Autosports Area
  • 1 Post By Tomas
 Old 12-01-2016, 11:33 AM   #1
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Default RX8s Are So Fucking Cheap Right Now I Want One In My Life
I had a plan to get a MK2 NA MR2 for Chump car racing at some point in my life. Then I thought a V6 Camaro or Pontiac might do the trick. Then I looked into Pontiac Fieros and almost immediately dismissed them. Then I thought a Gen2 RX7 could be rad. Now I've been trolling Craigslist and RX8s appear to be so incredibly fucking cheap, cheaper than gen2 RX7s, that I think that's the route I want to go. The RX8 is a 500 point car on the Chump car list but I still think it might be better than all the other options out there. The last thing I would ever get is a BMW E30. I have been psychologically marred by German cars and avoid them like the pest.
So. Before I head over and troll the rotary forums I know there are one or two or twenty fuckers around here who have owned RX8s. I know about the common S1 tranny problems, the useless coils, and potential lubrication issues on the Apex seals. What else is there? And more importantly, what else is there that has a high potential for failure during road racing use? Any overheating issues? Oil starvation issues? Is the S2 transmission robust enough for continued road racing? Anything that would make an RX8 a no go for road racing? Or at least something that is so expensive to modify that it's not worth it?
I am not scared of buying something with a blown engine and overhauling it myself. In fact, building a triangle is something I've been wanting to do for a long time. Question is how much money would I have to dump into it to make endurance racing reliable?
zenit likes this.
Neverlift (12-02-2016), WetzMS3 (12-02-2016), zenit (12-01-2016)
 Old 12-01-2016, 04:39 PM   #2
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Plz add me to Doritos chump team roster
-feejay
-wetzel
Tomas (12-01-2016)
 Old 12-02-2016, 09:44 AM   #3
Doritos and dirty oil wrestling with @Tomas; and @zenit;?
I want in.
Tomas (12-02-2016)
 Old 12-02-2016, 10:23 AM   #4
Wholegrain's Avatar
Posts: 110   (View Stats)
Wholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant futureWholegrain has a brilliant future
I've had a 2007 rx-8 for about 6 years now. I've only ever daily driven it, so my comments are limited on endurance racing. Worthless stock suspension, overheating was an issue until I swapped the entire cooling system from radiator, fans, plumbing, and controller kit. Oil cooling would be the next issue, and the stock rx-8 oil cooler is notorious for rusting out and going bad, might want to be something you check on. Lastly, I am on my second rotary engine after my first (second rotary) failed on me. I can field the more basic question of operation, perhaps that isn't what you need though. Good luck though! Funnest car i've owned.
'12 Mazdaspeed 3 - AP V3 /Freektuned/ Autotechs / JBR SRI + TIP/ ETS TMIC / Forge VI BPV / Dual Damond OCC/ Ultimate Racing Test Pipe / Ultimate Racing Catback/ JBR 88RMM / JBR 80TMM / JBR Boost Tubes /JBR Rear Sway Bar/ NGK 1 Step Colder/ Corksport Pads/ TWS Nurburgring 18x8.5 et 45//
Wholegrain is offline   Reply With Quote
The Following 2 Users Say Thank You to Wholegrain For This Useful Post:
Pu Manchu (12-02-2016), Tomas (12-02-2016)
 Old 12-02-2016, 10:27 AM   #5
zenit's Avatar
Groans: 57
Do you know why it failed?
-feejay
-wetzel
 Old 12-02-2016, 10:38 AM   #6
Wholegrain's Avatar
Yea, took the typical way out. Apex seal failure/catalytic converter clogging, likely because the weight of the oil used and incomplete combustion. It began as what I thought was a starting issue, so replaced coils/plugs/battery/starter, till I decided that a sluggish warm start wasn't normal. I compression tested obsessively over the next few months to monitor and just watched it steadily decrease, till one day I had a one rotor monster. Everything is up and running now, perfectly.
 Old 12-02-2016, 11:13 AM   #7
Bob Ross Fanclub
Tomas's Avatar
Yeah I've already read up on the clogged cat induced failures. I am in Florida so cat delete is no problem.
The overheating issues are a concern however. Thanks for the comments.
When you say stock suspension is crap do you mean unreliable or just soft? I was of the impression RX-8s handled great.
 Old 12-02-2016, 11:23 AM   #8
Wholegrain's Avatar
I should probably revisit that. It isn't crap. The car handled perfectly fine before the suspension overhaul. However, after putting a set of coilovers, front and rear sway bars, end links, and other suspension odds and ends, the suspension feels sturdier. So my correction is that it can only get better from where it currently stands, and where it currently stands is perfectly fine. As for overheating, I'm up in NJ so winters are freezing and summers are scorching. Summer becomes a very dangerous time for this car, especially when you're caught up in traffic on a highway. Even with all the upgrades cooling wise i'd see my temp gauge get scary close to red zone numbers (circa 220*).
 Old 12-02-2016, 12:25 PM   #9
Natey's Avatar
Posts: 536   (View Stats)
SOOO much less hassle working on a 13B out of an FC then trying to deal with a RENESIS. If you look at pretty much any RX-8 racecar, you'll see a 13b in it.
There's a reason for that. Simplicity.
'93 RX-7: 100% CARB approved. Just some wheels and stuff.
'03.5 Mazdaspeed Protege: Custom clunk and turkey call.
'12 4Runner Limited: Hollister Hills pinstripes, dog hair, beach sand, melted surf wax, a few french fries under the seat...
 Old 12-02-2016, 12:26 PM   #10
Bob Ross Fanclub
Tomas's Avatar
Shit I've had 240 temps on both the 6 and the 3 at the track and in traffic.
What fails from overheating? The Apex seals?
That doesen't really work for chump car racing. First the money. Second the points.
Last edited by Tomas; 12-02-2016 at 12:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-02-2016, 12:30 PM   #11
Natey's Avatar
My point exactly. Find a decent FC and save yourself the headaches and money of trying to work on the 8 engine.
 Old 12-02-2016, 02:04 PM   #12
Wholegrain's Avatar
In the process of rebuilding my 3 as we speak, so working through all the "head stud" debates, "piston alloy" conversations as I try to figure out which way is up or down, your name pops up a lot. So you have more knowledge of all this than I do. So perhaps 240* on the speeds isn't as detrimental as it is for the 8? I am not quite sure. I don't know for certain so I won't lead you astray, ill just go ahead and assume that it aids is the disintegration of the apex seals over time. Also, water pump was upgraded due to the OEM one being prone to cavitation at high temps. Just another heads up I guess.
The Following User Says Thank You to Wholegrain For This Useful Post:
Tomas (12-02-2016)
 Old 12-03-2016, 10:14 PM   #13
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I used to race a '79 RX7 (12A) in SCCA IT7/ITA. Competitively ran against plenty of FC's. Several seasons of revving the absolute piss out of that engine without having to rebuild. I know it's not accurate to make such a blanket statement, but it seems pre-renesis non-turbo rotaries are solid. My daily driver '88 RX7 Turbo II didn't fare so well. Rebuilt 3 times in about 5 years before I called it quits, but that was mostly my own fault...lol (see sig)
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Tomas (12-05-2016), zenit (12-03-2016)
MS6 on turquoise RX8s KotzurRacing Wheels & Tires - METRO GREY 10 01-18-2014 01:59 PM
Just another set of RX8s on a MS6 SuperTrooper169 Wheels & Tires - RED 22 12-05-2011 02:00 PM
Silver MS6 w/RX8s (What Color?) RichieRichness Appearance - SILVER 22 08-16-2011 12:49 PM
Page generated in 0.33263 seconds with 25 queries
