![]() Join Date: Sep 2012 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
__________________ Corksport: SRI & TIP, Strut Tower Brace, Coilovers CP-e: RMM JBR: Rear Sway Bar (with Moog End Links) TWM: Full Replacement Shifter Cobb: AP AutoTech: HPFP Internals Ebay: Test Pipe |
| The Following 2 Users Say Thank You to ChaunceyM For This Useful Post: | Db09ms3 (02-19-2018), roguemazda (02-19-2018) |
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score I would personally. I also fill my oil filters half way when I install them on changes.
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
| The Following User Says Thank You to kTaLgsTo For This Useful Post: | Db09ms3 (02-19-2018) |
| Not Ranked : 0 score That is actually a very good question. I'd almost be willing to bet that at least some fluid flows through the cooler at all times. You could possibly check the seat pressure of the oil thermostat. If it's less than your normal oil pressure, it will be slightly open during normal operation...I think. Edit: Just occurred to me...the thermostat doesn't snap open, it gradually opens as the oil warms up. So you won't get a sudden "no oil" situation. What made you decide to install an aux oil cooler?
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) Last edited by Fstrnyou; 02-19-2018 at 02:10 PM. |
| The Following User Says Thank You to Fstrnyou For This Useful Post: | JSmith (02-19-2018) |
![]() Join Date: May 2010 Location: SLC, Utah
| Not Ranked : 0 score Mishimoto has 2 types of thermostatic plates - one is fully closed until it reaches temp (front thermostat) and one restricts most oil before it reaches temp (rear thermostat). Which one do you have? For your question, I'd pre-fill it if you can. I'll be putting one (MMOC-DP-M) in next month but won't be able to pre-fill since the outputs will be on the side. JBR's outlets are on the bottom so no pre-filling there either. I'd also worry about that one emptying back into the pan every time you shut the engine off.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
(Thread Starter) | Not Ranked : 0 score Partly as a safegaurd during summer track days. Some of those July and August days have ambients in the upper 90s and it's just not something I want to worry about. Partly just to do it. At this point I'm using the MS3 as for learning purposes. Both driving technique and physical work. There'll be plenty more stuff I'm doing 'just because' for the experience aspect of it.
And I didn't even think about it draining into the pan during rest. Although when the thermostat closes it should cut that off. Before the first start I'll probably pull the top connector off and funnel in as much oil as I can. Then drive it around and hope it doesn't go pop!
__________________ Corksport: SRI & TIP, Strut Tower Brace, Coilovers CP-e: RMM JBR: Rear Sway Bar (with Moog End Links) TWM: Full Replacement Shifter Cobb: AP AutoTech: HPFP Internals Ebay: Test Pipe | |
| Not Ranked : 0 score How will your cooler be oriented?
(Thread Starter) | Not Ranked : 0 score Right now the connections will be on the side, but depending on where exactly I mount it they might be on the bottom. If it's side, I could "easily" unscrew the top hose and fill with oil.
| Not Ranked : 0 score What cooler are you using? Do you have a FMIC?
(Thread Starter) | Not Ranked : 0 score System all connected and working. No leaks and oil is definitely routed through the cooler. Making the custom hoses wasn't as tricky as I expected, although I need to get a better method of cutting the hose. Still have to connect the temp gauge, but that's not critical. I'll get it on before summer track days. Gotta move on to brake ducts and rear caliper replacement...
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score photobucket, yikes.
__________________ 94 M MS6 IS350 |
| The Following User Says Thank You to Pu Manchu For This Useful Post: | kTaLgsTo (03-30-2018) |
| Prime time for big pickups | Haltech | Automotive News | 0 | 01-20-2013 10:10 PM |
| Last chance to enter to win a Garage and Hardware Storage System from Flow Wall System! | Haltech | Automotive News | 0 | 06-21-2012 10:10 AM |
| Megatron or Optimus Prime???? | emag remrofni | Mazdaspeed3/6 General Discussion | 4 | 03-03-2011 03:26 PM |
