![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
(Thread Starter) | Not Ranked : 0 score I already picked up some FD's and some racing slicks, but i would like to hear from the experienced autocross-ers on what i should spend the small amount of money i have left on. Brakes - Mine are shot, i was thinking about going with the cheapest rotors i can find on rockauto and getting some good pads. Pad options with the least fade?(for canyon runs) I dont need stock bite, but i dont want to feel like i have to push the pedal thru the floor to slow down. (would like stainless brake lines but i dont think its necessary and could get something else to help more) Rear sway - can get a good deal on a whiteline, if not that then probably JBR because of adjustability. Swift Springs If i had another hundred or two anything else you would reccomend? I'm just trying to make the most competitive car with a small amount of money. Thoughts on my outline?
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() Join Date: Oct 2012 Location: Golden, CO
| Not Ranked : 0 score If you really want to be competitive, save a bit more and get a good set of CO's and some camber plates for the front and camber arms for the rear. If you just want to go out and have fun, I'd probably skip the springs for this season and spend the $$ on a big rear sway, Koni/Bilsteins, and some rear camber arms. That's what I'm running and it's a very balanced setup. Go full stiff on the rear sway and keep your rear camber in the -1 range to take some load off the fronts without too much oversteer.
__________________ 2011 PB EVOX GSR | FBO + E85 ![]() (Sold) 2008 Black Mica MS3 | Cobb AP | UR DP+TP | HTP 3" | CS TMIC | CS BPV | Autotech HPFP | CPE RMM | JBR SSP | Koni Yellows | Cobb RSB | SPC Camber Arms | E40 Self Tune - 295whp/327wtq Uncorrected @ 5600' ASL 2014 Triumph Street Triple R |
(Thread Starter) | Not Ranked : 0 score its more so this, but making the car as competitive as possible for this season with a limited budget. Next season i should be able to spring for a decent setup
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,658
| Not Ranked : 0 score Fix your brakes and get a rear sway bar. Almost any of the performance-oriented pads available at Edge, MAP, or Tire Rack will work fine for you. Just don't pick a track-only pad because it will never get up to operating temp during an autocross event.
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 |
| The Following User Says Thank You to Crarrs For This Useful Post: | snailD (01-06-2014) |
![]() Join Date: Sep 2012 Location: Farmington, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score I'm not super experienced in autox, but I would wait for slicks until you can out drive street tires. I'm in the same boat as you as far as experience, but there's a lot more to gain with an alignment and seat time.
__________________ Cobb AP // JBR 88d Trilogy // JBR 3.5" WP // JBR RSB // MS Coils // SPC Camber Arms // Autotech Internals // eBay Catless DP // ACT-ZX5-HDSS // TRM C3 17x9 +48 // 255/40/17 NT05 [SIGPIC][/SIGPIC] |
I DO need to get an alignment, i'm reading a book now about setting up the car so hopefully will come up with my own specs before the season begins
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | |
| The Following User Says Thank You to snailD For This Useful Post: | Bobforapples (01-06-2014) |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
| Not Ranked : 0 score Here is my recommendation. I got about 80 passes in this season. Honestly ditch the racing tires and get some good summers rivals z2 and so on. Imho race tires are not worth it. And u do not want to learn your car on them. For example @phate; beat me by 3 seconds in my own car. Driver mod is the best mod for ax. For suspension if you want something out of the box that is extremely awesome get ms coilovers through msm if they still have them. Only 1600 bucks and absolutely amazing. If you want something more custom go with the ground control kit with custom valved shocks and matching spring rates. Brakes go with ebc yellows. I will be switching to them for the new season. Also stainless steels lines give a huge improvement in brake feel. @nlllintend1; @MS3johanna; are some others that might have helpful info Sent from my XT1080 using Tapatalk
__________________ Damond Built Speed 6 |
| The Following 3 Users Say Thank You to Deldran For This Useful Post: |
| Not Ranked : 0 score Last year was my first year as well and I just went in with the mods in sig. Did fairly well; consistent but not quite quick enough. Like you, I also have the urge to buy parts but unfortunately my clutch is slipping so that takes priority. I'm obviously lacking in the suspension area but hopefully I can at least afford camber arms and an alignment, and maybe Bils/Swifts. But most of all, I'm just excited to get back out there driving! This -55 Windchill is no bueno.
I learned alot about the car already and tires are one thing i'm not changing. i got a good deal on some used r-comps and fd's (cost me like 300 bucks total) and getting different tires will be like my whole budget when i still need pads and rotors (maybe lines if enough people say its worth it) I realize ideally this wouldn't be the setup to run, but as the title says i'm going bang for the buck trying to work with what i have. I know i wont win (there is a super fast mx-6) but if i can have a good time and threaten a few people i'm happy.
![]() Join Date: Nov 2009 Location: Pensacola FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 659
| Not Ranked : 0 score Stainless steel brake lines will amaze you. Slap some hawk hp+ pads on and you'll have some wicked bite. And a rsb. Those two things will change up the feel enough it'll take you half a season to adjust. And I'm not saying to get used to I'm saying to fully appreciate and use to their full potential. Then start looking into some good suspension parts. Doesn't have to be a crazy CO set, even some koni yellis and sport springs will give a huge help.
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII |
Groans: 118
| Not Ranked : 0 score Listen in am all for bang for your buck. Buy rcomps are no way to become a better driver they will just mask your flaws as a driver. If you want budget the ground control is a much better option the spring rates on most after market springs are not well suited for AX. If you are serious about wanting to get into autocross sell those fds and rcomps I am sure you could get more than what u played for. Buy an rsb and start saving. Again I am all for doing stuff on the cheap but if your main goal is autocross for the car there are some things you simply can't compromise on Sent from my XT1080 using Tapatalk
| Not Ranked : 0 score Since you only did a few events, save the money on parts and spend it on seat time. Those RComps will give you some very, very bad habits if you use them early on. You can't use them to their full potential, and coming off of rcomps is a very difficult transition compared to going to rcomps. If you can't afford 2 sets of rcomps per season, don't bother just to 'test them out'. Seat time will gain you more than anything right now. Give it a season or two and then invest in parts. Edit: brakes. EBC yellows were my favorites in my ms3. Hawk HPS and HP+ are inconsistent and I couldn't stand them. My avatar pic was taken with yellows on my 6, also. They don't mind the abuse.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. Last edited by phate; 01-06-2014 at 10:15 PM. |
| The Following 4 Users Say Thank You to phate For This Useful Post: |
![]() Join Date: Mar 2012 Location: Bend, Oregon
Rep Power: 670 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,489
Groans: 122
| Not Ranked : 0 score As others have said, I would recommend to use summer tires and learn the car on an autox track through tons of seat time then slowly tweak the car to fit in your class. But that's just my opinion.
__________________ 2006 BCM Mazdaspeed 6 GT w/navi SOLD Freektune: 400whp/387awtq Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18 -Autocross Setup- 17x8 +38, BF Goodrich R1 225/45/17 Other Rides: 2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013) 1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it. 1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father) 1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD) |
Groans: 118
| Not Ranked : 0 score Also what size are those rcomps. I would imagine they are smaller than stock size which really is not that good as it makes your gearing even shorter. If they are close to stock size even in an rcomp you are going to get so much sidewall slop it would be crazy Sent from my XT1080 using Tapatalk
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,851
Groans: 58
| Not Ranked : 0 score As everyone else said, stick with street tires and learn the car as is. If you REALLY want to get something just invest in a RSB.
Groans: 118
| Not Ranked : 0 score I wasn't referring to width I was talking about sidewall height. If its close to stock wheel diameter that's a whole lot of sidewall I know rcomps have stiffer sidewalls but you are still con get some slop even in an rconp with a 70 or 80 ratio sidewall. Pretty sure they don't make rcomps that tall I could be wrong though Sent from my XT1080 using Tapatalk
Groans: 63
| Not Ranked : 0 score Don't cheap on brake rotors. KNS has a full stoptech street setup for $325 or so, all 4 corners. I've put in a bit of seat time with them on track and street and have been impressed. They may not be quite EBC good but for the money they're fantastic. Also a good sway bar will transform the handling of the car and take it from understeer prone to a very neutral balance, I love mine and most others here do as well.
Groans: 118
__________________ Damond Built Speed 6 | |
Groans: 63
| Not Ranked : 0 score I'm not doubting that but he said he would just buy the cheapest parts from rock auto...which I would not suggest. When I did my brakes I planned to go OEM but the stoptech setup was cheaper and the quality is just as good if not better. I don't have MSM access (wish I did) so prices were higher for me.
Groans: 118
| Not Ranked : 0 score Its super easy to get. Go do to ax events and be a member of scca. Sent from my XT1080 using Tapatalk
Groans: 63
| Not Ranked : 0 score I'm wanting to this year, everything is at least an hour from me though
Groans: 58
| Not Ranked : 0 score OEM and centric blanks work fine. I've used them both on the track with no ill side effects. |
| The Following User Says Thank You to daafisch For This Useful Post: | Nliiitend1 (01-07-2014) |
Groans: 118
| Not Ranked : 0 score I drive 3 hours to autocross stop being a pussy lol Sent from my XT1080 using Tapatalk
| The Following User Says Thank You to Deldran For This Useful Post: | Crarrs (01-07-2014) |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score yeah i have heard from many people that as long as they are still vented in the center a disc is a disc basically. i was told to not worry about getting expensive drilled and slotted just get a cheap disc and a good pad
| The Following User Says Thank You to snailD For This Useful Post: | daafisch (01-07-2014) |
![]() | | #25 | ![]() |
Groans: 118
| Not Ranked : 0 score Get an msm membership you if you did 2 events and are an scca member its free just got a give them info. There is no better solution than msm for rotors and many other consumable parts Sent from my XT1080 using Tapatalk
| The Following User Says Thank You to Deldran For This Useful Post: | snailD (01-07-2014) |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score i dont have a membership yet but i did 2 events last season. would i be able to apply once i get my membership?
![]() | | #27 | ![]() |
So as long as the results are timed with a date and the local Autox chapter name at top, and I get a SCCA membership; I qualify? I would love a discount on rotors, and I hear nothing but good about MSM coils out of the box. Sorry for thread jack OP, just looking for clarification.
__________________ Cobb AP // JBR 88d Trilogy // JBR 3.5" WP // JBR RSB // MS Coils // SPC Camber Arms // Autotech Internals // eBay Catless DP // ACT-ZX5-HDSS // TRM C3 17x9 +48 // 255/40/17 NT05 [SIGPIC][/SIGPIC] | |
![]() | | #28 | ![]() |
Groans: 118
| Not Ranked : 0 score Should be able to if not just do two more. What size are the rcomps Sent from my XT1080 using Tapatalk
__________________ Damond Built Speed 6 Last edited by Deldran; 01-07-2014 at 07:26 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Deldran For This Useful Post: | Bobforapples (01-07-2014) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score i dont remember, i'm visiting family right now, going home tomorrow. But it sounds like a RSB is a must (i dont like the lack of rotation right now) @daafisch; what is your favorite pad and were the swift springs worth it (for handling alone not the lows)
![]() | | #30 | ![]() |
Groans: 118
| Not Ranked : 0 score I really like the cs bar with the cs links. My car handles extremely well Sent from my XT1080 using Tapatalk I would guess most will recommend the ebc yellows. I am running cs right now as they are a bit of an improvement over stock they are just not aggressive enough for me. Might not be a bad choice for someone still learning though. I would still say get yellows Sent from my XT1080 using Tapatalk
__________________ Damond Built Speed 6 Last edited by Deldran; 01-07-2014 at 07:34 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #31 | ![]() |
Groans: 58
As for the springs, the car is definitely more balanced in the slaloms but I don't think they made a night and day difference. I got used making my transitions earlier due to the stock body roll and I then had to adjust that after the suspension install. My gen1 was traded just before the start of the season so I gradually swapped over my parts to the gen2 over the summer. I'd say the RSB made the biggest improvement. You make a lot of assumptions. | |
![]() | | #32 | ![]() |
Groans: 118
![]() | | #33 | ![]() |
Groans: 58
| Not Ranked : 0 score I've heard they are a great pad, I'm actually considering them for this upcoming season. In my region it's a good mix of Hawk, Carbotech and EBC that are ran. I've personally ran stock, Hawk HPS, and a mixture of Carbotech's. I want to get some Ferodo DS2500's but I don't really want to spend the money to see if the part number on the UK sites is correct. |
![]() | | #34 | ![]() |
![]() Join Date: Mar 2010 Location: SOJO
Rep Power: 176 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score |
![]() | | #35 | ![]() |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score DyDeeps! Get that bar! The tripoint is a very high quality RSB. Also, stick with the stock rotors. For autocrossing, pads and fluid make a bigger difference. The MS3 has some of the best brakes out there for sheer stopping power from sub 60. Going between my mazda and other cars (STis, M3s, etc) I missing my braking point every time because I expect those cars to stop as well as ours does. PS, it sucks I missed you last year. I'll see you this season! |
![]() | | #36 | ![]() |
Groans: 118
| Not Ranked : 0 score I love my cs bar. With my setup it is the right amount of stiff Sent from my XT1080 using Tapatalk
![]() | | #37 | ![]() |
![]() Join Date: Jan 2014
Rep Power: 0 ![]() ![]() Thanks: 3
| Not Ranked : 0 score Has anyone tried the expensive Centric rotors? They're supposed to be ok, though I don't know how they would compare to the stockers. I've had steel braided brake lines on a few cars and never "felt" a difference. Different pads will make more of a "feel" difference, imo. I don't think they're needed for AX, and the only reason I got them before was for track. I've heard stories (never verified) of rubber hoses bursting so putting in steel lines would make some sense. I also agree with the poster above to stay away from Hawks. Maybe some people love them, but the ones I had (HP+ I think) squealed on new rotors and dusted crazy mad. Just rinsing the wheel with a hose left a black river down the driveway. Didn't track them but they didn't seem to stop any better either under normal conditions. Definitely flush the brake system with at least a cheap DOT 3/4 fluid. As far as the Whiteline bar is concerned, it looks like they built it to work with their front bar (just based on size) so not sure it's a great stand-alone bar. I will also say that a rsb change would be helped by a fsb change too, but that's just my thought. If anyone has any hard evidence either way, I'd like to hear it. To get the car to rotate, try left foot braking or e-brake. I'm a big fan of left foot braking but haven't had this car long enough to try it. |
![]() | | #38 | ![]() |
Groans: 118
| Not Ranked : 0 score I switch to stainless lined and it made a huge difference in peddle feel Also I see absolutely 0 need to ever upgrade the front sway bar on these cars Sent from my XT1080 using Tapatalk
![]() | | #39 | ![]() |
| Not Ranked : 0 score I autocross with the front bar disconnected. Granted, for that to work you have to have stiff, stiff springs. |
![]() | | #40 | ![]() |
Groans: 58
| best bang for buck | IVIike13 | 2010 MS3 - Suspension & Brakes | 31 | 02-09-2012 03:02 PM |
| bang for your buck mods | rkwill | MazdaSpeed 6 - Engine, Transmission & Driveline | 27 | 11-21-2010 03:04 PM |
| Need the best bang for the buck HP mod combo... | 94jedi | MazdaSpeed 3/6 - Turbo Induction | 31 | 04-24-2008 08:29 AM |
