 queries
