Autosports Area
  • 1 Post By Jonb82
 Old 08-31-2017, 11:49 AM   #1
da johnny boy's Avatar
Posts: 16   (View Stats)
da johnny boy will become famous soon enoughda johnny boy will become famous soon enough
Default Downpipe recommendation for autocross
I'm pulling the turbo to fix the broken downpipe studs, so and it should be easy to do the downpipe while the turbo is removed. I'm trying to decide what to buy to either stay STX legal, or to switch to DSP, and therefore whether I need a cat or not. I mostly autocross my STR prepped Miata, so I'm not building the speed to be competitive. In my club, I run a PAX indexed class, so I can swap around cars and have that still count for the season standings. Or I can always just run the speed in a different club since it will not be competitive in STX or DSP.
Right now I have 17x9 wheels with 245 RE-71rs, a rear swaybar, deresonated midpipe, intake, HPFP, and e40 tune. If I ran STX, I'd just run 93 with stock boost tables. If I ran DSP, I could keep everything the same, and additionally, just run no cats. I don't want to spend much money. I'd probably go for one of the nicer high flow catted downpipes if I could find one used, but I my budget is around $200. If I did keep a cat, I'm not sure whether the better way to go is to eliminate the upstream or downstream cat.
What do you guys think about these options? I'm personally leaning towards option 4 or 5 with the ebay long downpipe.
  1. STX - High flow catted downpipe with either the OEM catted test pipe or a catless test pipe
  2. STX - Catless downpipe with OEM catted test pipe or High flow catted testpipe
  3. STX - Long catted downpipe
  4. STX - Long catless downpipe and add a high flow cat (I'd probably just use band clamps instead of welding)
  5. DSP - Long catless downpipe
da johnny boy is offline   Reply With Quote
 Old 09-02-2017, 04:56 PM   #2
Reedy's Avatar
Posts: 391   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
I've had a CP-e DP for a few years now and the core of the CAT failed after only a couple of years worth of track days. We cut it out and welded in a new one and that's just recently failed on me as well, to the point where the core has fallen down into the pipe and destroyed my rear O2 sensor.
I am swapping that out to a Cobb DP once my new turbo arrives. I have no idea if it will last any better than the Cp-e one did but I guess my main point is, if you're gonna go cheap ebay shit, don't get a CAT.
Reedy is offline   Reply With Quote
 Old 09-12-2017, 03:19 PM   #3
Haha, I wouldn't think of getting cheap cat from ebay. I don't know much about DIY exhaust parts, but I was looking at Vibrant, Magnaflow, or Flowmaster for high flow cats to add to the catless ebay downpipe.
Was the cat you replaced a metal core or a ceramic core? And do you know the brand? Looks like the stock CP-e DP has a metal core cat.
@Code Monkey, but wouldn't I still need an adapter from the stock K04 turbo discharge to attach a v-band flange?
 Old 09-13-2017, 03:53 AM   #4
Reedy's Avatar
The original cat was a ceramic core, not sure what they use now but that DP was purchased back in 2010. The one we replaced it with was a metal core, which lasted longer but still failed eventually.
 Old 09-02-2017, 06:37 PM   #5
Catted or catless, get a v-band DP and you will hopefully never have to deal again with broken DP to turbo studs.
Pu Manchu (09-02-2017)
 Old 09-12-2017, 08:37 PM   #6
Yes, but the adapter is really short so it is super easy to install it on the turbo as you have easier access to all the five studs, Mazdaspeed6 example here. Then you simply connect the rest of the DP via v-band.
 Old 10-11-2017, 05:38 PM   #7
Shottachris's Avatar
Posts: 31   (View Stats)
Shottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these parts
Groaned at 64 Times in 26 Posts
Nice
TopFlightInc! NYC
2011 speed 3 GT daily driver
Mods: big turbo , fuel internals , sure short shifter , forge BOV , FMIC , JBR motor mounts all around , BC coil overs , staggered advan wheels 18 x9.5 25+ offset front 18x 10.5 15+ offset rear , 3in catless down pipe , occ , Custom 3inch intake , Cobb strut bar ,Cobb v3 ,vtcs delete stock intake mani ,
Shottachris is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Shottachris For This Un-useful Post:
Pu Manchu (10-11-2017), zenit (10-12-2017)
 Old 10-11-2017, 05:48 PM   #8
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Originally Posted by Shottachris View Post
Nice
Shit posting for a reason or just trying to build your post count to look like you contribute?
crapatalk it sucks for free
 Old 10-12-2017, 02:35 PM   #9
Jonb82's Avatar
Posts: 416   (View Stats)
Nice
Sent while probably pooping
PlatinumCore16 likes this.
monkey.bones.007 (10-12-2017)
 Old 10-13-2017, 12:17 PM   #10
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Nice
Ditto
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Recommendation TheHitman Drag Racing 1 04-16-2011 12:13 AM
AP Map Recommendation Tomas MazdaSpeed 3/6 - ECU Computer Tuning 15 04-19-2009 07:09 AM
new mod recommendation! jlocurto Mazdaspeed3/6 General Discussion 29 09-23-2008 08:57 AM
Page generated in 0.30500 seconds with 26 queries
