 Old 10-05-2019, 12:36 PM   #1
Natedog0009's Avatar
Posts: 2   (View Stats)
Natedog0009 is an unknown quantity at this point
Default 2006 Ms6 smoking at idle issue
Hello Mazdaspeed forum! This is my first post so pardon me if I don't know the exact way how to communicate my ideas and the speed lingo. Yes I know what your thinking this is just the basic smoking ko4 issue but I have been following threads trying to fix it before posting anything. Originally the car used to smoke a little bit at idle after warming up before I got the catless downpipe and fmic but I raised the idle via the AP and it went away. Once I got the catless downpipe I knew it was going to start smoking like a chimney but I was prepared and got the damond motorsports restrictor bolt and had it installed before the downpipe went in. The car would still smoke at idle after the downpipe so I did the next thing which was switching to 5w40 oil and hope. My car still smokes pretty bad at idle(raised to 1000rpm) once it warms up and all I can think is that my ko4 is shit and its time to move on to a cs cts4. Any other possible fixes other than replacing my turbo would be greatly appreciated!
(Cx racing fmic, Cobb AP, Freektune on 91(almost done with revisions), turbo smart 50/50 bov, CS HPFP, CS Injector Seals, Cobb turbo inlet and intake, Damond oil restrictor bolt, M2 hatless downpipe, magna flow catback, NGK one step colder plugs, tranny(JBR) and rear(unknown) engine mounts.)
Natedog0009 is offline   Reply With Quote
 Old 10-05-2019, 06:04 PM   #2
The_big_dill's Avatar
Posts: 38   (View Stats)
The_big_dill has a spectacular aura aboutThe_big_dill has a spectacular aura about
Unless your oil drain from the turbo is clogged, It sounds like you have exhausted all possible options for mitigating the smoking turbo. I too put the restricted oil feed bolt and 5w40 and still smoking.
The catless DP isn't helping either.
The_big_dill is offline   Reply With Quote
Smoking at idle no CEL Tmwtlt Gen2 MS3 General Discussion 3 10-02-2016 06:26 PM
Still smoking at idle. Downthecrapper MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 03-11-2013 08:46 AM
Smoking at idle TrePaul86 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 40 12-03-2012 06:22 AM
Smoking at idle only 06speed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 03-03-2012 04:23 PM
Car smoking at idle!! help! shamuspeed3 Mazdaspeed3/6 General Discussion 11 01-25-2009 07:42 PM
Page generated in 0.23900 seconds with 21 queries
