Autosports Area
> Drag Racing
  • 2 Post By doubleflusher
 Old 03-18-2015, 11:48 PM   #1
tek_88's Avatar
Posts: 93   (View Stats)
tek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to behold
Groaned at 13 Times in 2 Posts
Default MS6 first time at track
First time at the track with the speed6. BNR S3, cpe tmic, short ram, internals, cs dp, tp, magnaflow mufflers with slightly tweaked OTS Stage 2 map. Should I be doing better than this or is this the norm?
First run on the left and second on the right w/ a ton of heat soak.
tek_88 is offline   Reply With Quote
 Old 03-19-2015, 12:00 AM   #2
Police - Grammarhead
Vansquish's Avatar
Define "slightly tweaked OTS Stage 2 map."
 Old 03-19-2015, 12:06 AM   #3
Amnesiac's Avatar
Posts: 315   (View Stats)
Groaned at 6 Times in 4 Posts
That's slow for what you have.
You may want to check into meth or e85 if that's available, and get a real tune
Last edited by Amnesiac; 03-19-2015 at 12:06 AM. Reason: MSF Database - Automerged Doublepost
Amnesiac is offline   Reply With Quote
 Old 03-19-2015, 12:10 AM   #4
tek_88's Avatar
I turned timing down in areas where it showed some knock.
@Amnesiac: That's what I thought, I know I could hit high 12's with my setup. I just need to find someone who tunes in my area.
 Old 03-19-2015, 12:20 AM   #5
Amnesiac's Avatar
I wouldn't worry too much about having someone local, etuning is great. I've used Stratified, Freektune, and Flowtuned and they were all fine.
I would really do something about fuel though, you're handicapping yourself if you're just running straight gas, especially in California where I hear it sucks.
The Following User Says NO Thank You to Amnesiac For This Un-useful Post:
trdsw (03-19-2015)
 Old 03-19-2015, 12:51 AM   #6
tek_88's Avatar
CA gas sucks, I want to do a tune on e85 but this is my wife's DD and she doesn't want to search for e85 stations. Only option left is to run water/meth injection.
 Old 03-19-2015, 07:05 AM   #7
scubasteve711's Avatar
Posts: 1,238   (View Stats)
Groans: 70
The tune is holding you back. The OTS's are just that...
Oh, and datalog your damn runs sonnnn
07' Speed6 Velocity Red Mica
scubasteve711 is offline   Reply With Quote
 Old 03-19-2015, 06:13 PM   #8
tek_88's Avatar
Haha, yeah I was planning on dataloging but forgot to press the button while lining up.
 Old 03-22-2015, 08:27 PM   #9
Caro's Avatar
Posts: 86   (View Stats)
Caro has much to be proud ofCaro has much to be proud ofCaro has much to be proud ofCaro has much to be proud ofCaro has much to be proud ofCaro has much to be proud ofCaro has much to be proud ofCaro has much to be proud ofCaro has much to be proud of
Groaned at 9 Times in 2 Posts
yea i would say that is slower than what your car is capable of. That is what i was running with no mods on my speed3.
Cobb v3/auto tech/HTP 3.5/Turbo Smart BPV/xs power manifold/BNR s4
Caro is offline   Reply With Quote
 Old 03-23-2015, 02:25 PM   #10
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Lol @ running your wife's DD at the track. That's classic.
Silver 2007 Speed3 GT
The Following 3 Users Say Thank You to HawkeyeGeoff For This Useful Post:
Arnie1229 (03-23-2015), CWP_MS3 (03-26-2015), WA_MS6 (03-24-2015)
 Old 03-23-2015, 02:33 PM   #11
Vansquish's Avatar
I'll just leave this here:
https://www.youtube.com/watch?v=3QGHqCMvo_0
 Old 03-23-2015, 03:01 PM   #12
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Cullen eats penises
Mfinlay04 and Vansquish like this.
Beanfab / Tuned by Nishan
Mfinlay04 (03-24-2015), SofaKingAwesome (03-24-2015), Vansquish (03-23-2015)
 Old 03-23-2015, 04:15 PM   #13
Vansquish's Avatar
But Cullen was faster with the stock terboh.
 Old 03-23-2015, 10:53 PM   #14
tek_88's Avatar
Yeah, I'm gonna do a compression test on the car this week and go from there. I'm pretty sure I'm still on stock injector seals so I'm gonna order those soon. After that schedule a tune.
 Old 03-24-2015, 06:36 AM   #15
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Your trap speed seems to be pretty low.
 Old 03-24-2015, 08:02 AM   #16
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
i used to drain most of my fuel out before i went to the track, then buy race fuel once i got there and change maps.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 03-24-2015, 10:55 AM   #17
tek_88's Avatar
I was wondering about that too. I mean my first run had a higher trap speed than my second run.
 Old 03-25-2015, 12:54 AM   #18
shaneski's Avatar
Posts: 506   (View Stats)
TMIC generally show slower times at drags with heat soak waiting in the lanes and get worse as the night goes on after it has had a hammering and back to the lanes again.
If the car was heat soaked the ECU pulls a fair bit of timing and richens AFRS, basically saps power big time to protect the engine.
 Old 03-26-2015, 12:27 AM   #19
tek_88's Avatar
That's right, I forgot all about heat soak. Next time I'll bring a bag of ice to try and keep the tmic cool.
My track time Sal's_MS6 Mazdaspeed3/6 General Discussion 8 11-03-2012 07:04 AM
First time at the track zatara Auto-X / Road Racing / Time Attack 2 07-18-2011 03:53 PM
First time at a track xxandrossxx Drag Racing 13 08-09-2009 11:07 PM
First time at track TXspeed3 Drag Racing 27 07-30-2009 01:23 PM
Page generated in 0.38357 seconds with 29 queries
