Autosports Area
> Drag Racing
 Old 05-21-2019, 02:25 PM   #1
Bmurray94's Avatar
Posts: 22   (View Stats)
Bmurray94 will become famous soon enough
Default Drag tire question
I was thinking about swapping the tire setup from my Evo onto the Mazda when I go to the track soon. My car is just a Intake, exhaust, stage 2 tuned car. So nothing crazy. The tires are 26x9.5x16 Hoosier QTPs. How do you guys think the stock axles will take these tires with a ~4K rpm launch?
07 GT MS3 - TBD
06 SSL Evo 9 - 10.1 @ 149.9mph
@Bmurray_evo9
Bmurray94 is offline   Reply With Quote
 Old 05-21-2019, 05:56 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Likely be fine if you don't shock load the axles.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Bmurray94 (05-26-2019)
 Old 05-25-2019, 08:03 PM   #3
shaneski's Avatar
Posts: 505   (View Stats)
It should be fine although some cars snap axles all the time with not much power which is probably due to axle tramp.
I launched mine at 5500 on stock axles plenty of times with zero issues on full slicks. Make sure you have a good rear motor and tranny mount, i use the Damonds and has no tramp.
If you do feel it start to tramp let off the throttle or they have a high chance of breaking
The Following User Says Thank You to shaneski For This Useful Post:
 Old 05-26-2019, 09:52 AM   #4
Bmurray94's Avatar
Cool deal. Thanks guys.
07 GT MS3 - TBD
@Bmurray_evo9
 Old 05-27-2019, 08:38 AM   #5
Posts: 2,235   (View Stats)
the axles are solid on these cars. i used non d.o.t. 15x8 without any issue a lot of times.
with 16, you won,t have bad offset, it will be easier.
as stated, the motor and trans mount is the weakness and if you don,t upgrade and keep the wheel jumping around, you won,t snap the axle but the transmission case.
just load the gear play and keep it there with the handbrake before you drop the clutch...
best tire wheel combo for drag strip Mazdaspeed2012joe MazdaSpeed 3/6 - Wheels & Tires 2 12-09-2012 02:30 PM
MS3 drag wheel/tire setup sg1320 Drag Racing 5 10-25-2011 10:27 AM
Best auto-x and drag tire? atenza_freak Wheels & Tires - SILVER 15 05-09-2010 09:29 PM
RX8 tire question KeysMS3 MazdaSpeed 3/6 - Wheels & Tires 0 03-22-2010 01:21 PM
autoX/ drag rims tire..best of both worlds? booya620 Auto-X / Road Racing / Time Attack 4 12-15-2008 08:23 PM
Page generated in 0.25924 seconds with 24 queries
