MAZDASPEED Protegé
> MSP - Engine, Transmission & Driveline
 Old 12-21-2013, 02:12 PM   #1
GusDiaz's Avatar
Posts: 2   (View Stats)
GusDiaz is an unknown quantity at this point
Default MSP 03 with missfire at high RPM or Boost
Hi Guys.
I am a proud owner of a Mazdaspeed protégé 2003.5. I have owed this car since new. I have a little problem. I have a misfire only at high RPM (over 3,500) or under boost. I have changed the spark plugs and wires, but still have the same misfire. Do I need to check for a code??? is there any other possibilities that I am not looking at. The car runs good under idle and when normally driven. When you ask boost to it then it starts having the problem.
Thanks, Gus
GusDiaz is offline   Reply With Quote
 Old 12-22-2013, 09:06 AM   #2
GusDiaz's Avatar
Ok, finally found the problem. NGK Iridium 11 Spark Plugs gap at 0.045. As soon I gap them at 0.030-31 the problem was solved. Ran it for 15-20 min at the interstate. No misfire at all. Good vacuum at -22. Good boost at 8.5. will inform is the problem happens again.
P0301 missfire with a twist. thebestdj07 MazdaSpeed 6 - Engine, Transmission & Driveline 5 12-14-2013 08:52 PM
Cylinder 3 missfire 08 Red Rocket MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 09-13-2012 11:35 AM
ms3 cyl 2 missfire shieldsy12 MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-09-2011 07:06 AM
Got a log, is boost high enough? Speedsicks MazdaSpeed 3/6 - ECU Computer Tuning 4 10-04-2009 01:28 AM
missfire? and also blown turbo? wisniaPl MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 05-04-2009 03:55 PM
Page generated in 0.22469 seconds with 20 queries
