Autosports Area
> Drag Racing
  • 1 Post By MazdaBoy2.3
 Old 08-23-2014, 06:27 PM   #1
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Default MazdaBoy2.3's - Trip to the drag strip.
First time to the track with my speed.
Full interior minus the spare tire and had my 555's at 20psi.
Looking for recommendations/advice..
Here is my final of 4 runs (right lane).
Srt jeep vs. Mazdaspeed3:
The Following 4 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
Code Monkey (08-23-2014), Hush (08-23-2014), ink28 (08-24-2014), mxlplx71 (08-23-2014)
 Old 08-23-2014, 06:33 PM   #2
Groans: 51
Here are the first three runs. I was in the left lane for all three.
The Following 2 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
bigspender (09-12-2014), pharaoh313 (08-25-2014)
 Old 08-23-2014, 07:51 PM   #3
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Pretty good runs. Better tires/slicks weight reduction could probably get you to mid/low 12s pretty easily.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
MazdaBoy2.3 (08-25-2014)
 Old 08-25-2014, 03:12 PM   #4
pharaoh313's Avatar
Posts: 120   (View Stats)
pharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the world
+1 Tires/Slicks & Meth
2013 Mazdaspeed 3 W/Tech
1st trip 2 the 1/4m: 1.89 60ft 12.87@109.62 VD* 289hp- HpFp - Trilogy 70D -E85(Freek)Tune - QTPs
2nd time 1/4m: 1.91 60ft 12.49@113.59 Dynojet 335.48hp- HpFp - Trilogy 70D - E85+M(Sn@il)Tune - QTPs - 3 port - SE/TBE - TMIC - 3.5Intake
Audio: 2 x Kicker Cvr 12s, Hif 1500D, Hif 800.4, Bx-15, 4x Infinity Kappa 60.11cs rewired w/12G
@FB Allan Langston
~4 Bangin Ain't EZ~
pharaoh313 is offline   Reply With Quote
The Following User Says Thank You to pharaoh313 For This Useful Post:
 Old 08-26-2014, 04:50 AM   #5
shaneski's Avatar
Posts: 506   (View Stats)
Nice runs, so close to 12s, what RPM did you cross the line at holding 4th in the vid.
 Old 08-26-2014, 05:24 AM   #6
Groans: 51
Bouncing off limiter which is set at 6800. I shifted to 5th on the prior run and hit 115. I probably should have done the same in this run.
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
shaneski (08-26-2014)
 Old 08-26-2014, 06:21 AM   #7
shaneski's Avatar
I ran 26 inch hoosiers QTP last time i went and short shifted at 6000 rpm cause of massive heat soak (even with meth) from 3-4-5th gear and did 13.2 @ 112.6 and failing oem clutch.
Just getting new clutch buttoned up and about to go FMIC before next drags in a few weeks. I'm limited at 6700 and was thinking of riding out 4th..but if i make the 380whp i do with no heat soak i may bounce too much for a stock block and not game to raise it to 7000rpm as it's a daily driver.
 Old 08-26-2014, 08:27 AM   #8
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
definitely raise the rev limiter. 7200 should be no problem for a few runs at the track and ride out 4th. though I'm no expert, that time is roughly my fastest with street tires too.
'08 CWP MS3 w/ T3 3071r
 Old 08-27-2014, 10:38 AM   #9
Josegarcia020's Avatar
Posts: 177   (View Stats)
Josegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant futureJosegarcia020 has a brilliant future
Some more weight reduction and some slicks will do wonders!!
Josegarcia020 is offline   Reply With Quote
 Old 08-27-2014, 10:41 AM   #10
Groans: 51
I'm not 100% sure I want to go to full out slicks.
I'm debating just some nt01s (245-45-17) along with maybe removing the back seats next time.
Matt
 Old 08-27-2014, 01:54 PM   #11
Matt
Yea try that, i think you can shave off another .2 or so
 Old 08-27-2014, 08:13 PM   #12
Groans: 51
I really just want 12s.
 Old 08-28-2014, 12:32 PM   #13
mxlplx71's Avatar
Groans: 128
youll get there with your current mods, just get the launch down and 60' around 2.0
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 2 Users Say Thank You to mxlplx71 For This Useful Post:
bigspender (09-12-2014), MazdaBoy2.3 (08-29-2014)
 Old 10-24-2014, 08:33 AM   #14
Groans: 51
Welp. These might help.
PUGENE likes this.
The Following 3 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
doubleflusher (10-24-2014), mxlplx71 (10-24-2014), PUGENE (10-24-2014)
Went to the drag strip tonight biggman026 Mazdaspeed3/6 General Discussion 3 08-25-2013 10:39 AM
Drag strip Hectik1 Drag Racing 1 06-24-2011 07:32 AM
Went to the drag strip again... SharkDiver Drag Racing 14 08-27-2008 08:58 PM
Page generated in 0.33020 seconds with 26 queries
